output_tdm.cpp Error
Dwayne
When verifying "Sample Player1.ino" (source below) using Arduino 1.8.9 I get the following error when Teensy Loader 1.4.6 begins loading:
--------------------------------Arduino IDE Command Output Display-------------------------------------------------------------------------------
/home/dwayne/arduino-1.8.9/hardware/teensy/avr/libraries/Audio/output_tdm.cpp: In static member function 'static void AudioOutputTDM::isr()':
/home/dwayne/arduino-1.8.9/hardware/teensy/avr/libraries/Audio/output_tdm.cpp:128:19: warning: variable 'dc' set but not used [-Wunused-but-set-variable]
uint32_t *dest, *dc;
---------------------------------------------End-------------------------------------------------------------------------------------------------------------
On reviewing output_tdm.cpp (source below) function 'static void AudioOutputTDM' it seems the braces are not correct for the if statement. I am no C++ expert, so I do not know if this is what is causing this error. The "SamplePlayer1.ino" compiled, and loaded successfully in the Teensy 3.2 card, but I do not know if it will work.
I am running Ubuntu 18.04.2. Any help on this would be appreciated, first time programming a Teensy.
Dwayne
-------------------Source Code-------------------------------------------------------
+++++++++++++++++++++++++++++++++++++++SamplePlayer1.ino+++++++++++++++++++++++++++++++++++++++
// WAV files converted to code by wav2sketch
#include "AudioSampleSnare.h"
#include "AudioSampleTomtom.h"
#include "AudioSampleHihat.h"
#include "AudioSampleKick.h"
#include "AudioSamplePianoff.h"
#include "AudioSampleClap.h"
#include "AudioSampleCleanbass.h"
#include "AudioSampleDub.h"
#include "AudioSampleDrum1.h"
#include "AudioSampleFf04.h"
#include "AudioSampleFf20.h"
#include "AudioSampleFf33.h"
#include "AudioSampleFf57.h"
#include "AudioSampleFf63.h"
// Create the Audio components.  These should be created in the
// order data flows, inputs/sources -> processing -> outputs
#include <SerialFlash.h>
#include <Bounce.h>
AudioControlSGTL5000     sgtl5000_1;
AudioPlayMemory    sound0;
AudioPlayMemory    sound1;  // six memory players, so we can play
AudioPlayMemory    sound2;  // all six sounds simultaneously
AudioPlayMemory    sound3;
AudioPlayMemory    sound4;
AudioPlayMemory    sound5;
AudioMixer4        mix1;    // two 4-channel mixers are needed in
AudioMixer4        mix2;    // tandem to combine 6 audio sources
AudioOutputI2S     headphones;
AudioOutputAnalog  dac;     // play to both I2S audio board and on-chip DAC
// Create Audio connections between the components
AudioConnection c1(sound0, 0, mix1, 0);
AudioConnection c2(sound1, 0, mix1, 1);
AudioConnection c3(sound2, 0, mix1, 2);
AudioConnection c4(sound3, 0, mix1, 3);
AudioConnection c5(mix1, 0, mix2, 0);   // output of mix1 into 1st input on mix2
AudioConnection c6(sound4, 0, mix2, 1);
AudioConnection c7(sound5, 0, mix2, 2);
AudioConnection c8(mix2, 0, headphones, 0);
AudioConnection c9(mix2, 0, headphones, 1);
AudioConnection c10(mix2, 0, dac, 0);
// Create an object to control the audio shield.
// Bounce objects to read six pushbuttons (pins 0-5)
Bounce button0 = Bounce(0, 5);
Bounce button1 = Bounce(1, 5);  // 5 ms debounce time
Bounce button2 = Bounce(2, 5);
Bounce button3 = Bounce(3, 5);
Bounce button4 = Bounce(4, 5);
Bounce button5 = Bounce(5, 5);
  // Configure the pushbutton pins for pullups.
