Playing with the Arduino UNO R4 boards
KurtE
Senior Member+
Yes, I know this is not a Teensy, but needed a diversion. Plus lots of things to try to improve.
Yesterday I was curious about how fast the digitalWrite calls are and if there was a digitalWriteFast and if so how much did it speed it up.
There is not a released version of it... Actually don't know if there are official versions of digitalWriteFast for any Arduino platform, but there was an open thread on it.
https://forum.arduino.cc/t/digitalwritefast-with-uno-r4/1145206/16
So I started playing. My first attempt that worked I modelled after the Teensy versions and looked like:
R_PORT0_Type *port_table[] = { R_PORT0, R_PORT1, R_PORT2, R_PORT3, R_PORT4, R_PORT5, R_PORT6, R_PORT7 };
static const uint16_t mask_table[] = { 1 << 0, 1 << 1, 1 << 2, 1 << 3, 1 << 4, 1 << 5, 1 << 6, 1 << 7,
                                       1 << 8, 1 << 9, 1 << 10, 1 << 11, 1 << 12, 1 << 13, 1 << 14, 1 << 15 };
// Cause a digital pin to output either HIGH or LOW.  The pin must
// have been configured with pinMode().  This fast version of
// digitalWrite has minimal overhead when the pin number is a
// constant.  Successive digitalWriteFast without delays can be
// too quick in many applications!
static inline void digitalWriteFast(uint8_t pin, uint8_t val) __attribute__((always_inline, unused));
static inline void digitalWriteFast(uint8_t pin, uint8_t val) {
  if (__builtin_constant_p(pin)) {
    if (val) {
      if (pin == 0) {
        port_table[g_pin_cfg[0].pin >> 8]->POSR = mask_table[g_pin_cfg[0].pin & 0xff];
      } else if (pin == 1) {
        port_table[g_pin_cfg[1].pin >> 8]->POSR = mask_table[g_pin_cfg[1].pin & 0xff];
      } else if (pin == 2) {
        port_table[g_pin_cfg[2].pin >> 8]->POSR = mask_table[g_pin_cfg[2].pin & 0xff];
      } else if (pin == 3) {
        port_table[g_pin_cfg[3].pin >> 8]->POSR = mask_table[g_pin_cfg[3].pin & 0xff];
      } else if (pin == 4) {
        port_table[g_pin_cfg[4].pin >> 8]->POSR = mask_table[g_pin_cfg[4].pin & 0xff];
      } else if (pin == 5) {
        port_table[g_pin_cfg[5].pin >> 8]->POSR = mask_table[g_pin_cfg[5].pin & 0xff];
      } else if (pin == 6) {
        port_table[g_pin_cfg[6].pin >> 8]->POSR = mask_table[g_pin_cfg[6].pin & 0xff];
      } else if (pin == 7) {
        port_table[g_pin_cfg[7].pin >> 8]->POSR = mask_table[g_pin_cfg[7].pin & 0xff];
      } else if (pin == 8) {
        port_table[g_pin_cfg[8].pin >> 8]->POSR = mask_table[g_pin_cfg[8].pin & 0xff];
      } else if (pin == 9) {
        port_table[g_pin_cfg[9].pin >> 8]->POSR = mask_table[g_pin_cfg[9].pin & 0xff];
      } else if (pin == 10) {
        port_table[g_pin_cfg[10].pin >> 8]->POSR = mask_table[g_pin_cfg[10].pin & 0xff];
      } else if (pin == 11) {
        port_table[g_pin_cfg[11].pin >> 8]->POSR = mask_table[g_pin_cfg[11].pin & 0xff];
      } else if (pin == 12) {
        port_table[g_pin_cfg[12].pin >> 8]->POSR = mask_table[g_pin_cfg[12].pin & 0xff];
      } else if (pin == 13) {
        port_table[g_pin_cfg[13].pin >> 8]->POSR = mask_table[g_pin_cfg[13].pin & 0xff];
      } else if (pin == 14) {
        port_table[g_pin_cfg[14].pin >> 8]->POSR = mask_table[g_pin_cfg[14].pin & 0xff];
