Hello KurtE, managed to get my screen running after putting sck on the wrong pin and scratching my head for about two hours. It seems very fast. I noticed that rotation only works for 0 and 2, do you know when you will be able to fix the other 2 rotation settings?
#include <ili9341_t3n_font_Arial.h>
#include <ili9341_t3n_font_ArialBold.h>
#include <ILI9341_t3n.h>
#define ROTATION 3
#include "SPI.h"
#define KURTS_FLEXI
#ifdef KURTS_FLEXI
#define TFT_DC 22
#define TFT_CS 15
#define TFT_RST -1
#define TFT_SCK 14
#define TFT_MISO 12
#define TFT_MOSI 7
#define DEBUG_PIN 13
#else
#define TFT_DC 9
#define TFT_CS 10
#define TFT_RST 7
#define TFT_SCK 13
#define TFT_MISO 12
#define TFT_MOSI 11
ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCK, TFT_MISO, &SPIN);
Adafruit_GFX_Button button;
uint8_t use_dma = 0;
uint8_t use_clip_rect = 0;
uint8_t use_set_origin = 0;
uint8_t use_fb = 0;
#define ORIGIN_TEST_X 50
#define ORIGIN_TEST_Y 50
while (!Serial && (millis() < 4000)) ;
tft.begin();
tft.setRotation(ROTATION);
// read diagnostics (optional but can help debug problems)
uint8_t x = tft.readcommand8(ILI9341_RDMODE);
Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDMADCTL);
Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDPIXFMT);
Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDIMGFMT);
Serial.print("Image Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDSELFDIAG);
Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
#ifdef DEBUG_PIN
pinMode(DEBUG_PIN, OUTPUT);
button.initButton(&tft, 200, 125, 100, 40, ILI9341_GREEN, ILI9341_YELLOW, ILI9341_RED, "UP", 1);
drawTestScreen();
void SetupOrClearClipRectAndOffsets() {
if (use_clip_rect) {
tft.setClipRect(); // make sure we clear the whole screen
tft.setOrigin(); // make sure none are set yet
tft.fillScreen(ILI9341_LIGHTGREY);
// Now lets set origin.
if (use_set_origin)
tft.setOrigin(ORIGIN_TEST_X, ORIGIN_TEST_Y);
int x = tft.width() / 4;
int y = tft.height() / 4;
int w = tft.width() / 2;
int h = tft.height() / 2;
tft.drawRect(x, y, w, h, ILI9341_ORANGE);
tft.updateScreen();
tft.setClipRect(x + 1, y + 1, w - 2, h - 2);
delay(250);
tft.setClipRect();
if (use_set_origin)
tft.setOrigin();
uint16_t palette[256]; // Should probably be 256, but I don't use many colors...
uint16_t pixel_data[2500];
const uint8_t pict1bpp[] = {0xff, 0xff, 0xc0, 0x03, 0xa0, 0x05, 0x90, 0x9, 0x88, 0x11, 0x84, 0x21, 0x82, 0x41, 0x81, 0x81,
0x81, 0x81, 0x82, 0x41, 0x84, 0x21, 0x88, 0x11, 0x90, 0x09, 0xa0, 0x05, 0xc0, 0x03, 0xff, 0xff
const uint8_t pict2bpp[] = {
0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff,
0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00,
0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55,
0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa,
const uint8_t pict4bpp[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x00,
0x00, 0x11, 0x22, 0x22, 0x22, 0x22, 0x11, 0x00,
0x00, 0x11, 0x22, 0x33, 0x33, 0x22, 0x11, 0x00,
void drawTestScreen() {
Serial.printf("Use FB: %d ", use_fb); Serial.flush();
tft.useFrameBuffer(use_fb);
SetupOrClearClipRectAndOffsets();
uint32_t start_time = millis();
tft.fillScreen(use_fb ? ILI9341_RED : ILI9341_BLACK);
//tft.setFont(Inconsolata_60);
tft.setFont(Arial_24_Bold);
tft.setTextColor(ILI9341_WHITE);
tft.setCursor(0, 0);
tft.println("Test");
tft.setTextColor(ILI9341_WHITE, ILI9341_RED);
tft.println("text");
tft.setCursor(85, 65);
tft.print("XYZ");
tft.setFontAdafruit();
tft.setTextSize(2);
tft.println("01234");
tft.setTextColor(ILI9341_WHITE, ILI9341_GREEN);
tft.println("56789!@#$%");
tft.drawRect(0, 150, 100, 50, ILI9341_WHITE);
tft.drawLine(0, 150, 100, 50, ILI9341_GREEN);
