/* Audio Library Note Frequency Detection & Guitar/Bass Tuner
* Copyright (c) 2015, Colin Duffy
* THE SOFTWARE.
#include "utility/dspinst.h"
#include "arm_math.h"
#include "Arduino.h"
#include "AudioTuner.h"
#define NUM_SAMPLES ( AUDIO_GUITARTUNER_BLOCKS << 7 )
void AudioTuner::update( void ) {
audio_block_t *block;
block = receiveReadOnly();
if (!block) return;
if ( !enabled ) {
release( block );
return;
* "factor" is the new block size calculated by
* the decimated shift to incremnt the buffer
* address.
const uint8_t factor = AUDIO_BLOCK_SAMPLES >> decimation_shift;
// filter and decimate block by block the incoming signal and store in a buffer.
arm_fir_decimate_fast_q15( &firDecimateInst, block->data, AudioBuffer + ( state * factor ), AUDIO_BLOCK_SAMPLES );
* when half the blocks + 1 of the total
* blocks have been stored in the buffer
* start processing the data.
if ( state++ >= AUDIO_GUITARTUNER_BLOCKS >> 1 ) {
if ( process_buffer ) process( AudioBuffer );
if ( state == 0 ) process_buffer = true;
release( block );
* Start the Yin algorithm
* TODO: Significant speed up would be to use spectral domain to find fundamental frequency.
* This paper explains: https://aubio.org/phd/thesis/brossier06thesis.pdf -> Section 3.2.4
* page 79. Might have to downsample for low fundmental frequencies because of fft buffer
* size limit.
void AudioTuner::process( int16_t *p ) {
const uint16_t inner_cycles = ( NUM_SAMPLES >> decimation_shift ) >> 1;
uint16_t outer_cycles = inner_cycles / AUDIO_GUITARTUNER_BLOCKS;
uint16_t tau = tau_global;
do {
uint64_t sum = 0;
int32_t a1, a2, b1, b2, c1, c2, d1, d2;
int32_t out1, out2, out3, out4;
uint16_t blkCnt;
int16_t * cur = p;
int16_t * lag = p + tau;
// unrolling the inner loop by 8
blkCnt = inner_cycles >> 3;
do {
// a(n), b(n), c(n), d(n) each hold two samples
a1 = *__SIMD32( cur )++;
a2 = *__SIMD32( cur )++;
b1 = *__SIMD32( lag )++;
b2 = *__SIMD32( lag )++;
c1 = *__SIMD32( cur )++;
c2 = *__SIMD32( cur )++;
d1 = *__SIMD32( lag )++;
d2 = *__SIMD32( lag )++;
// subract two samples at a time
out1 = __QSUB16( a1, b1 );
out2 = __QSUB16( a2, b2 );
out3 = __QSUB16( c1, d1 );
out4 = __QSUB16( c2, d2 );
// square the difference
sum = multiply_accumulate_16tx16t_add_16bx16b( sum, out1, out1 );
sum = multiply_accumulate_16tx16t_add_16bx16b( sum, out2, out2 );
sum = multiply_accumulate_16tx16t_add_16bx16b( sum, out3, out3 );
sum = multiply_accumulate_16tx16t_add_16bx16b( sum, out4, out4 );
} while( --blkCnt );
uint64_t rs = running_sum;
rs += sum;
yin_buffer[yin_idx] = sum*tau;
rs_buffer[yin_idx] = rs;
running_sum = rs;
yin_idx = ( ++yin_idx >= 5 ) ? 0 : yin_idx;
tau = estimate( yin_buffer, rs_buffer, yin_idx, tau );
if ( tau == 0 ) {
process_buffer = false;
new_output = true;
yin_idx = 1;
running_sum = 0;
tau_global = 1;
state = 0;
return;
} while ( --outer_cycles );
if ( tau >= inner_cycles ) {
new_output = false;
yin_idx = 1;
running_sum = 0;
tau_global = 1;
state = 0;
return;
tau_global = tau;
* check the sampled data for fundamental frequency
* @param yin buffer to hold sum*tau value
* @param rs buffer to hold running sum for sampled window
* @param head buffer index
* @param tau lag we are curly working on gets incremented
* @return tau
uint16_t AudioTuner::estimate( uint64_t *yin, uint64_t *rs, uint16_t head, uint16_t tau ) {
const uint64_t *y = ( uint64_t * )yin;
const uint64_t *r = ( uint64_t * )rs;
uint16_t _tau, _head;
const float thresh = yin_threshold;
_tau = tau;
_head = head;
if ( _tau > 4 ) {
uint16_t idx0, idx1, idx2;
idx0 = _head;
idx1 = _head + 1;
idx1 = ( idx1 >= 5 ) ? 0 : idx1;
idx2 = _head + 2;
idx2 = ( idx2 >= 5 ) ? idx2 - 5 : idx2;
// maybe fixed point would be better here? But how?
float s0, s1, s2;
s0 = ( ( float )*( y+idx0 ) / ( float )*( r+idx0 ) );
s1 = ( ( float )*( y+idx1 ) / ( float )*( r+idx1 ) );
s2 = ( ( float )*( y+idx2 ) / ( float )*( r+idx2 ) );
if ( s1 < thresh && s1 < s2 ) {
uint16_t period = _tau - 3;
periodicity = 1 - s1;
data = period + 0.5f * ( s0 - s2 ) / ( s0 - 2.0f * s1 + s2 );
return 0;
return _tau + 1;
* Initialise
* @param threshold Allowed uncertainty
void AudioTuner::begin( float threshold, int16_t *coeff, uint8_t taps, uint8_t factor ) {
__disable_irq( );
yin_threshold = threshold;
periodicity = 0.0f;
running_sum = 0;
tau_global = 1;
yin_idx = 1;
enabled = true;
state = 0;
data = 0.0f;
decimation_factor = factor;
decimation_shift = log( factor ) / log( 2 );
coeff_size = taps;
coeff_p = coeff;
arm_fir_decimate_init_q15( &firDecimateInst, coeff_size, decimation_factor, coeff_p, &coeff_state[0], AUDIO_BLOCK_SAMPLES );
__enable_irq( );
* available
* @return true if data is ready else false
bool AudioTuner::available( void ) {
__disable_irq( );
bool flag = new_output;
if ( flag ) new_output = false;
__enable_irq( );
return flag;
* read processes the data samples for the Yin algorithm.
* @return frequency in hertz
float AudioTuner::read( void ) {
__disable_irq( );
float d = data;
__enable_irq( );
return ( AUDIO_SAMPLE_RATE_EXACT / decimation_factor ) / d;
* Periodicity of the sampled signal.
* @return periodicity
float AudioTuner::probability( void ) {
__disable_irq( );
float p = periodicity;
__enable_irq( );
return p;
* New LP coeffients for decimation.
* @param p array pointer of coeffients.
* @param n array size.
void AudioTuner::coeff( int16_t *p, int n ) {
//coeff_size = n;
//coeff_p = p;
//arm_fir_decimate_init_q15(&firDecimateInst, coeff_size, 4, coeff_p, coeff_state, 128);
* Initialise parameters.
* @param thresh Allowed uncertainty
void AudioTuner::threshold( float p ) {
__disable_irq( );
yin_threshold = p;
__enable_irq( );
* disable yin from processing data, use begin to start back up
* @return none
void AudioTuner::disable( void ) {
__disable_irq( );
enabled = false;
__enable_irq( );
