Hello.
I use this library wich is the best I found for teensy (Polling very usefull): https://github.com/vertigo-dk/BlackLED
11 universes works at 44fps with MadMapper.
I've got 2 problems:
Color order and value:
Channels of pixel are inverted: Channel1 is W, C2 is Blue, C3 is Green and C4 is Red but my void blink() init sequence works perfectly (RGBW in good order). I can remap this on MadMapper but i need to understand why.
When i fade one Channel Value, the corresponding color follows the value from 0 to 127 and at 128, the color is off and then follow the value from 128 to 255.
Seems that color only takes 7 bits of 8 bits value...
First Universe
I can't find the place to modify first Universe (my fixture is always from U0 to U11)
Here is my code:
Thanks.
First Universe
Here is my code:
// initial user defined settings
#define NUM_OF_OUTPUTS 4
#define MAX_NUM_LED_PER_OUTPUT 280
#define NUM_CHANNEL_PER_LED 4 // do not change this
//#define blackOnOpSyncTimeOut //recoment more than 20000 ms
//#define blackOnOpPollTimeOut //recoment more than 20000 ms
const static uint32_t OpSyncTimeOut = 300000;
const static uint32_t OpPollTimeOut = 30000;
// definitions calculated from user settings
const int num_channel_per_output = MAX_NUM_LED_PER_OUTPUT * NUM_CHANNEL_PER_LED;
const int num_universes_per_output = (num_channel_per_output%512) ? num_channel_per_output/512+1 : num_channel_per_output/512;
const int num_led_per_output = num_universes_per_output*512/NUM_CHANNEL_PER_LED;
const int num_artnet_ports = num_universes_per_output*NUM_OF_OUTPUTS;
// includes and lib
#include <Ethernet.h>
#include <ArtNode.h>
#include "ArtNetFrameExtension.h"
#include <OctoWS2811.h>
#include "TeensyMAC.h"
#include <EEPROM.h>
// settings error check
#if F_BUS < 60000000
#error "Teensy needs to run at 120MHz to read all packets in time"
// real code starts hear
#define VERSION_HI 0
#define VERSION_LO 9
#define PIN_RESET 9
EthernetUDP udp;
uint8_t udp_buffer[600];
boolean locateMode = 0;
// variables for the node.report
float tempVal = 0;
float fps = 0;
float avgUniUpdated = 0;
uint8_t numUniUpdated = 0;
unsigned long currentMillis = 0;
unsigned long previousMillis = 0;
uint32_t lastPoll = 0;
uint32_t lastSync = 0;
// octoWS2811
uint32_t dmxMemory[num_led_per_output * 8];
DMAMEM uint32_t displayMemory[num_led_per_output * 8];
uint32_t drawingMemory[num_led_per_output * 8];
const int LEDconfig = WS2811_GRBW | SK6812_820kHz;
OctoWS2811 LEDS(num_led_per_output, displayMemory, drawingMemory, LEDconfig);
// Art-Net config
ArtConfig config = {
{0xDE, 0xAD, 0xBE, 0x00, 0x00, 0x00}, // MAC - last 3 bytes set by Teensy
{2, 0, 0, 1}, // IP
{255, 0, 0, 0}, // Subnet mask
0x1936, // UDP port
false, // DHCP
// These fields get overwritten by loadConfig:
0, 0, // Net (0-127) and subnet (0-15)
"BlackLED_6", // Short name
"BlackLED_6_port", // Long name
num_artnet_ports, // Number of ports
{ PortTypeDmx | PortTypeOutput,
}, // Port types
{0, 0, 0, 0}, // Port input universes (0-15)
{0, 1, 2, 3}, // Port output universes (0-15)
VERSION_HI,
VERSION_LO
ArtNodeExtended node;
// artnetSend - takes a buffer pointer and its length
void artnetSend(byte* buffer, int length) {
udp.beginPacket(node.broadcastIP(), config.udpPort);
udp.write(buffer, length);
udp.endPacket();
// Blink test all the leds r,g,b,w
void blink() {
for (int i = 0 ; i < 8 * num_led_per_output ; i++)
LEDS.setPixel(i, 127, 0, 0, 0);
LEDS.show();
LEDS.setPixel(i, 0, 127, 0, 0);
LEDS.show();
LEDS.setPixel(i, 0, 0, 127,0);
LEDS.show();
LEDS.setPixel(i, 0, 0, 0, 127);
LEDS.show();
LEDS.setPixel(i, 0, 0, 0, 0);
LEDS.show();
// EEPROM setup
// ID of the settings block
#define CONFIG_VERSION "ls1"
// Tell it where to store your config data in EEPROM
#define CONFIG_MEM_START 16
#define CONFIG_START 17
#define CONFIG_END 2
int oemCode = 0x0000; // OemUnkown
// loadConfig - loads configurations from EEPROM
void loadConfig() {
// To make sure there are settings, and they are YOURS!