  // Each button should connect from the pin to GND.
  pinMode(0, INPUT_PULLUP);
  pinMode(1, INPUT_PULLUP);
  pinMode(2, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(4, INPUT_PULLUP);
  pinMode(5, INPUT_PULLUP);
  // Audio connections require memory to work.  For more
  AudioMemory(10);
  // turn on the output
  audioShield.enable();
  audioShield.volume(1);
  // if your 3.3V power has noise, switching to the
  // internal 1.2V reference can give you a clean signal
  //dac.analogReference(INTERNAL);
  // reduce the gain on mixer channels, so more than 1
  // sound can play simultaneously without clipping
  mix1.gain(0, 0.5);
  mix1.gain(1, 0.5);
  mix1.gain(2, 0.5);
  mix1.gain(3, 0.5);
  mix2.gain(1, 0.5);
  mix2.gain(2, 0.5);
  // Update all the button objects
  button0.update();
  button1.update();
  button2.update();
  button3.update();
  button4.update();
  button5.update();
  // When the buttons are pressed, just start a sound playing.
  // The audio library will play each sound through the mixers
  // so any combination can play simultaneously.
  if (button0.fallingEdge()) {
    sound0.play(AudioSampleFf04);
  if (button1.fallingEdge()) {
    sound1.play(AudioSampleFf20);
  if (button2.fallingEdge()) {
    sound2.play(AudioSampleFf33);
  if (button3.fallingEdge()) {
    sound3.play(AudioSampleFf57);
  if (button4.fallingEdge()) {
    sound4.play(AudioSampleFf63);
  if (button5.fallingEdge()) {
    sound5.play(AudioSampleClap);
 // read the knob position (analog input A2)
  //int knob = analogRead(A2);
 // float vol = (float)knob / 1280.0;
 // sgtl5000_1.volume(vol);
++++++++++++++++++++++++++++++++++++++]+++++output_tdm.cpp+++++++++++++++++++++++++++++++++++++++++
/* Audio Library for Teensy 3.X
 * Copyright (c) 2017, Paul Stoffregen, [email]paul@pjrc.com[/email]
 * Development of this audio library was funded by PJRC.COM, LLC by sales of
 * Teensy and Audio Adaptor boards.  Please support PJRC's efforts to develop
 * open source software by purchasing Teensy or other PJRC products.
 * THE SOFTWARE.
#include <Arduino.h>
#include "output_tdm.h"
#include "memcpy_audio.h"
#include "utility/imxrt_hw.h"
audio_block_t * AudioOutputTDM::block_input[16] = {
	nullptr, nullptr, nullptr, nullptr, nullptr, nullptr, nullptr, nullptr,
bool AudioOutputTDM::update_responsibility = false;
DMAChannel AudioOutputTDM::dma(false);
DMAMEM __attribute__((aligned(32)))
static uint32_t zeros[AUDIO_BLOCK_SAMPLES/2];
static uint32_t tdm_tx_buffer[AUDIO_BLOCK_SAMPLES*16];
void AudioOutputTDM::begin(void)
	dma.begin(true); // Allocate the DMA channel first
	for (int i=0; i < 16; i++) {
		block_input[i] = nullptr;
	// TODO: should we set & clear the I2S_TCSR_SR bit here?
	config_tdm();
#if defined(KINETISK)
	CORE_PIN22_CONFIG = PORT_PCR_MUX(6); // pin 22, PTC1, I2S0_TXD0
	dma.TCD->SADDR = tdm_tx_buffer;
	dma.TCD->SOFF = 4;
	dma.TCD->ATTR = DMA_TCD_ATTR_SSIZE(2) | DMA_TCD_ATTR_DSIZE(2);
	dma.TCD->NBYTES_MLNO = 4;
	dma.TCD->SLAST = -sizeof(tdm_tx_buffer);
	dma.TCD->DADDR = &I2S0_TDR0;
	dma.TCD->DOFF = 0;
	dma.TCD->CITER_ELINKNO = sizeof(tdm_tx_buffer) / 4;
	dma.TCD->DLASTSGA = 0;
	dma.TCD->BITER_ELINKNO = sizeof(tdm_tx_buffer) / 4;
	dma.TCD->CSR = DMA_TCD_CSR_INTHALF | DMA_TCD_CSR_INTMAJOR;
	dma.triggerAtHardwareEvent(DMAMUX_SOURCE_I2S0_TX);
	update_responsibility = update_setup();
	dma.enable();
	I2S0_TCSR = I2S_TCSR_SR;
	I2S0_TCSR = I2S_TCSR_TE | I2S_TCSR_BCE | I2S_TCSR_FRDE;
#elif defined(__IMXRT1052__) || defined(__IMXRT1062__)
	CORE_PIN6_CONFIG  = 3;  //1:TX_DATA0
	dma.TCD->SOFF = 4;
	dma.TCD->DADDR = &I2S1_TDR0;
	dma.TCD->DOFF = 0;
	dma.triggerAtHardwareEvent(DMAMUX_SOURCE_SAI1_TX);
	dma.enable();
	I2S1_RCSR |= I2S_RCSR_RE;
	I2S1_TCSR |= I2S_TCSR_TE | I2S_TCSR_BCE | I2S_TCSR_FRDE;
	dma.attachInterrupt(isr);
// TODO: needs optimization...
