problem with 4.0
playback through lappy not to bad hit or miss if file loads but cant hear the greeting via the phone hand set but do hear a bleep tone
can't get greeting to play at all cant even see where u can increase the gain either only get a long single bleep even put the greeting directly onto the sd card in wav 16bit, pcm, 44100 got the mic working super fine like to put on my own messages, in the code
it says below but it does nothing ???
// First, read the buttons
buttonRecord.update();
buttonPlay.update();
switch(mode){
case Mode::Ready:
// Falling edge occurs when the handset is lifted --> 611 telephone
if (buttonRecord.fallingEdge()) {
Serial.println("Handset lifted");
mode = Mode::prompting; print_mode();
else if(buttonPlay.fallingEdge()) {
//playAllRecordings();
playLastRecording();
I'm getting the same error and have followed all advice in this thread. The error I get is
'AudioPlaySdWavX' does not name a type; did you mean 'AudioPlaySdWav'?
I have pasted my code below. Does anyone have an idea on where I could be making an error?
Thanks
 * Audio Guestbook, Copyright (c) 2022 Playful Technology
 * Tested using a Teensy 4.0 with Teensy Audio Shield, although should work
 * with minor modifications on other similar hardware
 * When handset is lifted, a pre-recorded greeting message is played, followed by a tone.
 * Then, recording starts, and continues until the handset is replaced.
 * Playback button allows all messages currently saved on SD card through earpiece
 * Files are saved on SD card as 44.1kHz, 16-bit, mono signed integer RAW audio format
 * --> changed this to WAV recording, DD4WH 2022_07_31
 * --> added MTP support, which enables copying WAV files from the SD card via the USB connection, DD4WH 2022_08_01
 * Frank DD4WH, August 1st 2022
 * for a DBP 611 telephone (closed contact when handheld is lifted) & with recording to WAV file
 * contact for switch button 0 is closed when handheld is lifted
 * GNU GPL v3.0 license
#include <Bounce.h>
#include <TimeLib.h>
#include <MTP_Teensy.h>
#include "play_sd_wav.h" // local copy with fixes
// DEFINES
// Define pins used by Teensy Audio Shield
#define SDCARD_CS_PIN    10
#define SDCARD_MOSI_PIN  7
#define SDCARD_SCK_PIN   14
// And those used for inputs
#define HOOK_PIN 0
#define PLAYBACK_BUTTON_PIN 1
#define noINSTRUMENT_SD_WRITE
// GLOBALS
// Audio initialisation code can be generated using the GUI interface at https://www.pjrc.com/teensy/gui/
// Inputs
AudioSynthWaveform          waveform1; // To create the "beep" sfx
AudioInputI2S               i2s2; // I2S input from microphone on audio shield
AudioPlaySdWavX              playWav1; // Play 44.1kHz 16-bit PCM greeting WAV file
AudioRecordQueue            queue1; // Creating an audio buffer in memory before saving to SD
AudioMixer4                 mixer; // Allows merging several inputs to same output
AudioOutputI2S              i2s1; // I2S interface to Speaker/Line Out on Audio shield
AudioConnection patchCord1(waveform1, 0, mixer, 0); // wave to mixer
AudioConnection patchCord3(playWav1, 0, mixer, 1); // wav file playback mixer
AudioConnection patchCord4(mixer, 0, i2s1, 0); // mixer output to speaker (L)
AudioConnection patchCord6(mixer, 0, i2s1, 1); // mixer output to speaker (R)
AudioConnection patchCord5(i2s2, 0, queue1, 0); // mic input to queue (L)
AudioControlSGTL5000      sgtl5000_1;
// Filename to save audio recording on SD card
char filename[15];
// The file object itself
File frec;
// Use long 40ms debounce time on both switches
Bounce buttonRecord = Bounce(HOOK_PIN, 40);
Bounce buttonPlay = Bounce(PLAYBACK_BUTTON_PIN, 40);
// Keep track of current state of the device
enum Mode {Initialising, Ready, Prompting, Recording, Playing};
Mode mode = Mode::Initialising;
float beep_volume = 0.04f; // not too loud :-)
uint32_t MTPcheckInterval; // default value of device check interval [ms]
// variables for writing to WAV file
unsigned long ChunkSize = 0L;
unsigned long Subchunk1Size = 16;
unsigned int AudioFormat = 1;
unsigned int numChannels = 1;
unsigned long sampleRate = 44100;
unsigned int bitsPerSample = 16;
unsigned long byteRate = sampleRate*numChannels*(bitsPerSample/8);// samplerate x channels x (bitspersample / 8)
unsigned int blockAlign = numChannels*bitsPerSample/8;
unsigned long Subchunk2Size = 0L;
unsigned long recByteSaved = 0L;
unsigned long NumSamples = 0L;
byte byte1, byte2, byte3, byte4;
  while (!Serial && millis() < 5000) {
    // wait for serial port to connect.