      } else if (pin == 15) {
        port_table[g_pin_cfg[15].pin >> 8]->POSR = mask_table[g_pin_cfg[15].pin & 0xff];
      } else if (pin == 16) {
        port_table[g_pin_cfg[16].pin >> 8]->POSR = mask_table[g_pin_cfg[16].pin & 0xff];
      } else if (pin == 17) {
        port_table[g_pin_cfg[17].pin >> 8]->POSR = mask_table[g_pin_cfg[17].pin & 0xff];
      } else if (pin == 18) {
        port_table[g_pin_cfg[18].pin >> 8]->POSR = mask_table[g_pin_cfg[18].pin & 0xff];
      } else if (pin == 19) {
        port_table[g_pin_cfg[19].pin >> 8]->POSR = mask_table[g_pin_cfg[19].pin & 0xff];
      } else if (pin == 20) {
        port_table[g_pin_cfg[20].pin >> 8]->POSR = mask_table[g_pin_cfg[20].pin & 0xff];
      } else if (pin == 21) {
        port_table[g_pin_cfg[21].pin >> 8]->POSR = mask_table[g_pin_cfg[21].pin & 0xff];
      } else if (pin == 22) {
        port_table[g_pin_cfg[22].pin >> 8]->POSR = mask_table[g_pin_cfg[22].pin & 0xff];
      } else if (pin == 23) {
        port_table[g_pin_cfg[23].pin >> 8]->POSR = mask_table[g_pin_cfg[23].pin & 0xff];
      } else if (pin == 24) {
        port_table[g_pin_cfg[24].pin >> 8]->POSR = mask_table[g_pin_cfg[24].pin & 0xff];
      } else if (pin == 25) {
        port_table[g_pin_cfg[25].pin >> 8]->POSR = mask_table[g_pin_cfg[25].pin & 0xff];
      } else if (pin == 26) {
        port_table[g_pin_cfg[26].pin >> 8]->POSR = mask_table[g_pin_cfg[26].pin & 0xff];
      } else if (pin == 27) {
        port_table[g_pin_cfg[27].pin >> 8]->POSR = mask_table[g_pin_cfg[27].pin & 0xff];
      } else if (pin == 28) {
        port_table[g_pin_cfg[28].pin >> 8]->POSR = mask_table[g_pin_cfg[28].pin & 0xff];
      } else if (pin == 29) {
        port_table[g_pin_cfg[29].pin >> 8]->POSR = mask_table[g_pin_cfg[29].pin & 0xff];
      } else if (pin == 30) {
        port_table[g_pin_cfg[30].pin >> 8]->POSR = mask_table[g_pin_cfg[30].pin & 0xff];
      } else if (pin == 31) {
        port_table[g_pin_cfg[31].pin >> 8]->POSR = mask_table[g_pin_cfg[31].pin & 0xff];
      } else if (pin == 32) {
        port_table[g_pin_cfg[32].pin >> 8]->POSR = mask_table[g_pin_cfg[32].pin & 0xff];
      } else if (pin == 33) {
        port_table[g_pin_cfg[33].pin >> 8]->POSR = mask_table[g_pin_cfg[33].pin & 0xff];
      } else if (pin == 34) {
        port_table[g_pin_cfg[34].pin >> 8]->POSR = mask_table[g_pin_cfg[34].pin & 0xff];
      } else if (pin == 35) {
        port_table[g_pin_cfg[35].pin >> 8]->POSR = mask_table[g_pin_cfg[35].pin & 0xff];
      } else if (pin == 36) {
        port_table[g_pin_cfg[36].pin >> 8]->POSR = mask_table[g_pin_cfg[36].pin & 0xff];
      } else if (pin == 37) {
        port_table[g_pin_cfg[37].pin >> 8]->POSR = mask_table[g_pin_cfg[37].pin & 0xff];
      } else if (pin == 38) {
        port_table[g_pin_cfg[38].pin >> 8]->POSR = mask_table[g_pin_cfg[38].pin & 0xff];
      if (pin == 0) {
        port_table[g_pin_cfg[0].pin >>8]->PORR = mask_table[g_pin_cfg[0].pin & 0xff];
        port_table[g_pin_cfg[1].pin >>8]->PORR = mask_table[g_pin_cfg[1].pin & 0xff];
        port_table[g_pin_cfg[2].pin >>8]->PORR = mask_table[g_pin_cfg[2].pin & 0xff];
