Are your QoS capabilities in a public fork?Just checking because I used your ieee 1588-2 branch for my AES67 4.1 implementation. I did modify it to include QoS capabilities. QNEthernet is awesome thanks so much for all your work.
## [0.34.0]
### Added
* Added tests for some of the print utility functions and classes.
* Added the `QNETHERNET_ENABLE_PING_REPLY` macro to disable ICMP echo replies.
* Added a "Requirements" section listing some library requirements to
the README.
* Added a `QNETHERNET_PROVIDE_GNU_VERBOSE_TERMINATE_HANDLER` configuration
option for including our own version of
`__gnu_cxx::__verbose_terminate_handler` for space-saving reasons.
* New `StreamDecorator` class that also does `printf` checking.
* Added `driver_restart_auto_negotiation()` driver function for restarting link
auto-negotiation. This is useful for when EMF brings the link down. A new
"EMF interference mitigation" section was also added to the Readme.
* Added `qindesign::network::util::isBroadcast(ip, localIP, mask)`.
* New `EthernetUDP::destIP()` for getting the destination IP address from
a received packet.
### Changed
* Improved code style and structure.
* Made `NullPrint::availableForWrite()` return `INT_MAX` instead of zero.
* Changed `EthernetUDP::stop()` to not clear the current packet.
* Changed `DNSClient::hostByName()` functions to use a default value of
`QNETHERNET_DEFAULT_DNS_LOOKUP_TIMEOUT` for the timeout parameter.
* Improved _SimplePing_ example to catch DNS lookup errors.
* Changed ping send enable macro to `QNETHERNET_ENABLE_PING_SEND`
from `QNETHERNET_ENABLE_PING`.
* Updated to support C++11 and C11 compilers.
* Improved setting of `errno`.
* Added `printf` checking to `PrintDecorator`.
* Replaced function-like-macros with `static inline` C functions.
* Renamed `QNETHERNET_ENABLE_ALTCP_DEFAULT_FUNCTIONS` macro
to `QNETHERNET_PROVIDE_ALTCP_DEFAULT_FUNCTIONS`.
* `EthernetUDP` and `EthernetFrame` now share some common circular buffer code
in an internal utility class.
* Replaced macros in `EthernetClient` with inline functions.
### Fixed
* Fixed `EthernetUDP` internal packet clear to reset all variables.
* Now keeping any manually-set link UP state sticky so that the driver can
choose not to set it to DOWN.
* Updated _Ping_ and _SimplePing_ examples to work with other systems by
changing use of `elapsedMillis` to `unsigned long` plus calculations.
* Fixed `ConnectionManager::iterateConnections()` calls to not call
`Ethernet.loop()` in the callback because that could potentially invalidate
the iterator. Also added notes about potential iteration invalidation to the
`iterateConnections()` and `iterateListeners()` docs.
* Fixed `EthernetClient` `read()` and `peek()` to return the correct value if
not connected.
The updates through the Arduino IDE don’t usually propagate for a day or so.Working fine for me still although I haven't added any of your new stuff yet. Oh come to think of it, Aduino 2.3.7 with Paul's beta6 didn't notify me to update, I saw email of this thread.
It takes using the new JSON :: https://www.pjrc.com/teensy/td_160-beta6/package_teensy_0.60.6_index.jsonbeta6 didn't notify me to update
## [0.35.0]
### Added
* Added a ping call to the main program.
* Added `qindesign::network::util::steady_clock_ms` and
`qindesign::network::util::arm_high_resolution_clock` classes that conform to
the _Clock_ C++ named requirement. These can be used with the `std::chrono`
API. The first provides a wrapper for `qnethernet_hal_millis()`. The second
wraps the ARM DWT_CYCCNT cycle counter.
* Added printing chrono clock times to network-up in the main program.
* Added `qindesign::network::util::elapsedTime<Clock>`, a class similar to
`elapsedMillis`, but uses a `std::chrono` Clock.
* Added support to the W5500 driver for interrupts via a pin.
* New _SimpleIPerfServer_ example. It just reads from a socket as fast
as possible.
* Added `write(const void*, size_t)` convenience functions to all
`Print`-like classes.
* New _ChronoClocks_ example that demonstrates how to use the new Clocks and
`std::chrono` features.
* Added `EthernetClass::linkInfo()` to replace `linkSpeed()`,
`linkIsFullDuplex()`, and `linkIsCrossover()`.
* Implemented setting link speed, duplex, and auto-negotiation in Teensy 4.1 and
W5500 drivers.
* Added `driver_reset_phy()` driver function for resetting the PHY.
* Added to `DriverCapabilities`:
* `isAutoNegotiationSettable`
* `isPHYResettable`
* Added call to `qnethernet_hal_deinit_entropy()` in `RandomDevice` destructor.
* Added `RandomDevice::entropy()` to match `std::random_device::entropy()`.