  Serial.println("Serial set up correctly");
  Serial.printf("Audio block set to %d samples\n",AUDIO_BLOCK_SAMPLES);
  print_mode();
  // Configure the input pins
  pinMode(HOOK_PIN, INPUT_PULLUP);
  pinMode(PLAYBACK_BUTTON_PIN, INPUT_PULLUP);
  AudioMemory(60);
  sgtl5000_1.enable();
  // Define which input on the audio shield to use (AUDIO_INPUT_LINEIN / AUDIO_INPUT_MIC)
  //sgtl5000_1.adcHighPassFilterDisable(); //
  sgtl5000_1.volume(0.95);
  mixer.gain(0, 1.0f);
  mixer.gain(1, 1.0f);
  // Play a beep to indicate system is online
  waveform1.begin(beep_volume, 440, WAVEFORM_SINE);
  wait(1000);
  waveform1.amplitude(0);
  // Initialize the SD card
  SPI.setMOSI(SDCARD_MOSI_PIN);
  SPI.setSCK(SDCARD_SCK_PIN);
  if (!(SD.begin(SDCARD_CS_PIN)))
    while (1) {
    else Serial.println("SD card correctly initialized");
  // mandatory to begin the MTP session.
    MTP.begin();
  // Add SD Card
//    MTP.addFilesystem(SD, "SD Card");
    MTP.addFilesystem(SD, "Kais Audio guestbook"); // choose a nice name for the SD card volume to appear in your file explorer
    Serial.println("Added SD card via MTP");
    MTPcheckInterval = MTP.storage()->get_DeltaDeviceCheckTimeMS();
    // Value in dB
//  sgtl5000_1.micGain(15);
  sgtl5000_1.micGain(5); // much lower gain is required for the AOM5024 electret capsule
  // Synchronise the Time object used in the program code with the RTC time provider.
  // See https://github.com/PaulStoffregen/Time
  // Define a callback that will assign the correct datetime for any file system operations
  // (i.e. saving a new audio recording onto the SD card)
  FsDateTime::setCallback(dateTime);
  mode = Mode::Ready; print_mode();
  switch(mode){
    case Mode::Ready:
        mode = Mode::Prompting; print_mode();
    case Mode::Prompting:
      // Wait a second for users to put the handset to their ear
      wait(1000);
      // Play the greeting inviting them to record their message
      playWav1.play("greeting.wav");
      // Wait until the  message has finished playing
//      while (playWav1.isPlaying()) {
      while (!playWav1.isStopped()) {
        // Check whether the handset is replaced
        // Handset is replaced
        if(buttonRecord.risingEdge()) {
          playWav1.stop();
          return;
          playWav1.stop();
          return;
      // Debug message
      Serial.println("Starting Recording");
      // Play the tone sound effect
      wait(1250);
      // Start the recording function
      startRecording();
    case Mode::Recording:
      if(buttonRecord.risingEdge()){
        // Debug log
        Serial.println("Stopping Recording");
        // Stop recording
        stopRecording();
        // Play audio tone to confirm recording has ended
        end_Beep();
      else {
        continueRecording();
    case Mode::Playing: // to make compiler happy
    case Mode::Initialising: // to make compiler happy
  MTP.loop();  // This is mandatory to be placed in the loop code.