tft.fillRectVGradient(125, 150, 50, 50, ILI9341_GREEN, ILI9341_YELLOW);
tft.fillRectHGradient(200, 150, 50, 50, ILI9341_YELLOW, ILI9341_GREEN);
// Try a read rect and write rect
#ifdef DEBUG_PIN
digitalWrite(DEBUG_PIN, HIGH);
tft.readRect(0, 0, 50, 50, pixel_data);
#ifdef DEBUG_PIN
digitalWrite(DEBUG_PIN, LOW);
tft.writeRect(250, 0, 50, 50, pixel_data);
// Lets try to pack this rectangle of data into 8 byte
tft.readRect(85, 65, 50, 50, pixel_data);
uint16_t *ppd16 = pixel_data;
uint8_t *ppd8 = (uint8_t*)pixel_data;
uint8_t palette_cnt = 0;
int palette_index;
for (int i = 0; i < 2500; i++) {
for (palette_index = 0; palette_index < palette_cnt; palette_index++) {
if (*ppd16 == palette[palette_index])
if (palette_index >= palette_cnt) {
palette[palette_cnt++] = *ppd16; // save away the color
*ppd8++ = palette_index;
ppd16++;
tft.writeRect8BPP(200, 50, 50, 50, (uint8_t*)pixel_data, palette);
palette[0] = ILI9341_CYAN;
palette[1] = ILI9341_OLIVE;
tft.writeRect1BPP(75, 100, 16, 16, pict1bpp, palette);
tft.writeRect1BPP(320-90, 75, 16, 16, pict1bpp, palette);
palette[2] = ILI9341_MAROON;
palette[3] = ILI9341_PINK;
tft.writeRect2BPP(75, 125, 32, 16, pict2bpp, palette);
tft.writeRectNBPP(15, 125, 32, 16, 2, pict2bpp, palette);
tft.writeRectNBPP(75, 150, 16, 16, 4, pict4bpp, palette);
// Try drawing button
button.drawButton();
if (use_dma) {
tft.startUpdateScreenDMA();
tft.updateScreen();
Serial.println(millis() - start_time, DEC);
if (use_dma && use_fb) {
Serial.printf("DMA error status: %x\n", DMA_ES);
use_fb = use_fb ? 0 : 1 ;
Serial.println(use_fb, DEC);
void drawTextScreen(bool fOpaque) {
tft.setFont(Arial_40_Bold);
if (fOpaque)
tft.setTextColor(ILI9341_WHITE, use_fb ? ILI9341_BLACK : ILI9341_RED);
tft.setCursor(0, 5);
tft.println("AbCdEfGhIj");
tft.setFont(Arial_28_Bold);
tft.println("0123456789!@#$");
#if 1
tft.setFont(Arial_20_Bold);
tft.println("abcdefghijklmnopq");
tft.setFont(Arial_14_Bold);
tft.println("ABCDEFGHIJKLMNOPQRST");
tft.setFont(Arial_10_Bold);
tft.println("0123456789zyxwvutu");
tft.updateScreen();
Serial.printf("Use FB: %d OP: %d, DT: %d OR: %d\n", use_fb, fOpaque, use_set_origin, millis() - start_time);
// Try continuous update
void testDMAContUpdate() {
// Force frame buffer on
Serial.printf("continuous DMA udpate test - Frame mode on\n"); Serial.flush();
use_fb = 1; //
tft.fillScreen(ILI9341_GREEN);
tft.startUpdateScreenDMA(true);
uint32_t frame_count;
while ((frame_count = tft.frameCount()) < 10) yield();
tft.fillScreen(ILI9341_YELLOW);
while ((frame_count = tft.frameCount()) < 20) yield();
tft.fillScreen(ILI9341_RED);
while ((frame_count = tft.frameCount()) < 30) yield();
while ((frame_count = tft.frameCount()) < 40) yield();
tft.setCursor(0, 100);
tft.println("DONE");
tft.endUpdateScreenDMA();
Serial.println("Finished test");
void loop(void) {
// See if any text entered
int ich;
if ((ich = Serial.read()) != -1) {
while (Serial.read() != -1) delay(1);
if (ich == 'c') {
use_clip_rect = !use_clip_rect;
if (use_clip_rect) Serial.println("Clip Rectangle Turned on");
else Serial.println("Clip Rectangle turned off");
return;
if (ich == 'd') {
use_dma = !use_dma;
if (use_dma) Serial.println("DMA Turned on");
else Serial.println("DMA turned off");
return;
if (ich == 's') {
use_set_origin = !use_set_origin;
if (use_set_origin) Serial.printf("Set origin to %d, %d\n", ORIGIN_TEST_X, ORIGIN_TEST_Y);
else Serial.println("Clear origin");
return;
if (ich == 'o')
drawTextScreen(1);
else if (ich == 't')
drawTextScreen(0);
else if (ich == 'r') {
testDMAContUpdate();
drawTestScreen();
What is not working on 1 and 3? Everything or the DMA stuff? I will try to take a look later today.
