proud to be now also part of this forum.
And of course I have an issue I don`t know how to solve :/
I want to use the YIN frequency detection “notefreq” for my project.
The problem is that “notefreq” spits out a noise frequency of 83Hz (at CPU speed 48Mhz) even if it`s completely silence.
But let`s recapitulate...
My equipment:
Hardware
Teensy 3.2
Audioboard
Microphone
Software:
arduino-1.6.11-windows.exe
TeensyduinoInstall_1.30.exe
Firstly I have test “notefreq” algorithm which a lot of recordings. I transformed my wav files with wav2sketch and include it to the example NoteFrequency:
File > Examples > Audio > Analysis > NoteFrequency
It works fine.
Next step was to test the mic... video tutorial and documentation helped me:
https://www.youtube.com/watch?v=wqt55OAabVs
See Part 2-4: Using the Microphone
https://github.com/PaulStoffregen/AudioWorkshop2015/raw/master/workshop.pdf
Also until this point everything ok. Mic and output to my stereo works fine!
Next step:
Design of note frequency detection via mic.
At that point serial monitor gives me ca. 83Hz…
To understand the problem better I connect also the output (to stereo) to hear what happens.
Now I heard that noise which gets a little bit louder every time it prints out a new line to serial monitor. If I halve the CPU to 24Mhz the frequency duplicates to ca. 170Hz.
Has anyone else got this error before?
Maybe some elementary error in programming?
My equipment:
Hardware
Teensy 3.2
Audioboard
Microphone
Software:
It works fine.
// Advanced Microcontroller-based Audio Workshop
// https://github.com/PaulStoffregen/AudioWorkshop2015/raw/master/workshop.pdf
// https://hackaday.io/project/8292-microcontroller-audio-workshop-had-supercon-2015
// Part 2-4: Using The Microphone
#include <SerialFlash.h>
AudioInputI2S i2s2; //xy=64,105
AudioOutputI2S i2s3; //xy=301,212
AudioConnection patchCord1(i2s2, 0, i2s3, 0);
AudioConnection patchCord2(i2s2, 0, i2s3, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=203,275
AudioMemory(8);
sgtl5000_1.enable();
sgtl5000_1.volume(0.6);
sgtl5000_1.micGain(30);
// do nothing
Next step:
AudioInputI2S i2s1; //xy=246,135
AudioAnalyzeNoteFrequency notefreq1; //xy=623,182
AudioConnection patchCord1(i2s1, 0, notefreq1, 0);
AudioMemory(30);
* Initialize the yin algorithm's absolute
* threshold, this is good number.
notefreq1.begin(.15);
// pinMode(LED_BUILTIN, OUTPUT);
// read back fundamental frequency
if (notefreq1.available()) {
float note = notefreq1.read();
float prob = notefreq1.probability();
Serial.printf("Note: %3.2f | Probability: %.2f\n", note, prob);
AudioInputI2S i2s1; //xy=352,135
AudioAnalyzeNoteFrequency notefreq1; //xy=600,228
AudioOutputI2S i2s2; //xy=626,144
AudioConnection patchCord2(i2s1, 0, i2s2, 0);
AudioConnection patchCord3(i2s1, 0, i2s2, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=525,305
AudioMemory(30);
//pinMode(LED_BUILTIN, OUTPUT);
