I have been playing with a little project that is now needing a little more urgency.
With some testing I found that the octoWS2911 library gave the best results for a single strip of LEDs. The next stage of the project was to attach a basic LCD, which I did only to be greated with all sorts on the display.
Eventually realising what the issue maybe i moved the LCD connections around. While finding this out i found that the FastLED has a similar issue (it also crashed during my programme - I have yet to fully investigate why)
With that in mind is it possible to use the pins used for other LED strip for thing other than LED strips? I only have to add a rotary encoder so pin count should not be an issue, but I am curious.
I did not see anything specifically on using less than 8 strips.
This is running on a teensy 3.2, still very much a work in progress.
#include <OctoWS2811.h>
#include <LiquidCrystal.h>
//const int rs = 14, en = 15, d4 = 16, d5 = 17, d6 = 18, d7 = 19;
//const int rs = 12, en = 11, d4 = 10, d5 = 9, d6 = 8, d7 = 7;
const int rs = 10, en = 11, d4 = 18, d5 = 17, d6 = 16, d7 = 15;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
const int ledsPerStrip = 216; //one strip of 216
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 pixels(ledsPerStrip, displayMemory, drawingMemory, config);
//upper case R,G,B set the colour
uint16_t R = 255;
uint16_t B = 0;
uint16_t G = 0;
//lower case r,g,b is manipulated but the bright function and should not be manually
//these are to allow brightness control
byte r;
byte g;
byte b;
#define bright_var A9
byte Brightness = 65;
int new_bright = 0;
byte old_bright = 0;
int upHyst_bright = 0;
int loHyst_bright = 0;
uint16_t i = 0;
uint16_t j = 0;
byte q = 0;
byte bottom_ring = 0; //this is the only set of LED at are access in sequence
byte lower_riser[] = { 36, 99, 117, 152, 62, 80}; //six lower risers - 3 up, 3 down
byte middle_ring[] = { 45, 63, 108, 135}; //middle ring only has 4 address
byte upper_riser[] = {153, 126, 81, 207, 206, 98}; //six upper risers - 4 up, 2 down
byte top_ring[] = {162, 171, 180, 189}; //top ring only has 4 addresses
byte pattern_1[] = {1,21,2,20,3,19,4,18,5,17,6,16,7,15,8,14,9,13,10,12,11};
byte pattern_2[] = {11,10,12,9,13,8,14,7,15,6,16,5,17,4,18,3,19,2,20,1,21};
#define DELAYVAL 0
pinMode(bright_var, INPUT);
pinMode(rs, OUTPUT);
pinMode(en, OUTPUT);
pinMode(d4, OUTPUT);
pinMode(d5, OUTPUT);
pinMode(d6, OUTPUT);
pinMode(d7, OUTPUT);
Serial.println("Starting");
pixels.begin();
set_bright(); //use this to allow for brightness control instead of pixels.show()
lcd.begin(16,2);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Running");
//use this for smooth colour circle
for (j = 0; j < 255; j++){
for (byte i = 0; i < 22; i++){
Wheel((i+j) & 255);
set_Leds(i);
change_bright(); //see if brightness has been changed
set_bright(); //this contain pixels.show
//pixels.show(); //using pixels.show seem to cause issues - don't call this and LCD is fine
//call this and LCD show carbage and seem to overflow each line
//only when using pin in relation to octoWS2811 for LCD
//use this for brutal colour pattern - testing pattern arrays
for (i = 1; i < 22; i++){
q = pattern_2[i-1];
set_bright();
set_Leds(q);
delay(DELAYVAL);
if (R == 255){
R = 0;
B = 255;
}else if (B == 255){
B = 0;
G = 255;
}else{
G = 0;
R = 255;
if (R == 255){
R = 0;
B = 255;
B = 0;
G = 255;
}else{
G = 0;
R = 255;
void change_bright(){
new_bright = analogRead(bright_var);
if (new_bright < loHyst_bright || new_bright > upHyst_bright){
Serial.print("Brightness Changed: ");
Serial.println(new_bright);
Brightness = map(new_bright, 0, 1023, 10, 255);
lcd.setCursor(0,1);
lcd.print(" "); //clear small section of display
lcd.setCursor(0,1);
lcd.print(Brightness);
Serial.print("Brightness: ");
Serial.println(Brightness);
loHyst_bright = new_bright - 10;
upHyst_bright = new_bright + 10;
void set_Leds(byte No){
byte mode = 0;
if (No == 1) mode = 1;
if ((No >= 2) && (No <= 10)) mode = 2;
if (No == 11) mode = 3;
if ((No >= 12) && (No <= 20)) mode = 4;
if (No == 21) mode = 5;
switch(mode){
case 1 :
for(byte n=0; n<36; n++) {
pixels.setPixel(n,r,g,b);
case 2:
for (byte n = 0; n < 3; n++){
pixels.setPixel(lower_riser[n]-2+No,r,g,b);
for (byte n = 3; n < 6; n++){
pixels.setPixel(lower_riser[n]+2-No,r,g,b);
case 3:
for(byte n=0; n<9; n++){
pixels.setPixel(middle_ring[0]+n,r,g,b);
pixels.setPixel(middle_ring[1]+n,r,g,b);
pixels.setPixel(middle_ring[2]+n,r,g,b);
pixels.setPixel(middle_ring[3]+n,r,g,b);
case 4:
for (byte n = 0; n < 4; n++){
pixels.setPixel(upper_riser[n]-12+No,r,g,b);
for (byte n = 4; n < 6; n++){
pixels.setPixel(upper_riser[n]+12-No,r,g,b);
case 5:
for(int n=0; n<9; n++){
pixels.setPixel(top_ring[0]+n,r,g,b);
pixels.setPixel(top_ring[1]+n,r,g,b);
pixels.setPixel(top_ring[2]+n,r,g,b);
pixels.setPixel(top_ring[3]+n,r,g,b);
default:
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
R = 255 - WheelPos * 3;
G = 0;
B = WheelPos *3;
//set_bright();
return;
if(WheelPos < 170) {
WheelPos -= 85;
R = 0;
G = WheelPos * 3;
B = 255 - WheelPos * 3;
//set_bright();
return;
WheelPos -= 170;
R = WheelPos *3;
G = 255 - WheelPos * 3;
B = 0;
//set_bright();
return;
void set_bright() {
r = (R * Brightness) >> 8;
g = (G * Brightness) >> 8;
b = (B * Brightness) >> 8;
pixels.show();
