Hello,
I plan to control a couple of 12V motors and a 5V Motor (in a pump) with teensy3. What would be the best way to go about having access to these voltages. By default I envision a power cable from 110V outlet connected to two power adapters (one for 5V and one for 12V). I would use output from 5V adapter to supply power to teensy and 5V motor and the other adapter will feed power on A4988 Stepper Motor Driver Carrier, which will drive the motor. Is there a better alternative, such as having a single circuit that could provide both voltages? I do not need both voltages active in my circuit at the same time, so maybe I can get a variable power supply that can be controlled by teensy? Any suggestions.
Thanks,
Alexander
Thanks,
Alexander
