Hi all,
I'm hoping someone can help me or point me in the right direction to try and find the fault that we are observing. We have created a PCB that is supposed to take 2x Teensy 4.1 boards (CPU1 and CPU2). For some reason, on some of the boards, the Teensy's MKL02Z chip will overheat when inserted in the CPU1 position and then work fine in the CPU2 position. On other boards it will be the other way around. We have found a few boards so far that the Teensy works in both positions and one that the Teensy does not work in any of the positions.
We have tested the 5 V power supplies for the VIN pin on all the boards, and they look good. We have also checked the GND connections, and they ring out fine. Before inserting a Teensy we do cut the trace on the back so that it won't get power from the USB connection anymore.
To me it seems that there must be a problem with the PCB manufacturing process to get such erratic results. What I would like advice on is what could cause the MKL02Z chip to overheat specifically? I'm hoping that might help us find the problem with the PCBs.
I have attached the schematic that we used to create the PCB. Maybe it is obvious to someone that we made an error somewhere.
Thanks very much for your time.