static void memcpy_tdm_tx(uint32_t *dest, const uint32_t *src1, const uint32_t *src2)
	uint32_t i, in1, in2, out1, out2;
	for (i=0; i < AUDIO_BLOCK_SAMPLES/4; i++) {
		in1 = *src1++;
		in2 = *src2++;
		out1 = (in1 << 16) | (in2 & 0xFFFF);
		out2 = (in1 & 0xFFFF0000) | (in2 >> 16);
		*dest = out1;
		*(dest + 8) = out2;
		in1 = *src1++;
		in2 = *src2++;
		*(dest + 16)= out1;
		*(dest + 24) = out2;
		dest += 32;
void AudioOutputTDM::isr(void)
	const uint32_t *src1, *src2;
	uint32_t i, saddr;
	saddr = (uint32_t)(dma.TCD->SADDR);
	dma.clearInterrupt();
	if (saddr < (uint32_t)tdm_tx_buffer + sizeof(tdm_tx_buffer) / 2) {
		// DMA is transmitting the first half of the buffer
		// so we must fill the second half
		dest = tdm_tx_buffer + AUDIO_BLOCK_SAMPLES*8;
		// DMA is transmitting the second half of the buffer
		// so we must fill the first half
		dest = tdm_tx_buffer;
	if (update_responsibility) AudioStream::update_all();
	dc = dest;
	for (i=0; i < 16; i += 2) {
		src1 = block_input[i] ? (uint32_t *)(block_input[i]->data) : zeros;
		src2 = block_input[i+1] ? (uint32_t *)(block_input[i+1]->data) : zeros;
		memcpy_tdm_tx(dest, src1, src2);
		dest++;
	#if IMXRT_CACHE_ENABLED >= 2
	arm_dcache_flush_delete(dc, sizeof(tdm_tx_buffer) / 2 );
	for (i=0; i < 16; i++) {
		if (block_input[i]) {
			release(block_input[i]);
void AudioOutputTDM::update(void)
	audio_block_t *prev[16];
	unsigned int i;
	__disable_irq();
		prev[i] = block_input[i];
		block_input[i] = receiveReadOnly(i);
	__enable_irq();
		if (prev[i]) release(prev[i]);
// MCLK needs to be 48e6 / 1088 * 512 = 22.588235 MHz -> 44.117647 kHz sample rate
#if F_CPU == 96000000 || F_CPU == 48000000 || F_CPU == 24000000
  // PLL is at 96 MHz in these modes
  #define MCLK_MULT 4
  #define MCLK_DIV  17
#elif F_CPU == 72000000
  #define MCLK_MULT 16
  #define MCLK_DIV  51
#elif F_CPU == 120000000
  #define MCLK_DIV  85
#elif F_CPU == 144000000
  #define MCLK_MULT 8
  #define MCLK_DIV  51
#elif F_CPU == 168000000
  #define MCLK_DIV  119
#elif F_CPU == 180000000
  #define MCLK_MULT 32
  #define MCLK_DIV  255
  #define MCLK_SRC  0
#elif F_CPU == 192000000
  #define MCLK_MULT 2
  #define MCLK_DIV  17
#elif F_CPU == 216000000
  #define MCLK_DIV  153
  #define MCLK_SRC  0
#elif F_CPU == 240000000
  #define MCLK_MULT 8
