Not receiving enough samples from microphone (ICS-52000)
eryvh
Hello everyone,
I’m currently working on a microphone array using 9 ICS-52000 microphones connected to a Teensy 4.1 via the TDM interface. Everything is functioning, and I’m able to capture data. However, I’m encountering an issue with the sampling rate. I aim to achieve 44.1kHz or 48kHz samples per second, but I'm only getting around 1000 samples per second.
I’m sending the data from the Teensy to a PC via the serial port for analysis in MATLAB.
Here’s a bit more detail:
  • I’m using an SCK frequency of 11.3MHz (BLCK)
  • Data is transferred to MATLAB for further analysis.
Program to get data from single microphone
This is how I'm receiving data from teensy to MatLab
Data from single microphone (on chart: y axis is digital signal)
Does anyone have suggestions on how I can increase the sampling rate to reach 44.1kHz or 48kHz? Any guidance would be much appreciated!
Thank you!
You're snippet for the Teensy code doesn't give enough information - perhaps just send the whole thing, or at least the variable declarations for all the variables involved and the code that sends data from the Teensy...
Why are you using a 9600 baud rate?
Teensy USB Serial always runs at full hardware speed the value in () doesn't get used: Serial.begin(9600);
Here's the file in "toolbar </>" code tags
#include <SerialFlash.h>
//TDM1
//Zasilanie mikrofonów 3,3V
//Pin 20 - FS - Output
//Pin 8 - SD - Input
//Pin 21 - BCLK - Output 11,3 MHz - SCK
//Pin 23 - MCLK - Outpit 22,6 MHz
//TDM2
//Pin 4 - BCLK - Output 11,3 MHz - SCK
//Pin 23 - MCLK - Output 22,6 MHz
//Pin 5 - SD - Input
//Pin 3 FS - Output
//Kod wygenerowany przy użyciu Audio System Design Tool
//TDM1
AudioInputTDM            tdm1;
AudioRecordQueue         queue1;
AudioRecordQueue         queue2;
AudioRecordQueue         queue3;
AudioRecordQueue         queue4;
AudioRecordQueue         queue5;
AudioRecordQueue         queue6;
AudioRecordQueue         queue7;
AudioRecordQueue         queue8;
AudioRecordQueue         queue9;
AudioRecordQueue         queue10;
AudioRecordQueue         queue11;
AudioRecordQueue         queue12;
AudioRecordQueue         queue13;
AudioRecordQueue         queue14;
AudioRecordQueue         queue15;
AudioRecordQueue         queue16;
//TDM2
AudioInputTDM2           tdm2_1;
AudioRecordQueue         queue17;
AudioRecordQueue         queue18;
//TDM1
AudioConnection          patchCord1(tdm1, 0, queue1, 0);
AudioConnection          patchCord2(tdm1, 1, queue2, 0);
AudioConnection          patchCord3(tdm1, 2, queue3, 0);
AudioConnection          patchCord4(tdm1, 3, queue4, 0);
AudioConnection          patchCord5(tdm1, 4, queue5, 0);
AudioConnection          patchCord6(tdm1, 5, queue6, 0);
AudioConnection          patchCord7(tdm1, 6, queue7, 0);
AudioConnection          patchCord8(tdm1, 7, queue8, 0);
AudioConnection          patchCord9(tdm1, 8, queue9, 0);
AudioConnection          patchCord10(tdm1, 9, queue10, 0);
AudioConnection          patchCord11(tdm1, 10, queue11, 0);
AudioConnection          patchCord12(tdm1, 11, queue12, 0);
AudioConnection          patchCord13(tdm1, 12, queue13, 0);
AudioConnection          patchCord14(tdm1, 13, queue14, 0);
AudioConnection          patchCord15(tdm1, 14, queue15, 0);
AudioConnection          patchCord16(tdm1, 15, queue16, 0);
//TDM2
AudioConnection          patchCord17(tdm2_1, 0, queue17, 0);
AudioConnection          patchCord18(tdm2_1, 1, queue18, 0);
//M1
int16_t* mic1A;
int16_t* mic1B;
//M2
int16_t* mic2A;
int16_t* mic2B;
//M3
int16_t* mic3A;
int16_t* mic3B;
//M4
int16_t* mic4A;
int16_t* mic4B;
//M5
int16_t* mic5A;
int16_t* mic5B;
//M6
int16_t* mic6A;
int16_t* mic6B;
//M7
int16_t* mic7A;
int16_t* mic7B;
//M8
int16_t* mic8A;
int16_t* mic8B;
//M9
int16_t*  mic9A;
int16_t*  mic9B;
bool f1;
bool f2;
bool f3;
bool f4;
bool f5;
bool f6;
bool f7;
