* Audio Guestbook, Copyright (c) 2022 Playful Technology
* Tested using a Teensy 4.0 with Teensy Audio Shield, although should work
* with minor modifications on other similar hardware
* When handset is lifted, a pre-recorded greeting message is played, followed by a tone.
* Then, recording starts, and continues until the handset is replaced.
* Playback button allows all messages currently saved on SD card through earpiece
* Files are saved on SD card as 44.1kHz, 16-bit, mono signed integer RAW audio format
* These can be loaded directly into Audacity ([url]https://www.audacityteam.org/[/url]). Or else, converted to WAV/MP3 format using SOX ([url]https://sourceforge.net/projects/sox/[/url])
// ********** Rik 6/22/2022 - My mods are marked with RAM in comments. *********
// ************ GREETING MUST BE RECORDED IN .RAW FORMAT (16 BIT 44.1Khz. MONO) ****************************************************************
// INCLUDES
// The default "sketchbook" location in which Arduino IDE installs libraries is:
// C:\Users\alast\Documents\Arduino
// However, the TeensyDuino installer installs libraries in:
// C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries
// To ensure the correct libraries are used when targetting Teensy platform in Arduino IDE, go File->Preferences and change the sketchbook location to avoid conflicts with Arduino libraries.
// When targetting Arduino boards, change it back again to default
#include <Bounce.h>
#include <TimeLib.h>
// DEFINES
// Define pins used by Teensy Audio Shield
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
// And those used for inputs
#define HOOK_PIN 0
#define PLAYBACK_BUTTON_PIN 1
int hookRead; // Added to check for hang up before playing greeting. RAM
int x;
// GLOBALS
// Audio initialisation code can be generated using the GUI interface at [url]https://www.pjrc.com/teensy/gui/[/url]
// Inputs
AudioSynthWaveform waveform1; // To create the "beep" sfx
AudioInputI2S i2s2; // I2S input from microphone on audio shield
AudioPlaySdRaw playRaw1; // Play .RAW audio files saved on SD card
AudioPlaySdWav playWav1; // Play 44.1kHz 16-bit PCM greeting WAV file
// Outputs
AudioRecordQueue queue1; // Creating an audio buffer in memory before saving to SD
AudioMixer4 mixer; // Allows merging several inputs to same output
AudioOutputI2S i2s1; // I2S interface to Speaker/Line Out on Audio shield
// Connections
AudioConnection patchCord1(waveform1, 0, mixer, 0); // wave to mixer
AudioConnection patchCord2(playRaw1, 0, mixer, 1); // raw audio to mixer
AudioConnection patchCord3(playWav1, 0, mixer, 2); // wav file playback mixer
AudioConnection patchCord4(mixer, 0, i2s1, 0); // mixer output to speaker (L)
AudioConnection patchCord5(i2s2, 0, queue1, 0); // mic input to queue (L)
AudioConnection patchcord6(i2s2, 0, mixer, 3); // Added mic input to mixer to hear talking through handset speaker. RAM
// Filename to save audio recording on SD card
char filename[15];
// The file object itself
File frec;
// Use long 100ms debounce time on hook switch
Bounce buttonRecord = Bounce(HOOK_PIN, 100); // default (40). RAM
Bounce buttonPlay = Bounce(PLAYBACK_BUTTON_PIN, 100); // default (8). RAM
// Keep track of current state of the device
enum Mode {Initialising, Ready, Prompting, Recording, Playing};
Mode mode = Mode::Initialising;
// Note that Serial.begin() is not required for Teensy -
// by default it initialises serial communication at full USB speed
// See [url]https://www.pjrc.com/teensy/td_serial.html[/url]
// Serial.begin()
Serial.println(__FILE__ __DATE__);
// Configure the input pins
pinMode(HOOK_PIN, INPUT_PULLUP);
pinMode(PLAYBACK_BUTTON_PIN, INPUT_PULLUP);
AudioMemory(60);
sgtl5000_1.enable();
// Define which input on the audio shield to use (AUDIO_INPUT_LINEIN / AUDIO_INPUT_MIC)
sgtl5000_1.volume(0.6); // Output speaker volume. default (.5). RAM
// Play a beep to indicate system is online
waveform1.frequency(440);
waveform1.amplitude(0.9);
wait(250);
waveform1.amplitude(0);
// Initialize the SD card
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
// Mic Gain (Value in dB)
sgtl5000_1.micGain(38); // default (15). RAM
// Synchronise the Time object used in the program code with the RTC time provider.
