Is anybody interested in * .flac ?
I think FLAC would be enough for now, I use ALAC but only because I have apple devices and iTunes doesn't support FLAC.
In file included from D:\Projets\_SVN_\Dev\Arduino\libraries\Teensy-Codec\aac.cpp:24:0:
D:\Projets\_SVN_\Dev\Arduino\libraries\Teensy-Codec\aac/imdct.c:48:1: error: 'erte' does not name a type
D:\Projets\_SVN_\Dev\Arduino\libraries\Teensy-Codec\aac/imdct.c: In function 'int raac_IMDCT(AACDecInfo*, int, int, short int*)':
D:\Projets\_SVN_\Dev\Arduino\libraries\Teensy-Codec\aac/imdct.c:573:127: error: 'DecWindowOverlap' was not declared in this scope
Noobish question :
I downloaded the git zip, extracted in my libraries folder, loaded the Mp3FilePlayer example and got those errors while compiling :
ok..before this last malloc(), FreeRam() reports -10828 Bytes
Tried the official version (edited hours... 1000's of warnings away, found a bug: #pragma GCC diagnostic ignored "-fpermissive" is ignored by the compiler)
The same.
Ok... something for the next Teensy, i think
Flac maybe is fast, but the ram-usage is...![]()
Yeah, i'm also interested in FLAC playback indeed. I should try out your latest experimental version soon, I just got too many other projects running at this board, I just bought a second teensy3.1 from Velleman, toobad Velleman doesnt sell the audioboard yet, though they said soon at the next year.
like above said, I have also have a lot of flac files laying around, just because of the better soundings, though most of them are 44~48khz.
my current solution is using PWM output and the dac output, but there's alot of difference on the sound output. sounds like one output is inverted and not always in sync, so it sounds like you are moving phases a few degrees over time. but thats not your code!
But awesome that you bring these decodings to teensy!
Thank you so much for your work !
Next:
- Playing from teensy-flash & serial flash.
- improvements to the internal structure of the lib
