Oddities in Timing of SD Card writes
tarnerich
I'm experiencing occasional slow writes to an SD card which are going to interfere with the desired timing in a sensor logging project. It's doing fine on average but some writes are nearly 10X slower, and this seems to be tied to the granularity of the clusters in the Fat 32 formatted card (I used the official SD Formatter 4 from the SD card industry's web page). This shows the timing:
That first really tall peak happened during a line write that took me to 32,488 bytes of my text in the file. There may be some header info that bumps up the total amount of data beyond what I can read in a word processor. That's interestingly close to the cluster size of 32,768. There are smaller events at nearly regular sub-intervals too. When it's been running a while the pattern is strikingly fractal but the upper limit is in the low 200's as seen here. I can imagine that there is some system overhead involved with linking the sectors together in a large file.
There is a practical reason for my concern. My real project involves IMU sensor fusion in addition to the logging and I don't want to compromise either part if I can help it. It would be very cool if I could insure that each cycle would never take more than 50 milliseconds. I intend to trigger the sensor readings, processing, and logging at 50 msec usng an interval timer. There are 11 violations of that timing goal in the interval shown in the chart above. It's not the line of code that does the write that takes the time, it's the file closing. I tried another approach and got the same results: only open the file once, never close it, and use the flush() function to make the writes happen. Without either the close() or the flush(), the data never gets into the card. I'm using the standard SD library, and the Adafruit SD card breakout. Processor is the Teensy 3.1.
Here are some options I have:
1) Speed things up in some way that I don't yet know
2) Make the writes more consistent, in some way I don't know
3) Multitask: Delegate the SD logging to an additional Teensy 3.1 (the average time is around 30 msec) but it would need an input buffer of nearly 1K
4) Just accept it
I know how to do options 3 and 4, but options 1 or 2 would preferable. Thanks in advance for any suggestions that may be contributed.
Here is the representative sample code that demonstrates the issue:
// SD Card Stuff
File      logfile;
char      filename[13];
const int slaveSelectPin = 10;
char      SDline[300];
// Globals
long afterclose = 0;
long tstart;
* setup()
  pinMode(3, INPUT_PULLUP);
  // SD Card File Naming and Creation
  pinMode (slaveSelectPin, OUTPUT);
  if (!SD.begin(slaveSelectPin)) {
    Serial.println("Is an SD card in place?");
  // Construct a unique file name
  strcpy(filename, "SDCARD00.csv");  // So we know what's in the file when looking at the file list
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = '0' + i/10;
    filename[7] = '0' + i%10;
    if (! SD.exists(filename)) {    // create if does not exist, do not open existing, write, sync after write
  // Get ready to log
  logfile = SD.open(filename, FILE_WRITE);
  if(! logfile ) {
    Serial.println("Couldn't open the file on the SD card; stopping now.");
    while(1);  // might as well stop if we can't open the file for logging
  Serial.println(filename);  // If we got this far we were successful with the SD file.
  logfile.println("msec C, text1, text2, msec A, msec B");
  logfile.close();
* loop()
  tstart = millis();
  char ctmp[12];
  strcpy(SDline, "");   // start fresh each time
  itoa(int(afterclose), SDline, 10);  // Initiate the line with the "msec C" data obtained from the previous iteration of loop()
  strcat(SDline, ",");
  strcat(SDline, "a012345678901234567890123456789012345678901234567890123456789,");  // just some generic text to bring up the character count
  strcat(SDline, "b012345678901234567890123456789012345678901234567890123456789,");  // to simulate the sensor data and calculation results
  // msec A
  strcat(SDline, itoa(int(millis()-tstart), ctmp, 10));
  // msec B
  strcat(SDline, ",");      // Last item!
  logfile.println(SDline);  // Log it
  logfile.close();
  // msec C; this is where the timing variability occurs
  // THE FILE IS ALREADY CLOSED; we'll have to log it at the start of the next line
  afterclose = millis()-tstart;  //   we'll print it at the head of the next line, once we get into the next cycle of loop()
  • SD_Timing_Irregularity.ino
Excellent idea
Have you tried different brands of SD cards?
I have only one micro card on hand at the moment, a 4GB Kingston Class 4 which I selected entirely by price some time ago. I'll get a Sandisk or a Lexar to try next.
Would the the SD speed classes be relevant here... Class 2, 4, 6, 10, U1, U3, UHS-I, UHS-II? Each of my recording events are literally microscopic at only around 150 bytes each, fundamentally unlike the mainstream use model that the speed classes address.
Update: The Sandisk Ultra 16GB Micro SDHC Class 6 looks really good here:
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=2&t=4076
The Sandisk Extreme SDHC 8gb Class 10 (sounds like it should be faster) only managed about 1/8th of that speed for small writes.
Wow. SD speed ratings can truly mean less than nothing if you don't happen to be talking about camcorders.
Now I'm getting somewhere
Paul, thanks again for the suggestion to try a different card. It panned out really well and I think I found my solution.
This chart was collected by running the same code on a SanDisk 8GB HC-I Class 4. Keep in mind tha in both charts I have an added delay of 10 milliseconds in order to simulate the time needed to collect my sensor readings and process them. If I take out the added delay() statements, this SanDisk looks like it's about 5X faster than the Kingston. Both are Class 4.
If I am not mistaken, the speed class of SD cards, and most published speed benchmarks relate to accessing the card in 4-bit parallel "SDIO" mode which is what happens on a desktop or laptop PC. The one-bit SPI interface mode that most microcontrollers use can have quite different timing. I believe the occasionally slow performance has to do with housekeeping tasks that the SD card controller is doing in the background.
See also: http://forum.arduino.cc/index.php?P...2fun53fgfma0&topic=110533.msg830654#msg830654
I suggesting using Bill Greiman's sdfat library. http://code.google.com/p/sdfatlib/
Look at the Fast logging example, or something like that. Binary encoding can probably help too.
I doubt you'll need to do all that much after adapting the fast logging example, but I'll mention things that I can think sdfat does or things you could add.
1. format with sdfat library.
2. pre-allocate the file
3. write in exactly 512 byte blocks
4. Use a ring buffer
5. Use Interval Timer to check for a full 512 byte buffer, and write it to SDcard.