  #define MCLK_DIV  85
#else
  #error "This CPU Clock Speed is not supported by the Audio library";
#ifndef MCLK_SRC
#if F_CPU >= 20000000
  #define MCLK_SRC  3  // the PLL
#else
  #define MCLK_SRC  0  // system clock
void AudioOutputTDM::config_tdm(void)
	SIM_SCGC6 |= SIM_SCGC6_I2S;
	SIM_SCGC7 |= SIM_SCGC7_DMA;
	SIM_SCGC6 |= SIM_SCGC6_DMAMUX;
	// if either transmitter or receiver is enabled, do nothing
	if (I2S0_TCSR & I2S_TCSR_TE) return;
	if (I2S0_RCSR & I2S_RCSR_RE) return;
	// enable MCLK output
	I2S0_MCR = I2S_MCR_MICS(MCLK_SRC) | I2S_MCR_MOE;
	while (I2S0_MCR & I2S_MCR_DUF) ;
	I2S0_MDR = I2S_MDR_FRACT((MCLK_MULT-1)) | I2S_MDR_DIVIDE((MCLK_DIV-1));
	// configure transmitter
	I2S0_TMR = 0;
	I2S0_TCR1 = I2S_TCR1_TFW(4);
	I2S0_TCR2 = I2S_TCR2_SYNC(0) | I2S_TCR2_BCP | I2S_TCR2_MSEL(1)
		| I2S_TCR2_BCD | I2S_TCR2_DIV(0);
	I2S0_TCR3 = I2S_TCR3_TCE;
	I2S0_TCR4 = I2S_TCR4_FRSZ(7) | I2S_TCR4_SYWD(0) | I2S_TCR4_MF
		| I2S_TCR4_FSE | I2S_TCR4_FSD;
	I2S0_TCR5 = I2S_TCR5_WNW(31) | I2S_TCR5_W0W(31) | I2S_TCR5_FBT(31);
	// configure receiver (sync'd to transmitter clocks)
	I2S0_RMR = 0;
	I2S0_RCR1 = I2S_RCR1_RFW(4);
	I2S0_RCR2 = I2S_RCR2_SYNC(1) | I2S_TCR2_BCP | I2S_RCR2_MSEL(1)
		| I2S_RCR2_BCD | I2S_RCR2_DIV(0);
	I2S0_RCR3 = I2S_RCR3_RCE;
	I2S0_RCR4 = I2S_RCR4_FRSZ(7) | I2S_RCR4_SYWD(0) | I2S_RCR4_MF
		| I2S_RCR4_FSE | I2S_RCR4_FSD;
	I2S0_RCR5 = I2S_RCR5_WNW(31) | I2S_RCR5_W0W(31) | I2S_RCR5_FBT(31);
	// configure pin mux for 3 clock signals
	CORE_PIN23_CONFIG = PORT_PCR_MUX(6); // pin 23, PTC2, I2S0_TX_FS (LRCLK) - 44.1kHz
	CORE_PIN9_CONFIG  = PORT_PCR_MUX(6); // pin  9, PTC3, I2S0_TX_BCLK  - 11.2 MHz
	CORE_PIN11_CONFIG = PORT_PCR_MUX(6); // pin 11, PTC6, I2S0_MCLK - 22.5 MHz
	CCM_CCGR5 |= CCM_CCGR5_SAI1(CCM_CCGR_ON);
//PLL:
	int fs = AUDIO_SAMPLE_RATE_EXACT;
	// PLL between 27*24 = 648MHz und 54*24=1296MHz
	int n1 = 4; //SAI prescaler 4 => (n1*n2) = multiple of 4
	int n2 = 1 + (24000000 * 27) / (fs * 256 * n1);
	double C = ((double)fs * 256 * n1 * n2) / 24000000;
	int c0 = C;
	int c2 = 10000;
	int c1 = C * c2 - (c0 * c2);
	set_audioClock(c0, c1, c2);
	// clear SAI1_CLK register locations
	CCM_CSCMR1 = (CCM_CSCMR1 & ~(CCM_CSCMR1_SAI1_CLK_SEL_MASK))
		   | CCM_CSCMR1_SAI1_CLK_SEL(2); // &0x03 // (0,1,2): PLL3PFD0, PLL5, PLL4
	n1 = n1 / 2; //Double Speed for TDM