bool f8;
bool f9;
bool newLine;
int finalSignal1;
int finalSignal2;
int finalSignal3;
int finalSignal4;
int finalSignal5;
int finalSignal6;
int finalSignal7;
int finalSignal8;
int finalSignal9;
  //Ustawienia
  AudioMemory(512);
  queue1.begin();
  queue2.begin();
  queue3.begin();
  queue4.begin();
  queue5.begin();
  queue6.begin();
  queue7.begin();
  queue8.begin();
  queue9.begin();
  queue10.begin();
  queue11.begin();
  queue12.begin();
  queue13.begin();
  queue14.begin();
  queue15.begin();
  queue16.begin();
  queue17.begin();
  queue18.begin();
  //Mikrofon 1
  if(queue1.available() > 0)
    mic1A = queue1.readBuffer();
    queue1.freeBuffer();
    f1 = true;
  if(queue2.available() > 0)
    mic1B = queue2.readBuffer();
    queue2.freeBuffer();
    if(f1) {
      finalSignal1 = mic1A[0]*256 + mic1B[0]/256;
  //Mikrofon 2
  if(queue3.available() > 0)
    mic2A = queue3.readBuffer();
    queue3.freeBuffer();
    f2 = true;
  if(queue4.available() > 0)
    mic2B = queue4.readBuffer();
    queue4.freeBuffer();
    if(f2)
      finalSignal2 = mic2A[0]*256 + mic2B[0]/256;
  //Mikrofon 3
  if(queue5.available() > 0)
    mic3A = queue5.readBuffer();
    queue5.freeBuffer();
    f3 = true;
  if(queue6.available() > 0)
    mic3B = queue6.readBuffer();
    queue6.freeBuffer();
    if(f3)
      finalSignal3 = mic3A[0]*256 + mic3B[0]/256;
  //Mikrofon 4
  if(queue7.available() > 0)
    mic4A = queue7.readBuffer();
    queue7.freeBuffer();
    f4 = true;
  if(queue8.available() > 0)
    mic4B = queue8.readBuffer();
    queue8.freeBuffer();
    if(f4)
      finalSignal4 = mic4A[0]*256 + mic4B[0]/256;
  //Mikrofon 5
  if(queue9.available() > 0)
    mic5A = queue9.readBuffer();
    queue9.freeBuffer();
    f5 = true;
  if(queue10.available() > 0)
    mic5B = queue10.readBuffer();
    queue10.freeBuffer();
    if(f5)
      finalSignal5 = mic5A[0]*256 + mic5B[0]/256;
  //Mikrofon 6
  if(queue11.available() > 0)
    mic6A = queue11.readBuffer();
    queue11.freeBuffer();
    f6 = true;
  if(queue12.available() > 0)
    mic6B = queue12.readBuffer();
    queue12.freeBuffer();
    if(f6)
      finalSignal6 = mic6A[0]*256 + mic6B[0]/256;
  //Mikrofon 7
  if(queue13.available() > 0)
    mic7A = queue13.readBuffer();
    queue13.freeBuffer();
    f7 = true;
  if(queue14.available() > 0)
    mic7B = queue14.readBuffer();
    queue14.freeBuffer();
    if(f7)
      finalSignal7 = mic7A[0]*256 + mic7B[0]/256;
  //Mikrofon 8
  if(queue15.available() > 0)
    mic8A = queue15.readBuffer();
    queue15.freeBuffer();
    f8 = true;
  if(queue16.available() > 0)
    mic8B = queue16.readBuffer();
    queue16.freeBuffer();
    if(f8)
      finalSignal8 = mic8A[0]*256 + mic8B[0]/256;
  //Mikrofon 8
  if(queue17.available() > 0)
    mic9A = queue17.readBuffer();
    queue17.freeBuffer();
    f9 = true;
  if(queue18.available() > 0)
    mic9B = queue18.readBuffer();
    queue18.freeBuffer();
    if(f9)
      finalSignal9 = mic9A[0]*256 + mic9B[0]/256;
  if(f1 && f2 && f3 && f4 && f5 && f6 && f7 && f8 && f9)
    Serial.print(finalSignal1);
    Serial.print(" ");
    Serial.print(finalSignal2);
    Serial.print(" ");
    Serial.print(finalSignal3);
    Serial.print(" ");
    Serial.print(finalSignal4);
    Serial.print(" ");
    Serial.print(finalSignal5);
    Serial.print(" ");
    Serial.print(finalSignal6);
    Serial.print(" ");
    Serial.print(finalSignal7);
    Serial.print(" ");
    Serial.print(finalSignal8);
    Serial.print(" ");
    Serial.print(finalSignal9);
    Serial.println(" "); //Nowy wiersz danych
    f1 = false;
    f2 = false;
    f3 = false;
    f4 = false;
    f5 = false;
    f6 = false;
    f7 = false;
    f8 = false;
    f9 = false;
  if(newLine) {
    newLine = false;
I meant 9600 baud here:
teensy = serialport("COM6", 9600);
Not sure if that could be a problem - why not use 115200 for instance?
