New Teensy 4.1 DIY Synthesizer
No, with I2C the A7 and B7 pins cannot be used reliably as inputs. This is a known silicon bug in the MCP23017, the SPI version (MCP23S17) is OK though - so its 7 encoders per 23017, 8 per 23S17.
I only learned about this last year, after having helped design quite a few boards that use MCP23017 for 16 digital inputs. We aren't aware of ever having seen a problem, though. Do you have any insight into the conditions under which it might be a problem?
I'm using 3x MCP23017. Two for the 24 keys and one for seven encoders in the Jeannie.
The circuit diagram is not yet complete. An MCP23017 is still needed for the other buttons (24 in total) and the other 5 encoders.
No idea, it was and maybe still is a silicon bug, or it might have been fixed. The nice thing about the MCP23S17 is you can multiplex 8 on the same SPI bus with only one CS line, which makes it a no-brainer to chose SPI over I2C if its available, and thus avoid the bug entirely.
I'm not using CS handling for the query (I don't have any more free lines) and am using the interrupt signals from the MCP23017. As soon as an interrupt signal from an MCP23017 arrives at the Teensy, I read the 16-bit GPIO register and mask the active encoder. This way, I only need one 16bit read operation on the I2C bus.
I have set the resolution for the envelope controls to 0-255. Internally, the values are scaled up to exponential values of 0-11880ms for the audio envelopes using a formula.
C:
// calc expo value ---------------------------------------------
float calc_expo_value(byte value)
    float normalized = value / 255.0f;
    float exponent = 1.9; // Curve steepness
    float expoValue = pow(normalized, exponent);
    // scaled to 0-11880
    float finalValue = expoValue * 11880.0f; // scale value
    return finalValue;
// Ctrl Handle Group 0 -----------------------------------------
void Ctrl_Handle_Group_0 (uint16_t ctrl_No, byte value)
    if (ctrl_No == 20)
                envelope1.delay(calc_expo_value(value));
            else if (ctrl_No == 21)
                envelope1.attack(calc_expo_value(value));
            else if (ctrl_No == 22)
                envelope1.decay(calc_expo_value(value));
            else if (ctrl_No == 23)
                envelope1.sustain(0.00392f * value);
            else if (ctrl_No == 24)
                envelope1.release(calc_expo_value(value));
// GUI ctrl_handle ---------------------------------------------
void GUI_Ctrl_Handle (byte ctrl_groub, uint16_t ctrl_No, byte value)
    if (ctrl_groub == 0) // Envelopes
        Ctrl_Handle_Group_0(ctrl_No, value);
Superbooth in Berlin :)
I actually thought I had gone a bit overboard with Jeannie—three microcontrollers and 28 LEDs. But the Swedes can do even better :love::love::love::love:
A whopping twelve microcontrollers for 1,500 euros.
Link : https://www.apaeron.com/
In the interview, he states that seven microcontrollers are responsible for a total of 35 voices - thats five voices per microcontroller.
Jeannie 2 Audio Test with 12 Voices. I'm curious to see if the processor resources are sufficient for 12 filters (one filter per voice).
Yeah I meant per micro controller. Looks nice and great to see a group take it to that level
In my TeensyMIDIPolySynth (TMPS), I have implemented a 3-voice 12-poly synth. The audio portion runs on a T4.0 (overclocked at 816MHz with no additional cooling, hovering at or below about 50 degrees C & staying just under 95% loaded when all audio components are active). The display control/traditional 5-pin DIN MIDI/USBmidi/USHhostMIDI portion runs on a T4.1. The two Teensys communicate bidirectionally over a 500kbaud serial connection. Control/setting information flows both ways, as well as selective DEBUG information, between the Teensy processors.
Each of the three voices includes the following capability:
Each VFO is amplitude adjustable, and the waveform generation can be any mix (positive or negative, amplitude adjustable) of sine, duty controllable square, triangle, and saw oscillators, with +/- 3-octave selection/control, with individual tuning, plus overall gross tuning.
