//#define SINGLE_EYE // only do a single eye
//#define SERIAL_tt Serial // Send debug_tt output here. Must have SERIAL_tt.begin( ## )
//#include "debug_tt.h"
// Pin selections here are based on the original Adafruit Learning System
// guide for the Teensy 3.x project. Some of these pin numbers don't even
// exist on the smaller SAMD M0 & M4 boards, so you may need to make other
// selections:
// GRAPHICS SETTINGS (appearance of eye) -----------------------------------
// If using a SINGLE EYE, you might want this next line enabled, which
// uses a simpler "football-shaped" eye that's left/right symmetrical.
// Default shape includes the caruncle, creating distinct left/right eyes.
// Otherwise your choice, standard is asymmetrical
#define SYMMETRICAL_EYELID
// Enable ONE of these #includes -- HUGE graphics tables for various eyes:
#if( DISPLAY_SIZE == 240 )
#include "graphics/default_large.h" // 240x240
#else
#include "graphics/defaultEye.h" // Standard human-ish hazel eye -OR-
//#include "graphics/dragonEye.h" // Slit pupil fiery dragon/demon eye -OR-
//#include "graphics/noScleraEye.h" // Large iris, no sclera -OR-
//#include "graphics/goatEye.h" // Horizontal pupil goat/Krampus eye -OR-
//#include "graphics/newtEye.h" // Eye of newt -OR-
//#include "graphics/terminatorEye.h" // Git to da choppah!
//#include "graphics/catEye.h" // Cartoonish cat (flat "2D" colors)
//#include "graphics/owlEye.h" // Minerva the owl (DISABLE TRACKING)
//#include "graphics/naugaEye.h" // Nauga googly eye (DISABLE TRACKING)
//#include "graphics/doeEye.h" // Cartoon deer eye (DISABLE TRACKING)
//#include "graphics/Nebula.h" //Dont work
//#include "graphics/MyEyeHuman1.h"
//#include "graphics/Human-HAL9000.h"
//#include "graphics/NebulaBlueGreen.h"
//#include "graphics/SpiralGalaxy.h"
//#include "graphics/ChameleonX_Eye.h" //no work
//#include "graphics/MyEye.h"
// Optional: enable this line for startup logo (screen test/orient):
#if !defined(ADAFRUIT_HALLOWING) // Hallowing can't always fit logo+eye
#include "graphics/logo.h" // Otherwise your choice, if it fits
// EYE LIST ----------------------------------------------------------------
// DISPLAY HARDWARE SETTINGS (screen type & connections) -------------------
//#define TFT_SPI SPI
//#define TFT_PERIPH PERIPH_SPI
// Enable ONE of these #includes to specify the display type being used
//#include <ST7735_t3.h> // TFT display library (enable one only)
#include <ST7789_t3.h>
#define SPI_FREQ 48000000 // TFT: use max SPI (clips to 12 MHz on M0)
// This table contains ONE LINE PER EYE. The table MUST be present with
// this name and contain ONE OR MORE lines. Each line contains THREE items:
// a pin number for the corresponding TFT/OLED display's SELECT line, a pin
// pin number for that eye's "wink" button (or -1 if not used), and a screen
// rotation value (0-3) for that eye.
eyeInfo_t eyeInfo[] =
#ifdef ST77XX_ON_SPI_SPI1
// SPI
//#define L_CS -1 // left display, no CS pin
//#define L_CS 10 // left display, main CS pin for SPI
#define L_CS 22 // left display, alternate CS, avoid I2S pins and avoid audio shield SD card
#define L_DC 9 // left display, D/C pin
#define L_RST 8 // left display, reset pin
#define L_SCK 13 // left display, clock pin
#define L_MOSI 11 // left display, MOSI pin
#define L_WINK -1 // left display, no wink
#define L_ROT 0 // left display, rotation
//#define L_INIT 0 // left display, initialization for no CS pin display
#define L_INIT INITR_144GREENTAB // left display, initialization for display with CS pin
// SPI1
//#define R_CS -1 // right display, no CS pin
#define R_CS 0 // right display, main CS pin for SPI
#define R_DC 25 // right display, D/C pin
#define R_RST 7 // right display, reset pin
#define R_SCK 27 // right display, clock pin SPI1
#define R_MOSI 26 // right display, MOSI pin SPI1
#define R_WINK -1 // right display, no wink
#define R_ROT 0 // right display, rotation
//#define R_INIT 0 // right display, initialization for no CS pin display
#define R_INIT INITR_144GREENTAB // right display, initialization for display with CS pin
//CS DC MOSI SCK RST WINK ROT INIT
{ L_CS, L_DC, L_MOSI, L_SCK, L_RST, L_WINK, L_ROT, L_INIT },
#ifndef SINGLE_EYE
{ R_CS, R_DC, R_MOSI, R_SCK, R_RST, R_WINK, R_ROT, R_INIT },
#else
{0, 2, 26, 27, 3, -1, 0, INITR_144GREENTAB }, // RIGHT EYE display-select and wink pins, no rotation
{10, 9, 11, 13, 8, -1, 0, INITR_144GREENTAB }, // LEFT EYE display-select and wink pins, no rotation
// INPUT SETTINGS (for controlling eye motion) -----------------------------
// JOYSTICK_X_PIN and JOYSTICK_Y_PIN specify analog input pins for manually
// controlling the eye with an analog joystick. If set to -1 or if not
// defined, the eye will move on its own.
// IRIS_PIN speficies an analog input pin for a photocell to make pupils
// react to light (or potentiometer for manual control). If set to -1 or
// if not defined, the pupils will change on their own.
// BLINK_PIN specifies an input pin for a button (to ground) that will
// make any/all eyes blink. If set to -1 or if not defined, the eyes will
// only blink if AUTOBLINK is defined, or if the eyeInfo[] table above
// includes wink button settings for each eye.
//#define JOYSTICK_X_PIN A0 // Analog pin for eye horiz pos (else auto)
//#define JOYSTICK_Y_PIN A1 // Analog pin for eye vert position (")
//#define JOYSTICK_X_FLIP // If defined, reverse stick X axis
//#define JOYSTICK_Y_FLIP // If defined, reverse stick Y axis
//#define TRACKING // If defined, eyelid tracks pupil
//#define AUTOBLINK // If defined, eyes also blink autonomously
#define BLINK_PIN 3 // Pin for manual blink button (BOTH eyes)
//#define LIGHT_PIN A9 // Photocell or potentiometer (else auto iris)
//#define LIGHT_PIN_FLIP // If defined, reverse reading from dial/photocell
#define LIGHT_MIN 0 // Lower reading from sensor
#define LIGHT_MAX 1023 // Upper reading from sensor
#define IRIS_SMOOTH // If enabled, filter input from IRIS_PIN
#if DISPLAY_SIZE > 128
#if !defined(IRIS_MIN) // Each eye might have its own MIN/MAX
#define IRIS_MIN 500 // Iris size (0-1023) in brightest light
#if !defined(IRIS_MAX)
#define IRIS_MAX 700 // Iris size (0-1023) in darkest light
#else
#define IRIS_MIN 120 // Iris size (0-1023) in brightest light
#define IRIS_MAX 720 // Iris size (0-1023) in darkest light
