I am planning balcony lighting that can run programs on holidays and special occasions.
The total length to the balcony is 32' with 8 evenly spaced verticals that will each have a 1M (60 LED) WS8211 strip.
Power is on one side. I was thinking of running AC to a 5V 50A PS with big cable (Awg 6 or 8) running the 32' length and feeding the LED strips. I am budgeting 5A per strip which allows for overhead and changing to RGBW in the future.
Question 1: Is 32' considered a long run for either power or data? I can run the AC to the middle of the balcony and have two 16' power/data runs (left and right) but that will put the power and electronics enclosure in and unsightly place. I'd rather overcome the I/R drop with bigger wire if power was the only consideration. I worry that 32' might be too far for data. I am using shielded CAT6 cable.
Question 2: I would like to run RGBW since this is an architectural application and most of the time the program will be "solid, dim, lightly tinted warm white". What is the status of libraries that will enable a fourth LED?
Any advice will be much appreciated! Thanks.
Jeff
Jeff