Each VFO can be modified by an LFO. Each LFO is frequency adjustable from 0-30Hz, depth adjustable (how much modulation is applied to the VFO), which can be any mix (positive or negative, amplitude adjustable) of sine, square, duty controllable pulse, triangle, and saw oscillators, S&H, or pink/white noise, and can be DC adjusted by +/- 1.0.
Each LFO is followed by an envelope generator, with adjustable delay, attack, hold, decay, sustain, and release.
Each modulated VFO is followed by an envelope generator, with adjustable delay, attack, hold, decay, sustain, and release.
Each LFO is followed by a filter than can be selectively enabled/disabled, and when enabled can be configured as LP, BP, HP, notch, with selectable number of octaves (how far the LFO sweeps the VFO), as well as adjustable resonance & bandwidth.
Each LFO filter can be modulated by an LFO that is frequency adjustable from 0-30Hz, depth adjustable (how much modulation is applied to the VFO), which can be any mix (positive or negative, amplitude adjustable) of sine, square, duty controllable pulse, triangle, and saw oscillators, S&H, or pink/white noise, and can be DC adjusted by +/- 1.0.
Each modulated VFO is followed by a filter than can be selectively enabled/disabled, and when enabled can be configured as LP, BP, HP, notch, with selectable number of octaves, as well as adjustable resonance & bandwidth.
Each of the three voices also includes an independent strings generator that can be frequency modulated by the same LFO modulating the VFO. The strings generator includes controls for octave selection and drive-level.
The TMPS includes independent white noise and pink noise generators that are mixed in at the top-most level (parallel to the modulated/filtered voices/notes). In addition, there is a simulated moog-style ladder filter that can be added after all of the voice generator objects in the audio processing chain. The ladder filter includes controls for knee freqency, resonance level, number of octaves, passband gain, overdrive, sweep time in milliseconds, beginning level, and ending level.
The TMPS also includes an SC reverb following the ladder filter, which includes controls for reverb percentage (wet/dry mix), duration, and damping.
The three voices are independently frequency tuneable, and the TMPS includes a master tuning control. There is a master amplifier volume control, as well as volume controls for each voice. Glissando/glide (of the last MIDI note input) is implemented as a software-generated linear frequency sweep algorithm.
Headphone volume and LINE OUT volume are independently adjustable. There is an on-screen CLIPPING indicator and an on-screen battery level monitor/indicator, as well as an on-screen clock. Real-time LED-style indication is displayed on-screen for MIDI note on / MIDI note off & MIDI control messages.
The TMPS includes a simple on-screen 1-key rollover keyboard, allowing the 12-poly capabilty to be exercised using an on-screen sustain pedal control, as well as on-screen pitch bend and mod wheel controls (these on-screen controls also follow any actual external hardware controls providing the same functionality, e.g. MIDI keyboard with pitch bend/mod wheel, and/or sustain pedal). All controls are implemented on the RA8875 800x480 touchscreen display as graphical buttons and sliders.
The TMPS has the ability to store & instantly recall up to 16 saves of all settings & parameters.
All of this capability is implemented in & comprised of 640 audio objects, with 1200 interconnection patch cords, all laid out using the standard Teensy Audio System Design Tool. If there's any question as to whether the Teensy is capable of running as a high-poly, multi-functional digital synthesizer, this is an actual case-in-point that proves, YES IT CAN !!
Mark J Culross
KD5RXT
P.S. Someday, I may actually get around to posting all of the design info, sources, PCB info, 3D-printed housing, etc. I just haven't made the time to do so yet. In the meantime, I'm extremely happy with the TMPS as an extremely capable, digitial musical synth, & I'm enjoying playing with it, as are several of my friends that I've given copies to as well. I haven't made any changes to the firmware in over a year, so it seems to be very stable at this point. MJC
Hallo..
In planning and testing: Jeannie_2, featuring 12 voices, a biquad filter with Low Pass, High Pass, Band Pass, Notch, Low Shelf, and High Shelf modes, and adjustable filter slope.
