sbfreddie
This is an oddball problem that has just come up, maybe because I have not built this piece of code including MTP for quite some time.
I received this peculiar error from my build:
In digging into this dilemma, I discover in the MTP part of the build, which I did include in my build this section of MTP_SD_Callbacks.cpp:
Any ideas on how to get around this problem without hacking up the MTP Library?
Regards,
Ed
And in the process of trying to figure out what the problem was, considering that I did not include "USBHost_t36" in my build because I am not using it for anything, I looked further and discovered that the build engine was building the "SdFat" and "SD" libraries as well, which I also did not include in my build./Users/freddie/.platformio/packages/framework-arduinoteensy/libraries/USBHost_t36/bluetooth.cpp:35:10: fatal error: EEPROM.h: No such file or directory
and in this section of MTP_USBFS_Callbacks.cpp:// This code should only be build and run if the SD library was included in the sketch
#if defined(__has_include) && __has_include(<SD.h>)
aha! So this is the guilty culprit. The compiler is not responding to the directive "__has_include" at all probably because this version of Teensy:// This code should only be build and run if the USBHost_t36 library was included in the sketch
#if defined(__has_include) && __has_include(<USBHost_t36.h>)
#include <USBHost_t36.h>
Teensy 1.59 which is the current released version, is using the compiler version 11.3.1, and according to my google search the directive "__has_include" was not included until version 17 of the compiler.- framework-arduinoteensy @ 1.159.0 (1.59)
- tool-teensy @ 1.159.0 (1.59)
- toolchain-gccarmnoneeabi-teensy @ 1.110301.0 (11.3.1)
Regards,
Ed