Update:
I tried on my Flex board, with my Frame buffer output and clip test program and was able to set rotation to all four rotations. I only did some basic testing, but did not notice anything obviously not working...
Code:#include <ili9341_t3n_font_Arial.h> #include <ili9341_t3n_font_ArialBold.h> #include <ILI9341_t3n.h> #define ROTATION 3 #include "SPI.h" #define KURTS_FLEXI #ifdef KURTS_FLEXI #define TFT_DC 22 #define TFT_CS 15 #define TFT_RST -1 #define TFT_SCK 14 #define TFT_MISO 12 #define TFT_MOSI 7 #define DEBUG_PIN 13 #else #define TFT_DC 9 #define TFT_CS 10 #define TFT_RST 7 #define TFT_SCK 13 #define TFT_MISO 12 #define TFT_MOSI 11 #endif ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCK, TFT_MISO, &SPIN); Adafruit_GFX_Button button; uint8_t use_dma = 0; uint8_t use_clip_rect = 0; uint8_t use_set_origin = 0; uint8_t use_fb = 0; #define ORIGIN_TEST_X 50 #define ORIGIN_TEST_Y 50 void setup() { while (!Serial && (millis() < 4000)) ; Serial.begin(115200); tft.begin(); tft.setRotation(ROTATION); tft.fillScreen(ILI9341_BLACK); // read diagnostics (optional but can help debug problems) uint8_t x = tft.readcommand8(ILI9341_RDMODE); Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX); x = tft.readcommand8(ILI9341_RDMADCTL); Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX); x = tft.readcommand8(ILI9341_RDPIXFMT); Serial.print("Pixel Format: 0x"); Serial.println(x, HEX); x = tft.readcommand8(ILI9341_RDIMGFMT); Serial.print("Image Format: 0x"); Serial.println(x, HEX); x = tft.readcommand8(ILI9341_RDSELFDIAG); Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX); #ifdef DEBUG_PIN pinMode(DEBUG_PIN, OUTPUT); #endif button.initButton(&tft, 200, 125, 100, 40, ILI9341_GREEN, ILI9341_YELLOW, ILI9341_RED, "UP", 1); drawTestScreen(); } void SetupOrClearClipRectAndOffsets() { if (use_clip_rect) { tft.setClipRect(); // make sure we clear the whole screen tft.setOrigin(); // make sure none are set yet tft.fillScreen(ILI9341_LIGHTGREY); // Now lets set origin. if (use_set_origin) tft.setOrigin(ORIGIN_TEST_X, ORIGIN_TEST_Y); int x = tft.width() / 4; int y = tft.height() / 4; int w = tft.width() / 2; int h = tft.height() / 2; tft.drawRect(x, y, w, h, ILI9341_ORANGE); tft.updateScreen(); tft.setClipRect(x + 1, y + 1, w - 2, h - 2); delay(250); } else { tft.setClipRect(); if (use_set_origin) tft.setOrigin(ORIGIN_TEST_X, ORIGIN_TEST_Y); else tft.setOrigin(); } } uint16_t palette[256]; // Should probably be 256, but I don't use many colors... uint16_t pixel_data[2500]; const uint8_t pict1bpp[] = {0xff, 0xff, 0xc0, 0x03, 0xa0, 0x05, 0x90, 0x9, 0x88, 0x11, 0x84, 0x21, 0x82, 0x41, 0x81, 0x81, 0x81, 0x81, 0x82, 0x41, 0x84, 0x21, 0x88, 0x11, 0x90, 0x09, 0xa0, 0x05, 0xc0, 0x03, 0xff, 0xff }; const uint8_t pict2bpp[] = { 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, }; const uint8_t pict4bpp[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x00, 0x00, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x00, 0x00, 0x11, 0x22, 0x22, 0x22, 0x22, 0x11, 0x00, 0x00, 0x11, 0x22, 0x22, 0x22, 0x22, 0x11, 0x00, 0x00, 0x11, 0x22, 0x33, 0x33, 0x22, 0x11, 0x00, 0x00, 0x11, 0x22, 0x33, 0x33, 