        port_table[g_pin_cfg[3].pin >>8]->PORR = mask_table[g_pin_cfg[3].pin & 0xff];
        port_table[g_pin_cfg[4].pin >>8]->PORR = mask_table[g_pin_cfg[4].pin & 0xff];
        port_table[g_pin_cfg[5].pin >>8]->PORR = mask_table[g_pin_cfg[5].pin & 0xff];
        port_table[g_pin_cfg[6].pin >>8]->PORR = mask_table[g_pin_cfg[6].pin & 0xff];
        port_table[g_pin_cfg[7].pin >>8]->PORR = mask_table[g_pin_cfg[7].pin & 0xff];
        port_table[g_pin_cfg[8].pin >>8]->PORR = mask_table[g_pin_cfg[8].pin & 0xff];
        port_table[g_pin_cfg[9].pin >>8]->PORR = mask_table[g_pin_cfg[9].pin & 0xff];
        port_table[g_pin_cfg[10].pin >>8]->PORR = mask_table[g_pin_cfg[10].pin & 0xff];
        port_table[g_pin_cfg[11].pin >>8]->PORR = mask_table[g_pin_cfg[11].pin & 0xff];
        port_table[g_pin_cfg[12].pin >>8]->PORR = mask_table[g_pin_cfg[12].pin & 0xff];
        port_table[g_pin_cfg[13].pin >>8]->PORR = mask_table[g_pin_cfg[13].pin & 0xff];
        port_table[g_pin_cfg[14].pin >>8]->PORR = mask_table[g_pin_cfg[14].pin & 0xff];
        port_table[g_pin_cfg[15].pin >>8]->PORR = mask_table[g_pin_cfg[15].pin & 0xff];
        port_table[g_pin_cfg[16].pin >>8]->PORR = mask_table[g_pin_cfg[16].pin & 0xff];
        port_table[g_pin_cfg[17].pin >>8]->PORR = mask_table[g_pin_cfg[17].pin & 0xff];
        port_table[g_pin_cfg[18].pin >>8]->PORR = mask_table[g_pin_cfg[18].pin & 0xff];
        port_table[g_pin_cfg[19].pin >>8]->PORR = mask_table[g_pin_cfg[19].pin & 0xff];
        port_table[g_pin_cfg[20].pin >>8]->PORR = mask_table[g_pin_cfg[20].pin & 0xff];
        port_table[g_pin_cfg[21].pin >>8]->PORR = mask_table[g_pin_cfg[21].pin & 0xff];
        port_table[g_pin_cfg[22].pin >>8]->PORR = mask_table[g_pin_cfg[22].pin & 0xff];
        port_table[g_pin_cfg[23].pin >>8]->PORR = mask_table[g_pin_cfg[23].pin & 0xff];
        port_table[g_pin_cfg[24].pin >>8]->PORR = mask_table[g_pin_cfg[24].pin & 0xff];
        port_table[g_pin_cfg[25].pin >>8]->PORR = mask_table[g_pin_cfg[25].pin & 0xff];
        port_table[g_pin_cfg[26].pin >>8]->PORR = mask_table[g_pin_cfg[26].pin & 0xff];
        port_table[g_pin_cfg[27].pin >>8]->PORR = mask_table[g_pin_cfg[27].pin & 0xff];
        port_table[g_pin_cfg[28].pin >>8]->PORR = mask_table[g_pin_cfg[28].pin & 0xff];
        port_table[g_pin_cfg[29].pin >>8]->PORR = mask_table[g_pin_cfg[29].pin & 0xff];
        port_table[g_pin_cfg[30].pin >>8]->PORR = mask_table[g_pin_cfg[30].pin & 0xff];
        port_table[g_pin_cfg[31].pin >>8]->PORR = mask_table[g_pin_cfg[31].pin & 0xff];
        port_table[g_pin_cfg[32].pin >>8]->PORR = mask_table[g_pin_cfg[32].pin & 0xff];
        port_table[g_pin_cfg[33].pin >>8]->PORR = mask_table[g_pin_cfg[33].pin & 0xff];
        port_table[g_pin_cfg[34].pin >>8]->PORR = mask_table[g_pin_cfg[34].pin & 0xff];
        port_table[g_pin_cfg[35].pin >>8]->PORR = mask_table[g_pin_cfg[35].pin & 0xff];
        port_table[g_pin_cfg[36].pin >>8]->PORR = mask_table[g_pin_cfg[36].pin & 0xff];
        port_table[g_pin_cfg[37].pin >>8]->PORR = mask_table[g_pin_cfg[37].pin & 0xff];
        port_table[g_pin_cfg[38].pin >>8]->PORR = mask_table[g_pin_cfg[38].pin & 0xff];
    digitalWrite(pin, val);
Which worked.
