Thundercat
Hi, apologies if this is obvious or stupid, but I've got a large project that is going to need more than the 500mA that a USB cable can supply. I'll be using a Teensy 4.1, as well as an ESP32-S3.
Yes I know USB-C can deliver much more power, but I also hear it's tricky and may not work reliably in all cases, and needs a special IC etc etc.
I want something really simple and reliable.
My thought is this: use the USB power for both the MCUs, and then add an additional wall wart that will supply 5V DC with more amperage.
I ran across a post where someone said you can do this, just connect the grounds of the Teensy and ESP32 and the external wall wart, and then use the external wall wart power for the higher wattage items (lots of LEDs and a BLDC motor that itself will take 1.2A).
Is this viable? Is this safe?
If so, what do I need to think about when introducing the wall wart positive rail onto the PCB? Should I add some bulk capacitance or EMF filtering, like a TVS, or an inductor?
Again, sorry if this is really obvious, but this is new territory for me. I really, really wanted to keep the project powered only by USB, but I'm afraid it will require a lot more power than the 500mA USB can deliver.
Thanks for any insights. And if anyone has an suggested circuits or specific ideas, I'd love that.
Mike
Mike