0x22, 0x11, 0x00, 0x00, 0x11, 0x22, 0x33, 0x33, 0x22, 0x11, 0x00, 0x00, 0x11, 0x22, 0x33, 0x33, 0x22, 0x11, 0x00, 0x00, 0x11, 0x22, 0x22, 0x22, 0x22, 0x11, 0x00, 0x00, 0x11, 0x22, 0x22, 0x22, 0x22, 0x11, 0x00, 0x00, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x00, 0x00, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, }; void drawTestScreen() { Serial.printf("Use FB: %d ", use_fb); Serial.flush(); tft.useFrameBuffer(use_fb); SetupOrClearClipRectAndOffsets(); uint32_t start_time = millis(); tft.fillScreen(use_fb ? ILI9341_RED : ILI9341_BLACK); //tft.setFont(Inconsolata_60); tft.setFont(Arial_24_Bold); tft.setTextColor(ILI9341_WHITE); tft.setCursor(0, 0); tft.println("Test"); tft.setTextColor(ILI9341_WHITE, ILI9341_RED); tft.println("text"); tft.setCursor(85, 65); tft.print("XYZ"); tft.setFontAdafruit(); tft.setTextSize(2); tft.setTextColor(ILI9341_WHITE); tft.println("01234"); tft.setTextColor(ILI9341_WHITE, ILI9341_GREEN); tft.println("56789!@#$%"); tft.drawRect(0, 150, 100, 50, ILI9341_WHITE); tft.drawLine(0, 150, 100, 50, ILI9341_GREEN); tft.fillRectVGradient(125, 150, 50, 50, ILI9341_GREEN, ILI9341_YELLOW); tft.fillRectHGradient(200, 150, 50, 50, ILI9341_YELLOW, ILI9341_GREEN); // Try a read rect and write rect #ifdef DEBUG_PIN digitalWrite(DEBUG_PIN, HIGH); #endif tft.readRect(0, 0, 50, 50, pixel_data); #ifdef DEBUG_PIN digitalWrite(DEBUG_PIN, LOW); #endif tft.writeRect(250, 0, 50, 50, pixel_data); // Lets try to pack this rectangle of data into 8 byte tft.readRect(85, 65, 50, 50, pixel_data); uint16_t *ppd16 = pixel_data; uint8_t *ppd8 = (uint8_t*)pixel_data; uint8_t palette_cnt = 0; int palette_index; for (int i = 0; i < 2500; i++) { for (palette_index = 0; palette_index < palette_cnt; palette_index++) { if (*ppd16 == palette[palette_index]) break; } if (palette_index >= palette_cnt) { palette[palette_cnt++] = *ppd16; // save away the color } *ppd8++ = palette_index; ppd16++; } tft.writeRect8BPP(200, 50, 50, 50, (uint8_t*)pixel_data, palette); palette[0] = ILI9341_CYAN; palette[1] = ILI9341_OLIVE; tft.writeRect1BPP(75, 100, 16, 16, pict1bpp, palette); tft.writeRect1BPP(320-90, 75, 16, 16, pict1bpp, palette); palette[2] = ILI9341_MAROON; palette[3] = ILI9341_PINK; tft.writeRect2BPP(75, 125, 32, 16, pict2bpp, palette); tft.writeRectNBPP(15, 125, 32, 16, 2, pict2bpp, palette); tft.writeRectNBPP(75, 150, 16, 16, 4, pict4bpp, palette); // Try drawing button tft.setFontAdafruit(); button.drawButton(); if (use_dma) { tft.startUpdateScreenDMA(); } else { tft.updateScreen(); } Serial.println(millis() - start_time, DEC); if (use_dma && use_fb) { delay(500); Serial.printf("DMA error status: %x\n", DMA_ES); } use_fb = use_fb ? 0 : 1 ; Serial.println(use_fb, DEC); } void drawTextScreen(bool fOpaque) { SetupOrClearClipRectAndOffsets(); uint32_t start_time = millis(); tft.useFrameBuffer(use_fb); tft.fillScreen(use_fb ? ILI9341_RED : ILI9341_BLACK); tft.setFont(Arial_40_Bold); if (fOpaque) tft.setTextColor(ILI9341_WHITE, use_fb ? ILI9341_BLACK : ILI9341_RED); else tft.setTextColor(ILI9341_WHITE); tft.setCursor(0, 5); tft.println("AbCdEfGhIj"); tft.setFont(Arial_28_Bold); tft.println("0123456789!