Hello,
Noticing a bit of issue with colors not being displayed correctly. Searches are coming up empty, and curious if anyone as any background on this. I've been able to reproduce from multiple machines, however lack to the toolchain to dig any deeper.
:: Problem ::
The top bit of each color channel appears to be masked off under later Arduino environments. (255 = 127) (128 = 0).
Below is my observations of running the Code snippet attached.Obviously the difference between Lime green and Very green is subjective however the important note is that the perceived green channel drops to zero as the value turns to 128.
[Arduino IDE 1.8.0 - teensyduino 1.35]
expected results are shown
A = 'Very Green'
B = 'Lime Green'
C = ''Lime Green'
D = 'Red'
[Arduino IDE 1.8.1 - teensyduino 1.35 ([and TD1.36)]
A = 'Lime Green'
B = 'Lime Green'
C = ''Red'
D = 'Red'
In the code example below (A,B) are equal and (C,D) are equal. this holds for R,G,B channels
:: Environment ::
Hardware: Teensy 3.2
Ledstrip: WS2812 5050 (sourced from adafruit)
Wiring: Stock teensy 3.2
Compiling Device: Windows 8.1
::Example::
Has anyone else been seeing this? I can roll back my environment for now, however would like to gain some more info on this so I can address it eventually.
Cheers,
Jazz
Note: Might be a distraction but this is also the boundary that The 'first pixel' issue (https://forum.pjrc.com/threads/43001-octo-basic-test-first-pixel) first appears for me.
:: Problem ::
A = 'Very Green'
B = 'Lime Green'
C = ''Lime Green'
D = 'Red'
A = 'Lime Green'
B = 'Lime Green'
C = ''Red'
D = 'Red'
:: Environment ::
::Example::
#include <OctoWS2811.h>
const int ledsPerStrip = 6;
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
leds.begin();
leds.show();
fill(leds.color(60,254,0)); // A
delay(2000);
fill(leds.color(60,127,0)); // B
delay(2000);
fill(leds.color(60,128,0)); // C
delay(2000);
fill(leds.color(60,0,0)); // D
delay(2000);
void fill(int color){
for (int i=0; i < leds.numPixels(); i++) {
leds.setPixel(i, color);
leds.show();
Cheers,
Jazz
