I've got a dumb question about using teensy libraries. I'm a fairly experienced embedded developer, but new to Arduinio and Teensy. My project is to use a Teensy 4.1 to receive some low bandwidth incoming UDP/IP data packets and convert to some other types of I/O. I've got Arduino 1.8.19 and Teensyduino 1.56 installed on a Windows 10 computer.
I want to use the NativeEthernet libraries and I've read the messages at
https://forum.pjrc.com/threads/60857-T4-1-Ethernet-Library/ and some other posts
I ran the UDPSendReceiveString example that came with Teensyduino and it worked just fine where it was directly connected to another computer without a hub/router using static IPs and I used the windows program PacketSender to exercise it from the other networked computer. I was running the example and had to change the IP address and then couldn't save changes because of where it was installed under c:/Program Files (x86)/Arduino/hardware/teensy/avr/libraries/NativeEthernet/......
I would like to take the UDPSendReceiveString project and copy it over to my sketch folder at ../Documents/Arduino/Projects/EthernetProject01/EthernetProject01.ino and add to that for my new project.
However when I build it from there, it can no longer find the native ethernet or fnet libraries. Apparently the teensy libraries are installed in a different path than the regular Arduino libraries. I go to the library manager and try to install them, but there are not there. So I copied the NativeEthernet and FNET libraries from where they got installed over to my sketch folder at ../Documents/Arduino/libraries/NativeEthernet and ../Documents/Arduino/libraries/FNET.
When I try to compile my newly named UDPSendReceiveString sketch it can apparently now build in the NativeEthernet and FNET libraries, but I'm still getting a bunch of type related errors like this:
C:\Users\Majors\Documents\Arduino\libraries\NativeEthernet\src/NativeEthernet.h:80:12: error: 'DMAMEM' does not name a type; did you mean 'EEMEM'?
static DMAMEM uint8_t** socket_buf_transmit;
EEMEM
Which makes me think there are still more libraries over there in the installed folder structure that I would have to copy over to my sketch folder structure.
So here's the big question....... how do you start your own sketch based on a Teensy example, using Teensy libraries ? How do you tell Arduino how to find the Teensy libraries where are originally located when installed so you don't have play trial and error ?
Thanks for any help. I'm sure this has an easy answer, I just haven't come across it yet and need a nudge in the right direction.
Mike
EEMEM
Mike