@#$"); #if 1 tft.setFont(Arial_20_Bold); tft.println("abcdefghijklmnopq"); tft.setFont(Arial_14_Bold); tft.println("ABCDEFGHIJKLMNOPQRST"); tft.setFont(Arial_10_Bold); tft.println("0123456789zyxwvutu"); #endif tft.updateScreen(); Serial.printf("Use FB: %d OP: %d, DT: %d OR: %d\n", use_fb, fOpaque, use_set_origin, millis() - start_time); } //============================================================================= // Try continuous update //============================================================================= void testDMAContUpdate() { // Force frame buffer on Serial.printf("continuous DMA udpate test - Frame mode on\n"); Serial.flush(); use_fb = 1; // tft.useFrameBuffer(use_fb); tft.fillScreen(ILI9341_GREEN); tft.startUpdateScreenDMA(true); uint32_t frame_count; while ((frame_count = tft.frameCount()) < 10) yield(); tft.fillScreen(ILI9341_YELLOW); while ((frame_count = tft.frameCount()) < 20) yield(); tft.fillScreen(ILI9341_RED); while ((frame_count = tft.frameCount()) < 30) yield(); tft.fillScreen(ILI9341_BLACK); while ((frame_count = tft.frameCount()) < 40) yield(); tft.setCursor(0, 100); tft.setFont(Arial_20_Bold); tft.println("DONE"); tft.endUpdateScreenDMA(); Serial.println("Finished test"); } void loop(void) { // See if any text entered int ich; if ((ich = Serial.read()) != -1) { while (Serial.read() != -1) delay(1); if (ich == 'c') { use_clip_rect = !use_clip_rect; if (use_clip_rect) Serial.println("Clip Rectangle Turned on"); else Serial.println("Clip Rectangle turned off"); return; } if (ich == 'd') { use_dma = !use_dma; if (use_dma) Serial.println("DMA Turned on"); else Serial.println("DMA turned off"); return; } if (ich == 's') { use_set_origin = !use_set_origin; if (use_set_origin) Serial.printf("Set origin to %d, %d\n", ORIGIN_TEST_X, ORIGIN_TEST_Y); else Serial.println("Clear origin"); return; } if (ich == 'o') drawTextScreen(1); else if (ich == 't') drawTextScreen(0); else if (ich == 'r') { testDMAContUpdate(); } else drawTestScreen(); } }
#include "SPI.h"
#include <ILI9341_t3DMA.h>
#define TFT_DC 9
#define TFT_CS 10
#define TFT_RST 8 // 255 = unused, connect to 3.3V
#define TFT_MOSI 11
#define TFT_SCLK 13
#define TFT_MISO 12
ILI9341_t3DMA tft = ILI9341_t3DMA(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
tft.begin();
tft.setRotation(1); //broken
tft.dfillScreen(ILI9341_BLACK);
tft.setTextColor(ILI9341_YELLOW);
tft.setTextSize(2);
tft.println("Waiting for Arduino Serial Monitor...");
tft.refreshOnce();
while (!Serial) ; // wait for Arduino Serial Monitor
Serial.println("ILI9341 Test!");
tft.refreshOnce();
void loop(void) {
#include "SPI.h"
#define KURTS_FLEXI
#ifdef KURTS_FLEXI
#define TFT_DC 22
#define TFT_CS 15
#define TFT_RST -1
#define TFT_SCLK 14
#define TFT_MISO 12
#define TFT_MOSI 7
#else
#define TFT_DC 9
#define TFT_CS 10
#define TFT_MOSI 11
#define TFT_SCLK 13
#define TFT_MISO 12
ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
tft.begin();
tft.useFrameBuffer(true);
tft.setTextSize(2);
tft.updateScreen();
tft.println("Connected!");
tft.updateScreen();
void loop(void) {
Wrong libraryThat is Frank's library, mine is ILI9341_t3n.