* Added `qindesign::security::random_device` to mimic `std::random_device`.
* New _ElapsedTime_ example that shows how to use the new `elapsedTime` utility.
### Changed
* Improved _Ping_ example by always sending, even if a send fails. It was
stopping on error.
* Changed some sizes to `size_t` instead of `int`:
* `writeFully(client, data, len)` example in the Readme
* `EthernetClass::kMACAddrSize`
* `EthernetClass::maxMulticastGroups()`
* `EthernetClass::dnsServerIP(index)`
* `EthernetClass::setDNSServerIP(index, ip)`
* `DNSClient::maxServers()`
* `DNSClient::setServer(index, ip)`
* `DNSClient::getServer(index)`
* `EthernetClient::maxSockets()`
* `EthernetFrame::maxFrameLen()`
* `EthernetFrame::minFrameLen()`
* `EthernetServer::maxListeners()`
* `EthernetUDP::maxSockets()`
* `MDNSClass::maxServices()`
* Changed `EthernetClass::begin(mac, timeout)` return type to `bool` from `int`.
* Robustness changes:
* Removed all implicit conversions
* Handle all return values in some way
* Reduced the number of #defines in favour of constants, enums, and static
inline functions
* Changed `MDNSClass` to use `std::string` instead of the Arduino `String`.
* Updated examples to be more consistent with each other.
* Changed drivers to always loop until a frame can be sent instead of returning
`ERR_WOULDBLOCK` or NULL.
* Marked _IPerfServer_ example as "Under Repair".
* Now excluding the FCS (Frame Check Sequence) from all frame length-related
definitions and use.
* Made dramatic improvements to the W5500 driver with much better buffering and
how it waits to send frames.
* Updated the W5500 driver's `driver_deinit()` function to power down the PHY.
* Updated drivers to change link settings and get link info as a group. See the
new `LinkSettings` and `LinkInfo` structs.
* Changed all definitions of, uses of, and references to max. and min. frame
length to exclude the FCS (frame check sequence).
* Made `QNETHERNET_ENABLE_PING_SEND` on by default.
* Updated _SNTPClient_ example to use `settimeofday()` to set the time.
* Updated _RandomNumbers_ example to use new
`qindesign::security::random_device` class.
### Removed
* Removed from `EthernetClass` (and replaced with `linkInfo()`):
* `linkSpeed()`
* `linkIsFullDuplex()`
* `linkIsCrossover()`
### Fixed
* Fixed `EthernetClass::ping(ip, ttl)` to return -1 if sending the ping failed.
* Fixed _RawFrameMonitor_ example tag interpretation to split at <=1500 and
assume values in the range 1501-1535 are a type.
* Fixed setting an incorrect register in the entropy module (Teensy 4).
* Changed `DNSClient` to not ignore a zero timeout. This had caused a potential
use-after-scope.
* Added better checks in the driver output for any buffer copy errors.
* Now checking for NULL buffer arguments in `write()` of `EthernetUDP`
and `EthernetFrameClass`.
* Fixed `MDNSClass`:
* Ensure there's final NULs after copying some strings.
* Avoid undefined casting between `void*` and a function pointer.
* Added some NULL argument checking.
* `DNSClient` no longer ignores a timeout of zero. This was causing a potential
use-after-scope.
* Fixed the entropy module (Teensy 4) to not depend on a possibly stale `errno`.
* Clarified in the `EthernetServer` and `EthernetUDP` docs that the `beginXXX()`
functions are non-transactional in that they call `end()` or `stop()` first.
* Fixed connection and listener iteration to first take a snapshot of the lists
so that it's not possible to change the lists while iterating over them.
std::chrono-compatible ClockselapsedTime<Clock> utilityelapsedTime<Clock>LinkSettings and LinkInfo concepts that group all the link settings and informationqindesign::security::random_device mimics std::random_deviceint sizes to size_t sizesMDNS now uses std::string instead of String## [0.36.0]
### Added
* Added `elapsedTime::reset()` for resetting the timer back to zero.
* Added `rep` assignment operator and constructor to `elapsedTime` for assigning
a count.
* Added `elapsedTime` operators that use a count.
* Added a `settimeofday()` implementation in the HAL for Teensy, gated on the
new `QNETHERNET_PROVIDE_TEENSY_SETTIMEOFDAY` configuration macro.
* Added `qnethernet_hal_entropy_available()` function to the HAL.
* Added `operator(buf, size)` and `available()` to
`qindesign::security::random_device`.
* Added some basic entropy randomness quality tests.
* Added `QNETHERNET_ENABLE_RAW_FRAME_FILTER_HOOK` option for determining whether
to route incoming frames directly to the raw frame handling machinery.
(Thanks to Folkert van Heusden for helping with this:
<https://github.com/ssilverman/QNEthernet/issues/106#issuecomment-4619339870>)
### Changed
* Enabled raw frame loopback by default, but not raw frame support.
