Marathonman
Hello everyone,
I am currently working on an Duel H bridge solar tracker motor drive board. this is going to be a one stop solution having all components on one board with 12 and 24 volt capability @ 15a and 8a peak respectively. i wanted to use the Teensy 4.1 until i hit a tissy fight between the Teensy and the Texas Instruments UCC23514S.
according to the spec sheet on the Teensy it recommends a 4 ma max.
according to the Texas Instruments the UCC23514S has an recommended operating current of 7ma to 16ma.
Quote from Spec sheet;
"The forward voltage drop across the e-diode is 2.1V (typ). An external resistor should be used to limit the forward current. The recommended range for the forward current is 7mA to 16mA. When IF exceeds the threshold current IFLH(2.8mA typ.) a high frequency signal is transmitted across the isolation barrier through the high voltage SiO2 capacitors."
So i guess my question is do i dump the Teensy and get a piece of crap Arduino to hook up to the driver.
any solution would be appreciated.
Thanks in advance,
Marathonman
Thanks in advance,
Marathonman