I did borrow some of Frank's stuff, but then updated it to work in all orientations, plus merged in lots of stuff, that had Pull requests for the main library, plus...
Here is a version of your above, using my Frame buffer stuff.
Code:#include "SPI.h" #include <ILI9341_t3n.h> #define KURTS_FLEXI #ifdef KURTS_FLEXI #define TFT_DC 22 #define TFT_CS 15 #define TFT_RST -1 #define TFT_SCLK 14 #define TFT_MISO 12 #define TFT_MOSI 7 #define DEBUG_PIN 13 #else #define TFT_DC 9 #define TFT_CS 10 #define TFT_RST 8 // 255 = unused, connect to 3.3V #define TFT_MOSI 11 #define TFT_SCLK 13 #define TFT_MISO 12 #endif ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO); void setup() { tft.begin(); tft.useFrameBuffer(true); tft.setRotation(1); //broken tft.fillScreen(ILI9341_BLACK); tft.setTextColor(ILI9341_YELLOW); tft.setTextSize(2); tft.println("Waiting for Arduino Serial Monitor..."); tft.updateScreen(); Serial.begin(9600); while (!Serial) ; // wait for Arduino Serial Monitor Serial.println("ILI9341 Test!"); tft.println("Connected!"); tft.updateScreen(); } void loop(void) { }
Yep - I forked his library, in order to make some changes and make Pull Requests....Well bah, I took it from your Github
It malloc's the memory as the library can be and, and is most often used without using the frame buffer, especially on everything but the T3.6KurtE, been busy prepping for IRMA. Took a look at your example on post 88, for some reason when I compile the IDE it says it only needs 5,272 bytes of memory, shouldn't the Frame Buffer eat up far more then that?
uint16_t frame_buffer[320*240]; // define your own buffer.
uint8_t useFrameBuffer(boolean b); // use the frame buffer? First call will allocate
void setFrameBuffer(uint16_t *buf) {_pfbtft = buf;}
// Let's allocate the frame buffer ourself.
uint16_t tft_frame_buffer[ILI9341_TFTWIDTH * ILI9341_TFTHEIGHT];
tft.begin();
tft.setFrameBuffer(tft_frame_buffer);
DMAMEM uint16_t ili9341_frame_buffer[ILI9341_TFTWIDTH*ILI9341_TFTHEIGHT];
#include "SPI.h"
#define TFT_DC 9
#define TFT_CS 10
#define TFT_MOSI 11
#define TFT_SCLK 13
#define TFT_MISO 12
ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO, [B]???????[/B]);
tft.begin();
tft.setRotation(1);
tft.setTextSize(2);
tft.updateScreen();
tft.updateScreen();
void loop(void) {
D:\Arduino\hardware\teensy\avr\libraries\ILI9341_t3n\ILI9341_t3n.cpp: In constructor 'ILI9341_t3n::ILI9341_t3n(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, SPINClass*)':
D:\Arduino\hardware\teensy\avr\libraries\ILI9341_t3n\ILI9341_t3n.cpp:103:28: error: 'class SPINClass' has no member named 'port'
_pkinetisk_spi = &_pspin->port();
D:\Arduino\hardware\teensy\avr\libraries\ILI9341_t3n\ILI9341_t3n.cpp: In member function 'void ILI9341_t3n::begin()':
D:\Arduino\hardware\teensy\avr\libraries\ILI9341_t3n\ILI9341_t3n.cpp:1456:31: error: 'class SPINClass' has no member named 'port'
D:\Arduino\hardware\teensy\avr\libraries\ILI9341_t3n\ILI9341_t3n.cpp:1465:32: error: 'class SPINClass' has no member named 'port'
Error compiling for board Teensy 3.6.
You probably need to update to a later version of SPIN. With the newer releases of Teensyduino and the rework of SPI, the newer SPIN code was updated to be closer to SPI code... Goal, get enough functionality into SPI to make SPIN no longer needed. If that becomes a problem, can try to build a version again using old SPIN...