* Changed _SNTPClient_ example to assume that the `settimeofday()`
function exists.
* Changed entropy functions to set `errno` to `EIO` instead of `EAGAIN` on
entropy generation failure.
* Made the HAL's `qnethernet_hal_deinit_entropy()` and
`qnethernet_hal_estimate entropy()` weak.
* Improved entropy and `qindesign::security::random_device` APIs.
* Updated cppreference.com URLs.
* Moved driver C functions into namespace `qindesign::network::driver`.
* Moved entropy C functions into namespace `qindesign::entropy`.
* Changed `QNETHERNET_FLUSH_AFTER_WRITE` to `QNETHERNET_FLUSH_AFTER_TCP_WRITE`.
### Removed
* Removed `qindesign::security::RandomDevice` in favour of the
`std::random_device`-mimicking `qindesign::security::random_device`.
### Fixed
* Fixed the _ElapsedTime_ example to actually toggle the LED.
* Fixed Teensy 4.1 driver to clear the MAC address hash-collision bookkeeping
when the driver is uninitialized.
* Fixed TRNG (entropy) access for lower operating frequencies, on Teensy 4.
* Fixed to add some `errno` assignments and update some related comments
and docs.
* Fixed TRNG initialization to use the correct macros.
* Fixed raw frame loopback to pass along broadcast frames.
(Thanks to Folkert van Heusden:
<https://github.com/ssilverman/QNEthernet/issues/106#issuecomment-4639110163>)
* Fixed Teensy 4.1 driver to not overwrite output source MAC address.
<https://github.com/ssilverman/QNEthernet/issues/106#issuecomment-4638274539>)
* Fixed Teensy 4.1 driver to not calculate checksums when sending raw frames.
<https://github.com/ssilverman/QNEthernet/issues/106#issuecomment-4697867441>,
<https://github.com/ssilverman/QNEthernet/issues/106#issuecomment-4754025776>)
* Fixed Ping to calculate the ICMP checkum if needed.
RawFrameMonitor: In function 'void loop()':
RawFrameMonitor:119: error: 'EthernetFrame' was not declared in this scope
119 | int size = EthernetFrame.parseFrame();
Using library QNEthernet-master at version 0.37.0-snapshot in folder: /home/wwatson/Arduino/libraries/QNEthernet-master
Sorry, It was my fault I did not save the change. It's working ok now after saving "qnethernet_opts.h"@wwatson that's because support for raw frames is disabled by default. You can enable it by either adding the QNETHERNET_ENABLE_RAW_FRAME_SUPPORT=1 macro to the compiler options or by setting it to 1 in qnethernet_opts.h.
There are some good reasons right now why I'm doing it this way. One is code size, and the other is that if raw frames are enabled, then a few MAC accelerator functions are disabled for the Teensy 4.1 driver. Now, I know not all drivers necessarily care — some might — but I need to look at a few more things. I'm hesitant to enable features by default that I don't think most people use.
See also the notes at the top of the RawFrameMonitor example. (There's a mistake where it says the default is 'enabled'.)
## [0.37.0]
### Changed
* Moved chrono utilities to the `qindesign::chrono` namespace.
* Changed `MAIN_TEST_PROGRAM` to `QNETHERNET_MAIN_TEST_PROGRAM` to detect main
program inclusion.
* Now starting with MIB counters (RFC 2819) disabled.
* Updated the project to use registers and functions from the `imxrt1060-regs`
library, obviating the need for `imxrt.h`.
* Improved _SNTPClient_ example to retry sending SNTP requests until a response
is received
* Added `stratum < 16` check to _SNTPClient_ example and updated the
RFC reference.
### Fixed
* Fixed a `pbuf` copy error in `ByteBuffer::read(pbuf*)`.
* Fixed W5500 input processing to skip the rest of the frame if a `pbuf` could
not be allocated.
* Fixed `Ping` to use the current header size instead of a constant.
* Moved essential operations out of LWIP_ASSERT() statements because
LWIP_NOASSERT may be defined.
* Fixed W5500 driver `ETH_PAD_SIZE` handling.
* Fixed STM32 Arduino core 3.0.0 builds. Arduino classes are in the `arduino`
namespace; `Arduino.h` was included for this architecture.
Thanks, That explains why it it is not working with the your QNEthernet and teensy4_usbhost library. It compiles and uploads fine but fails to get the link up. The original FNet library still works...That is the AX88772B which is slightly different. I think they're up to model E or F now, which are completely different and use CDC-NCM.
Looks like it's out of stock.@jmarsh - Is that the same chip set used in the "Amazon Basics" used in this thread?:
https://forum.pjrc.com/index.php?threads/usb-host-ethernet-driver.57701/
I Still have mine to play with...
EDIT: Never mind, I found the README.md with the amazon link...