// If nothing is found it will use the default settings.
if (EEPROM.read(CONFIG_MEM_START + 0) == CONFIG_VERSION[0] &&
EEPROM.read(CONFIG_MEM_START + 1) == CONFIG_VERSION[1] &&
EEPROM.read(CONFIG_MEM_START + 2) == CONFIG_VERSION[2]) {
for (unsigned int t = CONFIG_START; t < sizeof(config) - CONFIG_END; t++) {
*((char*)&config + t ) = EEPROM.read(CONFIG_MEM_START + t + 3 - CONFIG_START);
// saveConfig - saves configurations to EEPROM
void saveConfig() {
EEPROM.write(CONFIG_MEM_START + 0, CONFIG_VERSION[0]);
EEPROM.write(CONFIG_MEM_START + 1, CONFIG_VERSION[1]);
EEPROM.write(CONFIG_MEM_START + 2, CONFIG_VERSION[2]);
EEPROM.write(CONFIG_MEM_START + t - CONFIG_START + 3, *((char*)&config + t));
// setup
//saveConfig(); //<-- uncomment to force the EEPROM config to your settings on eatch reboot
ArtConfig tempConfig = config;
loadConfig();
config.numPorts = tempConfig.numPorts;
config.verHi = tempConfig.verHi;
config.verLo = tempConfig.verLo;
saveConfig();
#ifdef PIN_RESET
pinMode(PIN_RESET, OUTPUT);
digitalWrite(PIN_RESET, LOW);
delayMicroseconds(2);
digitalWrite(PIN_RESET, HIGH);
delay(150);
// Read MAC address
mac_addr mac;
for (int i = 3; i < 6; i++) {
config.mac[i] = mac.m[i];
// Calculate IP address
config.ip[0] = 2;
config.ip[1] = config.mac[3] + (oemCode & 0xFF);// + ((oemCode >> 16) & 0xFF);
config.ip[2] = config.mac[4];
config.ip[3] = config.mac[5];
// Open Ethernet connection
IPAddress gateway(config.ip[0], 0, 0, 1);
IPAddress subnet(255, 0, 0, 0);
Ethernet.begin(config.mac, config.ip, gateway, gateway, subnet);
udp.begin(config.udpPort);
// Open ArtNet
node = ArtNodeExtended(config, sizeof(udp_buffer), udp_buffer);
LEDS.begin();
LEDS.show();
blink();
// to read internal temperature
analogReference(INTERNAL);
analogReadResolution(12);
// main loop
while (udp.parsePacket()) {
// First read the header to make sure it's Art-Net
unsigned int n = udp.read(udp_buffer, sizeof(ArtHeader));
if (n >= sizeof(ArtHeader)) {
ArtHeader* header = (ArtHeader*)udp_buffer;
// Check packet ID
if (memcmp(header->ID, "Art-Net", 8) == 0) { //is Art-Net
// Read the rest of the packet
udp.read(udp_buffer + sizeof(ArtHeader), udp.available());
// Package Op-Code determines type of packet
switch (header->OpCode) {
// Poll packet
case OpPoll: {
//T_ArtPoll* poll = (T_ArtPoll*)udp_buffer;
//if(poll->TalkToMe & 0x2){
#ifdef blackOnOpPollTimeOut
lastPoll = millis();
float tempCelsius = 25.0 + 0.17083 * (2454.19 - tempVal);
sprintf(node.pollReport, "numOuts;%d;numUniPOut;%d;temp;%.1f;fps;%.1f;uUniPF;%.1f;", NUM_OF_OUTPUTS, num_universes_per_output, tempCelsius, fps, avgUniUpdated);
node.createPollReply(); //create pollReply