The test sketch had in it:
  Serial.println("\n\nTest");
  while (!Serial && millis() < 5000)
  pinMode(LED_BUILTIN, OUTPUT);
  uint32_t start_time = micros();
  for (int i = 0; i < 1000; i++) {
    digitalWriteFast(LED_BUILTIN, HIGH);
    digitalWriteFast(LED_BUILTIN, LOW);
  delta_time = micros() - start_time;
  Serial.print("digitalWriteFast: ");
  Serial.println(delta_time, DEC);
And had a nice speed up:
Test
digitalWrite: 1515
digitalWriteFast: 179
One of the responses included:
    if (val) {
      if (pin == 0) {
Not needed. Make your "fasterDigitalWrite()" function "static inline", and it should produce nearly identical code. The compiler will happily optimize array accesses to static arrays to simple loads without going to the ugliness you implemented.
He was right:
static inline void fasterDigitalWrite(uint8_t pin, uint8_t val) __attribute__((always_inline, unused));
static inline void  fasterDigitalWrite(pin_size_t pin, PinStatus val) {
  uint16_t hardware_port_pin = g_pin_cfg[pin].pin;
  //uint16_t mask = 1 << (hardware_port_pin & 0xf);
  uint16_t mask = mask_table[hardware_port_pin & 0xf];
  R_PORT0_Type *port = port_table[hardware_port_pin >> 8];
  if (val) port->POSR = mask;
  else port->PORR = mask;
Also 1000 loops through it completed in: 179us
Which made me wonder about the Teensy versions. So I hacked up the teensy4\core_pins.h and added:
static inline void digitalWriteFastSimple(uint8_t pin, uint8_t val) __attribute__((always_inline, unused));
	if(val) *portSetRegister(pin) = digitalPinToBitMask(pin);
	else *portClearRegister(pin) = digitalPinToBitMask(pin);
Ran a similar test sketch:
  while(!Serial && millis() < 5000);
  for (int i = 0; i < 10000; i++) {
  uint32_t delta_time = micros() - start_time;
  Serial.print("digitalWrite: ");
    digitalWriteFastSimple(LED_BUILTIN, HIGH);
    digitalWriteFastSimple(LED_BUILTIN, LOW);
  Serial.print("digitalWriteFastSimple: ");
I went 10000 times instead of 1000 due the speed of the T4.x. In this case running a Micromod.
Test
digitalWrite: 684
digitalWriteFastSimple: 67
digitalWriteFast: 67
So wondering if we should update the real one... Probably similar for digitalToggleFast...
Again just having some fun.
Now back to Arduino UNO R4 Wifi board. And see about fixing some of their Serial code. Some reason I don't like that it crashes the board, if I call Serial.print (or Serial1.print()), from an ISR...
Good test @KurtE. Wondered about that the other day when the @??? poster mentioned alternate code.
When tested the other day there was the same speed up when PIN # was NOT CONSTANT - known at compile time.
The same is true with the digitalWriteFastSimple():
Test
digitalWrite: 684
RANDOM digitalWriteFastSimple: 67	 Random Pin#= 34
RANDOM digitalWriteFastSimple: 67	 Random Pin#= 35
RANDOM digitalWriteFastSimple: 67	 Random Pin#= 31
RANDOM digitalWriteFastSimple: 67	 Random Pin#= 33
With this added test looping at end of setup():
  int jj;
  for (int ii = 0; ii < 5; ii++) {
    jj=30;
    while (jj == 30)
      jj = random(7) + 30;
    pinMode(jj, OUTPUT);
      digitalWriteFastSimple(jj, HIGH);
      digitalWriteFastSimple(jj, LOW);
    Serial.print("RANDOM digitalWriteFastSimple: ");
    Serial.print(delta_time, DEC);
    Serial.print("\t Random Pin#= ");
    Serial.println(jj);
    if (val) {
      if (pin == 0) {
      if (pin == 0) {
Which worked.
Test
digitalWrite: 1515
He was right:
Test
digitalWrite: 684
Now back to Arduino uno R4 Wifi board. And see about fixing some of their Serial code. Some reason I don't like that it crashes the board, if I call Serial.print (or Serial1.print()), from an ISR...
Hello. Has anyone's experience with the new R4 been better than the super hit or miss cloud agent performance on pretty much all the other IOT devices? It doesn't actually seem to be hardware related, more browser and an inability to code managing windows resources adequately, especially serial connectivity, so I'd guess this would be just work about as unreliably.
Sorry I have not played with any of the cloud stuff. You might have better luck asking on the Arduino forum.
