Hi i have been playing with the Teensy for a while, i have a MIMXRT1064-evk as well as the one for the rt1176, I also play with the HUB75 panels and smartmatrix etc.
I wanted a board for my clock, that could drive a few more panels than the ESP32, so i'm building this.
So as i couldn't find the RT1062, i used a RT1064, put the parts on to drive the HUB75, an ESP32-S3 for the wifi, some PSRAM, and a co2,temp hum sensors..., i used the same pinouts as the teensy and added a JTAG header, also added an RGB led on both the esp32 and the RT1060, both USB's are pulled out and also usb for the ESP32, I've added the bootloader chip, but used 0R resistors to isolated it, i understand the bootloader chip won't work with this chip but there for the fun.., boards are ordered, as are the parts, so now the fun begins!!
So after testing this board, i think i will make a board using the RT1176 with SDRAM, same idea...
My question, has anyone got the RT1064 running with the teensy software (platformio-arduino), or do i need to carryon using Keil?
