OTA for Teensy 4.0
Tanaji
Hello Team,
We have Teensy 4.0 running with an Android tablet application.
Tablet Application has an Android app, that controls (command/response) the Teensy 4.0.
Tablet Application and Teensy 4.0 are connected through Micro USB on Teensy side - USB C cable.
Tablet is connected to Internet.
We are exploring options to update Software on Teensy with OTA.
- Is it possible to download the Teensy 4.0 firmware on the Tablet and send it over USB to teensy 4.0?
Please let us know if anyone has insights. Thank you.
Regards,
Tanaji Nalawade
Hello Team,
Regards,
Tanaji Nalawade
Have a look at this.
@BriComp : Thank you for the information.
The update method is to transfer the new firmware to the Teensy via Serial (USB or UART).
We have USB: Raw HID; will it work with it, or do we need to 1st convert RAW HID to serial and the try it?
Yes, FlasherX can work with any method of transferring the new firmware to Teensy. The repository has examples for UART, serial USB, and SD, but it could also be SPI, I2C, Ethernet, etc. Regardless of the method of transfer, the concept is always the same.
1) Define/create a buffer in RAM, PSRAM, or unused Flash
2) Somehow transfer the new firmware to the buffer
3) Execute "move" function to automatically erase old firmware, write new firmware to flash, reboot
1. Downloaded and Installed FlasherX-main Library
Detecting libraries used...
C:\Users\110615\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_RAWHID -DLAYOUT_US_ENGLISH -IC:\Users\110615\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 C:\Users\110615\AppData\Local\arduino\sketches\178F50165B22C7EBD633C25B622ED029\sketch\V1_Final_v3.0.2_FWUpdate.ino.cpp -o nul
Alternatives for FXUtil.h: [FlasherX]
ResolveLibrary(FXUtil.h)
-> candidates: [FlasherX]
Compiling sketch...
IC:\\Users\\110615\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.59.0\\cores\\teensy4" "-Ic:\\Users\\110615\\OneDrive\\Documents\\Arduino\\libraries\\FlasherX" "C:\\Users\\110615\\AppData\\Local\\arduino\\sketches\\178F50165B22C7EBD633C25B622ED029\\sketch\\V1_Final_v3.0.2_FWUpdate.ino.cpp" -o "C:\\Users\\110615\\AppData\\Local\\arduino\\sketches\\178F50165B22C7EBD633C25B622ED029\\sketch\\V1_Final_v3.0.2_FWUpdate.ino.cpp.o"
C:\Users\110615\Downloads\V1_Final_v3.0.2_FWUpdate\V1_Final_v3.0.2_FWUpdate.ino:14:1: error: 'FlasherX' does not name a type
14 | FlasherX flasher(0x60000000); // Start of Teensy flash for app (QSPI)
C:\Users\110615\Downloads\V1_Final_v3.0.2_FWUpdate\V1_Final_v3.0.2_FWUpdate.ino: In function 'void FirmwareUpdate()':
C:\Users\110615\Downloads\V1_Final_v3.0.2_FWUpdate\V1_Final_v3.0.2_FWUpdate.ino:766:7: error: 'flasher' was not declared in this scope
766 | flasher.parseHexLine((const char*)buf);
C:\Users\110615\Downloads\V1_Final_v3.0.2_FWUpdate\V1_Final_v3.0.2_FWUpdate.ino:774:7: error: 'flasher' was not declared in this scope
774 | if (flasher.isComplete()) {
Using library FlasherX in folder: C:\Users\110615\OneDrive\Documents\Arduino\libraries\FlasherX (legacy)
exit status 1
Compilation error: 'FlasherX' does not name a type
Arduino by default generate .hex fir for Teensy.
Then, we have converted .elf file to .bin to send with FlasherX
  • Convert ELF → BIN (arm-none-eabi-objcopy -O binary).
  • Rebase flash addresses (for Teensy 4.1, 0x60000000) → .raw.bin.
  • Verify the vector table is at the start.
  • xxd -l 8 fota_poc_v1.ino.raw.bin
    • 00000000: 4643 4642 0000 0156 FCFB...V
command:
/Users/tanaji/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/arm-none-eabi-objcopy -I ihex fota_poc_v1.ino.hex -O binary fota_poc_v1.ino.hex.bin
FlasherX .bin isn’t working for OTA yet.
The first 4–8 bytes of current .bin show:
  • FCFB is the HalfKay signature Teensy prepends to .bin files for USB flashing.
  • This is not the actual vector table that the MCU expects at the start of flash for an OTA update.
