I'm trying to use an encoder knob on pins 4 and 5, as well as an I2C OLED on pins 18 and 19. If I have the display in the code, pin 4 is pulled high and overpowers the 10k series resistor I have going to the signal from the knob. What causes this? Is it possible to fix this behavior? What other pins might be affected by this that I haven't ran into yet?
Below is code that demonstrates the issue, cobbled together from example files and the project where I found this.
C-like:
#include "QuadEncoder.h"
// Supported pins: 0, 1, 2, 3, 4, 5, 7, 8, 30, 31, 33, 36, 37
#define KNOB_CLK 4
#define KNOB_DT 5
#define KNOB_PULLUPS 0 // Onboard knob PCB, don't need
#define KNOB_PPR 20
// Display
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define W 6
#define H 8
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define I2C_SDA 18 // Teensy 4.1
#define I2C_SCL 19 // Teensy 4.1
QuadEncoder knob(2, KNOB_CLK, KNOB_DT, KNOB_PULLUPS);
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> Can1; // CAN1
// Setup display
Wire.setSDA(I2C_SDA); // Teensy 4.1
Wire.setSCL(I2C_SCL); // Teensy 4.1
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;)
; // Don't proceed, loop forever
display.ssd1306_command(SSD1306_SETCONTRAST); // 0x81
display.ssd1306_command(0x01);
display.clearDisplay();
display.setTextSize(0); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_WHITE); // Draw white text with black backgroud - changes a character
display.cp437(true); // Use real 256 char 'Code Page 437' font
display.setTextWrap(false);
display.setTextSize(2);
display.setCursor(0, 0);
display.print("Loading...");
display.display();
Serial.println("Knob Encoder Test:");
Wire.setSDA(18); // Teensy 4.1
Wire.setSCL(19); // Teensy 4.1
Wire.begin();
knob.setInitConfig();
//Optional filter setup
knob.EncConfig.filterCount = 5;
knob.EncConfig.filterSamplePeriod = 255;
knob.init();
long position = -999;
long newPos;
newPos = knob.read();
if (newPos != position) {
Serial.print("Knob = ");
Serial.print(newPos);
position = newPos;
// if a character is sent from the serial monitor,
// reset both back to zero.
if (Serial.available()) {
Serial.read();
Serial.println("Reset knob to zero");
knob.write(0);
