I recently experienced a Teensy crash/reset while controlling a motor on a lathe. Quite often, there isn't even a console attached, just an ILI9341. Trying to install bread crumbs and whatnot in my code now.
I want to both write to serial AND to overwrite the whole display with the CrashReport output. I think a code crash is important enough to do this. This fault is infrequent, having only happened once in 18 months, so if it's a code problem I want a fighting chance at capturing it.
I'm using @KurtE 's ILI9341_t3n driver. It's been a while since I've set something like this up. The example crash report file prints out character by character, until the logfile is empty. Is the correct method to type out a single character on the display simply
? Does
mean that characters that go past the 320 pixels in x, will be automatically wrapped to the next line?
Here's what I have written so far. I call this routine to check if a crash has occurred, any hopefully it would print out the CrashReport and any bread crumbs I set. The LittleFS and tft libraries have been imported in other files, don't want to import them twice.
I logged the data to a small part of the flash, so that it would be retrievable, without modifying units in the field. If I were starting from scratch, maybe I'd use an SD card.
Obviously this routine won't work, if the display routines died, but I'm hoping not! A display is always present, but a serial console isn't. I obviously don't have a routine to delete the file, I'll need to write that... If there's a crash report, I'd like to know it happened and the operator knows something serious occurred.
Grateful for any additional insight. This is a tough nut to crack. The application has never crashed before, including when I was operating it at rates that were 17 times faster on the lathe. I'd like to isolate the problem before releasing this latest branch of my code... Thanks.
tft.drawFontChar( char c);
tft.setTextWrap(true);
C++:
/* This takes over the tft screen if there's a major crash logged by the Teensy. Such a crash is a
big deal and we want to know it happened. Print out message to serial console if attached and
take over the tft screen entirely.
void crashreporter() {
char c;
File logFile = myfs.open("crashlog.txt");
if (logFile) {
tft.fillScreen(thisGREY);
tft.setCursor(0,0);
tft.setTextColor(ILI9341_WHITE);
tft.setTextDatum(TL_DATUM);
tft.setFont(Arial_10); // Make text small enought to fit the message
while (logFile.available()) {
c = logFile.read();
Serial.write(c);
tft.drawFontChar(c);
while(1); // hang forever
else {
Serial.println("Sorry, no crashlog.txt stored");
