Hello-
I cobbled together this code on another thread and it basically does what I want. It works with 4 or 5 files, but i thought I could just add my own files...as many as I like...20 wav files...nothing very long or big in size. And it doesn't really work. It plays a couple of files but only sometimes. I also had a real hard time with SD cards. I had three and only one would work. Formatted to FAT32. These were SanDisk Ultra 32G. It wasn't until I switched to a Pioneer 16G that I got it to work. Is it something with the SD cards? the formatting? the WAV files? or is it the code?
I thought I could just change the filenames and the wavnum and I could run a bunch of files....it only seems to work with the original 4 or 5 files.
thanks, steve
thanks, steve
#include <SerialFlash.h>
#include <Bounce.h>
// create audio component objects
AudioPlaySdWav playWav1; // SD card wav file player
AudioInputI2S audioInput; // audio shield input, mic or line-in selectable
AudioMixer4 mixer1; // mixers to combine wav file and audio shield inputs
AudioMixer4 mixer2;
// Use one of these 3 output types: Digital I2S, Digital S/PDIF, or Analog DAC
AudioOutputI2S audioOutput;
//AudioOutputSPDIF audioOutput;
//AudioOutputAnalog audioOutput;
// wire up the interfaces between audio components with patch cords
// mixer inputs
AudioConnection patchCord1(playWav1, 0, mixer1, 0); // left channels into mixer 1
AudioConnection patchCord2(audioInput, 0, mixer1, 1);
AudioConnection patchCord3(playWav1, 1, mixer2, 0); // right channels into mixer 2
AudioConnection patchCord4(audioInput, 1, mixer2, 1);
// mixer outputs
AudioConnection patchCord5(mixer1, 0, audioOutput, 0);
AudioConnection patchCord6(mixer2, 0, audioOutput, 1);
// object to allow control of the SGTL5000 audio shield settings
// buttons and potentiometers
#define pot0 A1
#define pot1 A2
#define pot2 A3
#define button0 0
#define button1 1
#define button2 2
//#define button3 27
// attach button debouncers to input buttons
Bounce db_button0 = Bounce(button0, 30);
Bounce db_button1 = Bounce(button1, 30);
Bounce db_button2 = Bounce(button2, 30);
//Bounce db_button3 = Bounce(button3, 30);
// choose mic or line input for audio shield input path
const int inputChSelect = AUDIO_INPUT_MIC;
//const int inputChSelect = AUDIO_INPUT_LINEIN;
// audio shield volume
int masterVolume = 0;
// uncomment one set of SD card SPI pins to use
// Use these with the Teensy Audio Shield
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
// wav filenames on SD card for playback
char *wavFiles[] = {"CM.000.WAV", "SDTEST1.WAV", "SDTEST2.WAV", "SDTEST3.WAV", "SDTEST4.WAV"};
byte wavNum = 0; // current wav file index playing from array list
bool wavIsPlaying = false; // track if a wav file is currently playing or not
Serial.println("SD Player Demo\n");
// buttons are inputs with pullups
pinMode(button0, INPUT_PULLUP);
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
//pinMode(button3, INPUT_PULLUP);
// Audio connections require memory to work. For more
AudioMemory(8);
// comment these out if not using the audio adaptor board.
Serial.print("init audio shield...");
audioShield.enable();
audioShield.inputSelect(inputChSelect); // select mic or line-in for audio shield input source
audioShield.volume(0.5);
Serial.println("done.");
mixer1.gain(0, 0.5);
mixer1.gain(1, 0.5);
mixer1.gain(2, 0);
mixer1.gain(3, 0);
mixer2.gain(0, 0.5);
mixer2.gain(1, 0.5);
mixer2.gain(2, 0);
mixer2.gain(3, 0);
Serial.print("init SD card...");
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
// stop here, but print a message
Serial.println("Unable to access the SD card. Program halted.");
while (1);
Serial.println("Waiting for control input...");
// reset audio resource usage stats.
// useful if tracking max usage in main program
AudioProcessorUsageMaxReset();
AudioMemoryUsageMaxReset();
void playFile(const char *filename)
Serial.print("Start playing file: ");
Serial.println(filename);
// start playing the file.
// sketch continues to run while the file plays.
playWav1.play(filename);
// A brief delay for the library to read WAV header info
delay(5);
// auto select next wav file if current file finishes playing
// and if playback is enabled
if ((!(playWav1.isPlaying())) && (wavIsPlaying)) {
wavNum++;
if (wavNum > 4) {
wavNum = 0;
playFile(wavFiles[wavNum]);
// read volume control pot and set audio shield volume if required
int vol = analogRead(pot0);
if (vol != masterVolume) {
masterVolume = vol;
audioShield.volume((float)vol / 1023); // audio shield headphone out volume (optional)
mixer1.gain(0, (float)vol / 1023); // software mixer input channel volume
mixer1.gain(1, (float)vol / 1023);
mixer2.gain(0, (float)vol / 1023);
mixer2.gain(1, (float)vol / 1023);
// update the button debounce status so falling edges
// can be detected and processed
db_button0.update();
db_button1.update();
db_button2.update();
//db_button3.update();
// button 0 pressed - toggle playback start/stop for current wav file
if (db_button0.fallingEdge()) {
if (playWav1.isPlaying()) {
playWav1.stop();
Serial.println("Playback stopped\n");
else {
wavIsPlaying = true;
Serial.println("Playback started");
//Serial.print("Audio memory usage max: ");
//Serial.println(AudioMemoryUsageMax());
// button 1 pressed - skip track forward
if (db_button1.fallingEdge()) {
Serial.println("Skip track forward");
if (wavNum == 4)
wavNum = 0;
wavNum++;
// button 2 pressed - skip track backward
if (db_button2.fallingEdge()) {
Serial.println("Skip track backward");
if (wavNum == 0)
wavNum = 4;
wavNum--;
