HI,
Im trysint to read from two SHT31 sensors, but keep getting errors using this library, can anyone please advise?
#include <i2c_t3.h>
#include <Arduino.h>
#include "Adafruit_SHT31.h"
#include <SoftwareSerial.h>
SoftwareSerial lcd = SoftwareSerial(0, 7); //lcd tx pin = 7
//#include <i2c_t3.h>
Adafruit_SHT31 sht31a = Adafruit_SHT31();
Adafruit_SHT31 sht31b = Adafruit_SHT31();
Wire.begin(I2C_MASTER, 0x44, 33, 34);
Wire1.begin(I2C_MASTER, 0x45, 37, 38);
SPI.begin(); // Init SPI bus
while (!Serial)
delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println("SHT31 test");
if (! sht31a.begin(0x44)) { // first sensor with default address
Serial.println("Couldn't find SHT31 #1");
while (1) delay(1);
if (! sht31b.begin(0x45)) { // second sensor with secondary address
Serial.println("Couldn't find SHT31 #2");
while (1) delay(1);
lcd.begin(9600); //initializes lcd
lcd.write(0xFE); //screen size
lcd.write(0xD1);
lcd.write(16);
lcd.write(2);
float t = sht31a.readTemperature();
float h = sht31a.readHumidity();
float t2 = sht31b.readTemperature();
float h2 = sht31b.readHumidity();
if (! isnan(t)) { // check if 'is not a number'
Serial.print("Temp *C = "); Serial.println(t);
Serial.println("Failed to read temperature");
delay (100);
if (! isnan(t2)) { // check if 'is not a number'
Serial.print("Temp *C = "); Serial.println(t2);
if (! isnan(h)) { // check if 'is not a number'
Serial.print("Hum. % = "); Serial.println(h);
lcd.write(0xFE);
lcd.write(0x58);
lcd.print("Hum. % = "); lcd.println(h);
Serial.println("Failed to read humidity");
delay (100);
if (! isnan(h2)) { // check if 'is not a number'
Serial.print("Hum. % = "); Serial.println(h2);
lcd.write(0xFE);
lcd.write(0x58);
lcd.print("Hum. % = "); lcd.println(h2);
In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire/Wire.h:26:0,
from C:\Users\kedar\Dropbox\code\SHT31test_teensy\SHT31test_teensy.ino:16:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire/WireKinetis.h:215:16: error: conflicting declaration 'TwoWire Wire'
extern TwoWire Wire;
In file included from C:\Users\kedar\Dropbox\code\SHT31test_teensy\SHT31test_teensy.ino:1:0:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\i2c_t3-master/i2c_t3.h:989:15: note: previous declaration as 'i2c_t3 Wire'
extern i2c_t3 Wire;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire/WireKinetis.h:218:16: error: conflicting declaration 'TwoWire Wire1'
extern TwoWire Wire1;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\i2c_t3-master/i2c_t3.h:991:19: note: previous declaration as 'i2c_t3 Wire1'
extern i2c_t3 Wire1;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire/WireKinetis.h:221:16: error: conflicting declaration 'TwoWire Wire2'
extern TwoWire Wire2;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\i2c_t3-master/i2c_t3.h:994:19: note: previous declaration as 'i2c_t3 Wire2'
extern i2c_t3 Wire2;
Error compiling for board Teensy 3.5.