		   | CCM_CS1CDR_SAI1_CLK_PRED(n1-1) // &0x07
		   | CCM_CS1CDR_SAI1_CLK_PODF(n2-1); // &0x3f
	IOMUXC_GPR_GPR1 = (IOMUXC_GPR_GPR1 & ~(IOMUXC_GPR_GPR1_SAI1_MCLK1_SEL_MASK))
			| (IOMUXC_GPR_GPR1_SAI1_MCLK_DIR | IOMUXC_GPR_GPR1_SAI1_MCLK1_SEL(0));	//Select MCLK
	if (I2S1_TCSR & I2S_TCSR_TE) return;
	if (I2S1_RCSR & I2S_RCSR_RE) return;
	int rsync = 0;
	int tsync = 1;
	I2S1_TMR = 0;
	I2S1_TCR1 = I2S_TCR1_RFW(4);
	I2S1_TCR2 = I2S_TCR2_SYNC(tsync) | I2S_TCR2_BCP | I2S_TCR2_MSEL(1)
	I2S1_TCR3 = I2S_TCR3_TCE;
	I2S1_TCR4 = I2S_TCR4_FRSZ(7) | I2S_TCR4_SYWD(0) | I2S_TCR4_MF
	I2S1_TCR5 = I2S_TCR5_WNW(31) | I2S_TCR5_W0W(31) | I2S_TCR5_FBT(31);
	I2S1_RMR = 0;
	I2S1_RCR1 = I2S_RCR1_RFW(4);
	I2S1_RCR2 = I2S_RCR2_SYNC(rsync) | I2S_TCR2_BCP | I2S_RCR2_MSEL(1)
	I2S1_RCR3 = I2S_RCR3_RCE;
	I2S1_RCR4 = I2S_RCR4_FRSZ(7) | I2S_RCR4_SYWD(0) | I2S_RCR4_MF
	I2S1_RCR5 = I2S_RCR5_WNW(31) | I2S_RCR5_W0W(31) | I2S_RCR5_FBT(31);
	CORE_PIN23_CONFIG = 3;  //1:MCLK
	CORE_PIN21_CONFIG = 3;  //1:RX_BCLK
	CORE_PIN20_CONFIG = 3;  //1:RX_SYNC
This is just a nuisance warning in the case where the Teensy at hand doesn't have this cache support because the code wasn't cluttered with another #if or two to make that variable creation/assignment similarly #if conditional, but the original unchanged value of 'dest' is required.
The 'dc' unused is conditional based on the #if at compile time:
	[COLOR="#FF0000"]dc = dest;[/COLOR]
		dest++;
	[COLOR="#FF0000"]#if IMXRT_CACHE_ENABLED >= 2[/COLOR]
	arm_dcache_flush_delete([B][COLOR="#FF0000"]dc[/COLOR][/B], sizeof(tdm_tx_buffer) / 2 );
In the case this is running on a processor with 'cache' the memory at cd=dest seems to needed to be flushed from the cache to ensure the 'current' data is presented for later use.
Good to know it does work.
This version of the isr() should avoid that warning and work the same - if you can SWAP it in and confirm I can put in a PULL request to change the code:
	uint32_t *dest;
	uint32_t i, saddr;
	uint32_t *dc = dest;
		dest++;
That code compiled for T4 when the sample.wav's were excluded - then I see this:
T:\Ard186t4b2\hardware\teensy\avr\libraries\Audio\output_i2s2.cpp:75:18: warning: unused variable 'dc' [-Wunused-variable]
  int16_t *dest, *dc;
That one is simpler as the dc is never used … just :: int16_t *dest;
