1bit
Haven't said anything for a while. I dug up one of my one boards and went over the features of it. So, I thought I would post it. Mainly, so I could find it. It has a Due or Mega 2560 as an I2c slave of Teensy32. The Teensy32 runs most of the peripherals but the Arduino (with all that I/O can run) the steppers or some other things or the board can use the mega pin hole to strap the board for direct stepper driving by the Teensy32. The WizNet5100 the business of the Teensy on SPI. The Teensy also has slots for ADS1115 with little mini termian blocks. The Teensy is the I2c bus master so a touch screen either on I2c or SPI has been done. The ESP8266 can go on either the Arduino or the Teensy depending on how you strap the board, same for the RS-485 drivers.
I am out of these boards and will send them out for a lot of 10 or so.
