Hello,
this is my first forum post, so first off all I'd like to say "thank you" for your awesome Teensy Products and the great audio library. I've done a lot of sound projects so far and had a lot of fun with it!
For my current project I'd like to do some physical modeling with Teensy and the audio adaptor. My first tryout was a simple Karplus-Strong-Algorithm (not the 100% original) to synthesize a plucked string. Which worked and sounded well so far, see my block diagram:
To adjust the correct pitch in Karplus-Strong you have to set the length of the delay line. The number of delayed samples is N = Fsample / Fpitch. For the note A4 = 440Hz @ Fs=44100 the delay length should be 100 samples, but the resulting pitch is much lower. After some research I figured out, that even when I set the delay on 0.0ms it produces delay. Am I doing something wrong? If I set the delay on 0.0ms my Karplus-Strong produces a pitch of almost the note F4, wich is about 340Hz.
Is it possible to delay samples very precisely or even a one sample delay with the delay-object?
If not, is it possible to modify or write a new audio object to do this?
Thanks so much!
Thanks so much!