The two numbers above the envelope curve are the temperatures of the Audio MCU and the GUI CPU.
Small update..
The bargraph display and Voices LED are functional. The bargraph display on the screen shows the envelope contour of each individual voice. The LED display is coupled to the NoteOn and NoteOff signals and indicates the current voice allocation within the audio engine.
Hi there 🖐️
There was a minor issue with the PCM5102A DAC being used—the same one found in the Jeannie_1. When a sound decayed during the "Note Off" phase, a faint click could be heard at the very end (see the first image). The root cause lies in the automatic muting function built into the DAC chip. If the PCM5102A receives nothing but zero data at its digital input, it activates an analog mute after a few milliseconds. This results in a faint clicking sound at its output. I was able to resolve this issue via software by mixing in a small DC offset within the digital output mixer. As a result, the DAC continuously receives data and does not trigger its mute function.
Image 1: Clicking sound at the end of the release phase
Image 2: DC offset of (-1.0f/32786.0f) in the output mixer
Principle of the Digital Output Mixer with DC Offset
A quick update...
Jeannie_2 is now drawing some nice-looking filter curves :)
I still need to adjust the grid line relative to the cutoff frequency. The "12dB" button allows you to switch the filter from 24dB to 12dB, or vice versa.
Jeannie_2 filter curve
It has turned out that the Teensy Biquad filter is, unfortunately, not suitable for modulation. The filter produces clicking noises when the cutoff frequency is changed or modulated slowly.
I am now reverting to the proven StateVariable filter (LP/HP/BP) with a 12 dB slope from the Teensy Audio Library. When the resonance is increased (up to a maximum of 127.0f), the input signal is automatically attenuated slightly via an amplifier to limit the output level.
Hi there, and have a lovely Sunday! 😊
I’m currently working on the VCA and VCF structure for the Jeannie 2. The VCA and VCF envelopes feature both normal and inverted modes, which can be toggled using the "Invert" touch button on the envelope page.
Controlling the VCF envelope was straightforward. To generate an inverted VCF envelope, one simply switches the DC signal (dc3) at the VCF envelope's input from 1.0 to -1.0. Switching the VCA envelope from normal to inverted is somewhat more complex than doing so for the VCF envelope. The VCA utilizes a "Multiply" object from the Teensy Audio Library; the audio signal from the filter and the control signal from the VCA envelope are multiplied together to produce amplitude modulation—or "voltage-controlled amplification."
For standard VCA envelope control, it suffices to feed the filter output into the first input of the VCA multiplier and the VCA envelope's control signal into the second input. Unfortunately, simply switching the DC signal—as was done for the VCF envelope—does not work for an inverted VCA envelope. There are two issues involved here.
The first issue is that the VCA multiplier's inputs can only process values ranging from 0.0 to 1.0. However, an inverted envelope produces a control signal ranging from -1.0 to 0.0 at its output. To resolve this, I used a mixer (Inv-Mixer) to invert the envelope signal.
The second issue concerns NoteOff control. During the release phase of an inverted VCA envelope, the audio signal at the VCA output progressively increases to its maximum level. This problem can be solved using a second envelope (`vca_gate_env`). This envelope is configured with short attack and release times and is triggered when the VCA envelope is inactive (upon NoteOff), thereby cutting off the audio signal at the VCA multiplier.
One voice
Short test video... Some features are still missing from the filter menu and are under development.
The touchscreen cost me quite a bit of time and patience. The touchscreen driver library was blocking the MIDI data and couldn't be used. However, the Teensy forum provided excellent support, and now it's working perfectly. 😊
Touching the envelope curve isn't possible yet and is a bit tricky on the small 3.5" display. But it might be doable. I've implemented some basic things for now. The filter menu is still missing the function and display for LFO modulation and key tracking. Furthermore, I don't yet know if the Teensy4's processor resources are sufficient to handle 12 voices with a 24dB filter function (two state variable filters in series). But the biggest challenge is the oscillator engine with its many functions. These include sample playback, wavetable, VA, and much more...
