bigwetdognose
Hi All,
Here's a project I've worked on for the past few months. Designed specifically around the Teensy's ability to function as a MID controller. Hope you like it.
Modi is a expandable controller bank system designed for AVR microcontroller platforms like Arduino and Teensy. There are four distinct module types available, each consisting of either 8 or 16 individually readable analog or digital controllers. Modi boards can be stacked to support up to 64 inputs making them ideal for MIDI/OSC projects.
The system utilizes the 4051 8-channel analog multiplexer and a firmware library to collect readings from all the controllers. A smoothing method is included in the library to facilitate stable readings.
There are four board types...
Hybri 8 buttons + 8 potentiometers
Turni 16 potentiometers
Pushi 16 buttons
Slidi 8 slide potentiometers
GitHub Repository: https://github.com/brendan-byrne/Modi
Assembly Instructions: http://brendanbyrne.info/Hybri-Assembly-Instructions
Purchase Kits: http://xiwielectronics.com/collections/all
Pushi 16 buttons