// See [url]https://github.com/PaulStoffregen/Time[/url]
// Define a callback that will assign the correct datetime for any file system operations
// (i.e. saving a new audio recording onto the SD card)
FsDateTime::setCallback(dateTime);
mode = Mode::Ready;
// First, read the buttons
buttonRecord.update();
buttonPlay.update();
switch(mode){
case Mode::Ready:
// Rising edge occurs when the handset is lifted
if (buttonRecord.risingEdge()) {
Serial.println("Handset lifted");
mode = Mode::Prompting;
else if(buttonPlay.fallingEdge()) {
playAllRecordings();
case Mode::Prompting:
// Wait a second for users to put the handset to their ear. RAM
// Added to read hook pin to check if handset has been replaced before proceeding. RAM
x=0; // Clear counter.
while (x < 30) {
wait(50); // Wait 50 mS.
x=x+1; // Increment counter
Serial.println(x); // Print counter value
hookRead=digitalRead(HOOK_PIN); // Check if handset replaced.
if (hookRead==0) {
Serial.println("Handset Replaced Before Message");
mode = Mode::Ready; // Return to ready mode if hang up.
return;
// Play the greeting inviting them to record their message
playRaw1.play("greeting.raw"); // Changed from default (.wav) to (.raw) format. Greeting MUST be recorded in .raw format. RAM
// Wait until the message has finished playing
while (playRaw1.isPlaying()) {
// Check whether the handset is replaced
// Handset is replaced
if(buttonRecord.fallingEdge()) {
playRaw1.stop();
mode = Mode::Ready;
return;
// Debug message
Serial.println("Starting Recording");
// Play the tone sound effect
wait(250);
// Start the recording function
startRecording();
case Mode::Recording:
if(buttonRecord.fallingEdge()){
// Debug log
Serial.println("Stopping Recording");
// Stop recording
stopRecording();
// Play audio tone to confirm recording has ended
waveform1.frequency(523.25);
wait(50);
wait(50);
wait(50);
else {
continueRecording();
case Mode::Playing:
void startRecording() {
// Find the first available file number
for (uint8_t i=0; i<9999; i++) {
// Format the counter as a five-digit number with leading zeroes, followed by file extension
snprintf(filename, 11, " %05d.RAW", i);
// Create if does not exist, do not open existing, write, sync after write
if (!SD.exists(filename)) {
frec = SD.open(filename, FILE_WRITE);
if(frec) {
Serial.print("Recording to ");
Serial.println(filename);
queue1.begin();
mode = Mode::Recording;
else {
Serial.println("Couldn't open file to record!");
void continueRecording() {
// Check if there is data in the queue
if (queue1.available() >= 2) {
byte buffer[512];
// into a 512 byte buffer. The Arduino SD library
// writes are used.
memcpy(buffer, queue1.readBuffer(), 256);
queue1.freeBuffer();
memcpy(buffer+256, queue1.readBuffer(), 256);
// Write all 512 bytes to the SD card
frec.write(buffer, 512);
void stopRecording() {
// Stop adding any new data to the queue
queue1.end();
// Flush all existing remaining data from the queue
// Save to open file
frec.write((byte*)queue1.readBuffer(), 256);
// Close the file
frec.close();
mode = Mode::Ready;
void playAllRecordings() {
// Recording files are saved in the root directory
File dir = SD.open("/");
while (true) {
File entry = dir.openNextFile();
if (!entry) {
// no more files
entry.close();
int8_t len = strlen(entry.name());
if (strstr(strlwr(entry.name() + (len - 4)), ".raw")) {
Serial.print("Now playing ");
Serial.println(entry.name());
// Play a short beep before each message
waveform1.amplitude(0.5);
wait(250);
// Play the file
playRaw1.play(entry.name());
mode = Mode::Playing;
entry.close();
// Button is pressed again
if(buttonPlay.risingEdge() || buttonRecord.fallingEdge()) {
playRaw1.stop();
mode = Mode::Ready;
return;
// All files have been played
mode = Mode::Ready;
// Retrieve the current time from Teensy built-in RTC
time_t getTeensy3Time(){
return Teensy3Clock.get();
// Callback to assign timestamps for file system operations
void dateTime(uint16_t* date, uint16_t* time, uint8_t* ms10) {
// Return date using FS_DATE macro to format fields.
*date = FS_DATE(year(), month(), day());
// Return time using FS_TIME macro to format fields.
*time = FS_TIME(hour(), minute(), second());
// Return low time bits in units of 10 ms.
*ms10 = second() & 1 ? 100 : 0;
// Non-blocking delay, which pauses execution of main program logic,
// but while still listening for input
void wait(unsigned int milliseconds) {
elapsedMillis msec=0;
while (msec <= milliseconds) {
if (buttonRecord.fallingEdge()) Serial.println("Button (pin 0) Press");
if (buttonPlay.fallingEdge()) Serial.println("Button (pin 1) Press");
if (buttonRecord.risingEdge()) Serial.println("Button (pin 0) Release");
if (buttonPlay.risingEdge()) Serial.println("Button (pin 1) Release");
}void setup() {
}void setup() {