artnetSend(udp_buffer, sizeof(ArtPollReply)); //send pollReply
// DMX packet
case OpDmx: {
ArtDmx* dmx = (ArtDmx*)udp_buffer;
int port = node.getAddress(dmx->SubUni, dmx->Net) - node.getStartAddress();
if (port >= 0 && port < config.numPorts) {
uint16_t portOffset = port * 512/NUM_CHANNEL_PER_LED;
//write the dmx data to the Octo frame buffer
uint32_t* dmxData = (uint32_t*) dmx->Data;
for (int i = 0; i < 128; i++) {
LEDS.setPixel(i + portOffset, dmxData[i]);
numUniUpdated++;
// OpSync
case 0x5200: {
LEDS.show();
#ifdef blackOnOpSyncTimeOut
lastSync = millis();
// calculate framerate
currentMillis = millis();
if(currentMillis > previousMillis){
fps = 1 / ((currentMillis - previousMillis) * 0.001);
fps = 0;
previousMillis = currentMillis;
// calculate average universes Updated
avgUniUpdated = numUniUpdated * 0.16 + avgUniUpdated * 0.84;
numUniUpdated = 0;
// OpAddress
case OpAddress: {
T_ArtAddress * address = (T_ArtAddress*)udp_buffer;
if (address->LongName[0] != 0) {
memcpy(config.longName, address->LongName, 64);
if (address->ShortName[0] != 0) {
memcpy(config.shortName, address->ShortName, 18);
if (address->NetSwitch != 0x7F) { // Use value 0x7f for no change.
if ((address->NetSwitch & 0x80) == 0x80) { // This value is ignored unless bit 7 is high. i.e. to program a value 0x07, send the value as 0x87.
config.net = address->NetSwitch & 0x7F;
if (address->SubSwitch != 0x7F) { // Use value 0x7f for no change.
if ((address->SubSwitch & 0x80) == 0x80) { // This value is ignored unless bit 7 is high. i.e. to program a value 0x07, send the value as 0x87.
config.subnet = address->SubSwitch & 0x7F;
for (int i = 0; i < 4; i++) {
if (address->SwIn[i] != 0x7F) {
if ((address->SwIn[i] & 0x80) == 0x80) {
config.portAddrIn[i] = address->SwIn[i] & 0x7F;
if (address->SwOut[i] != 0x7F) {
if ((address->SwOut[i] & 0x80) == 0x80) {
config.portAddrOut[i] = address->SwOut[i] & 0x7F;
if (address->Command == 0x04) {
locateMode = true;
locateMode = false;
saveConfig();
loadConfig();
//node.createExtendedPollReply();
//artnetSend(udp_buffer, node.sizeOfExtendedPollReply());
// Unhandled packet
default: {
// answer routine for Art-Net Extended
} else if (memcmp(header->ID, "Art-Ext", 8) == 0) {
// ArtNet Frame Extension
case OpPoll | 0x0001: {
}else if(memcmp(header->ID, "MadrixN", 8) == 0){
LEDS.show();
fps = 0;
numUniUpdated = 0;
// read temperature value
tempVal = analogRead(38) * 0.01 + tempVal * 0.99;
if (currentMillis - lastSync > OpSyncTimeOut) {
for (int i = 0; i < num_led_per_output * 8; i++) {
LEDS.setPixel(i, 0);
LEDS.show();
if (currentMillis - lastPoll > OpPollTimeOut) {
LEDS.show();
Thanks.
