I'm using the OpenAudio_ArduinoLibrary that I downloaded two days ago with the Arduino 2.1.1 IDE under Win 10. The Teensy patch is 1.58.1. I got the following error message:
In file included from C:\Users\User\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\OpenAudio_ArduinoLibrary\output_spdif3_f32.h:27,
from C:\Users\User\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\OpenAudio_ArduinoLibrary\output_spdif3_f32.cpp:28:
C:\Users\User\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\OpenAudio_ArduinoLibrary\AudioStream_F32.h:34:7: note: 'class audio_block_f32_t' declared here
34 | class audio_block_f32_t {
which I have never seen before. Has anyone else run into this? I'm assuming this is in the library code so others have probably seen it.