void setMTPdeviceChecks(bool nable)
  if (nable)
    MTP.storage()->set_DeltaDeviceCheckTimeMS(MTPcheckInterval);
    Serial.print("En");
    MTP.storage()->set_DeltaDeviceCheckTimeMS((uint32_t) -1);
    Serial.print("Dis");
  Serial.println("abled MTP storage device checks");
#if defined(INSTRUMENT_SD_WRITE)
static uint32_t worstSDwrite, printNext;
#endif // defined(INSTRUMENT_SD_WRITE)
void startRecording() {
  setMTPdeviceChecks(false); // disable MTP device checks while recording
  worstSDwrite = 0;
  printNext = 0;
  // Find the first available file number
//  for (uint8_t i=0; i<9999; i++) { // BUGFIX uint8_t overflows if it reaches 255
  for (uint16_t i=0; i<9999; i++) {
    // Format the counter as a five-digit number with leading zeroes, followed by file extension
    snprintf(filename, 11, " %05d.wav", i);
    // Create if does not exist, do not open existing, write, sync after write
    if (!SD.exists(filename)) {
  frec = SD.open(filename, FILE_WRITE);
  Serial.println("Opened file !");
  if(frec) {
    Serial.print("Recording to ");
    Serial.println(filename);
    queue1.begin();
    mode = Mode::Recording; print_mode();
    recByteSaved = 0L;
  else {
    Serial.println("Couldn't open file to record!");
void continueRecording() {
  uint32_t started = micros();
#define NBLOX 16
  // Check if there is data in the queue
  if (queue1.available() >= NBLOX) {
    byte buffer[NBLOX*AUDIO_BLOCK_SAMPLES*sizeof(int16_t)];
    // into a 512 byte buffer.  The Arduino SD library
    // writes are used.
    for (int i=0;i<NBLOX;i++)
      memcpy(buffer+i*AUDIO_BLOCK_SAMPLES*sizeof(int16_t), queue1.readBuffer(), AUDIO_BLOCK_SAMPLES*sizeof(int16_t));
      queue1.freeBuffer();
    // Write all 512 bytes to the SD card
    frec.write(buffer, sizeof buffer);
    recByteSaved += sizeof buffer;
  started = micros() - started;
  if (started > worstSDwrite)
    worstSDwrite = started;
  if (millis() >= printNext)
    Serial.printf("Worst write took %luus\n",worstSDwrite);
    worstSDwrite = 0;
    printNext = millis()+250;
void stopRecording() {
  // Stop adding any new data to the queue
  queue1.end();
  // Flush all existing remaining data from the queue
    // Save to open file
    frec.write((byte*)queue1.readBuffer(), AUDIO_BLOCK_SAMPLES*sizeof(int16_t));
    recByteSaved += AUDIO_BLOCK_SAMPLES*sizeof(int16_t);
  writeOutHeader();
  // Close the file
  frec.close();
  Serial.println("Closed file");
  setMTPdeviceChecks(true); // enable MTP device checks, recording is finished
void playAllRecordings() {
  // Recording files are saved in the root directory
  File dir = SD.open("/");
  while (true) {
    File entry =  dir.openNextFile();
    if (strstr(entry.name(), "greeting"))
    if (!entry) {
      // no more files
      entry.close();
      end_Beep();
    //int8_t len = strlen(entry.name()) - 4;
//    if (strstr(strlwr(entry.name() + (len - 4)), ".raw")) {
//    if (strstr(strlwr(entry.name() + (len - 4)), ".wav")) {
    // the lines above throw a warning, so I replace them with this (which is also easier to read):
    if (strstr(entry.name(), ".wav") || strstr(entry.name(), ".WAV")) {
      Serial.print("Now playing ");
      Serial.println(entry.name());
      // Play a short beep before each message
      waveform1.amplitude(beep_volume);
      wait(750);
      // Play the file
      playWav1.play(entry.name());
      mode = Mode::Playing; print_mode();
    entry.close();
//    while (playWav1.isPlaying()) { // strangely enough, this works for playRaw, but it does not work properly for playWav
    while (!playWav1.isStopped()) { // this works for playWav
      // Button is pressed again
//      if(buttonPlay.risingEdge() || buttonRecord.risingEdge()) { // FIX
      if(buttonPlay.fallingEdge() || buttonRecord.risingEdge()) {
        playWav1.stop();
        return;
  // All files have been played
void playLastRecording() {
  uint16_t idx = 0;
    // check, if file with index i exists
     idx = i - 1;
      // now play file with index idx == last recorded file
      snprintf(filename, 11, " %05d.wav", idx);
      playWav1.play(filename);
        playWav1.stop();
        return;
      // file has been played
  end_Beep();
// Retrieve the current time from Teensy built-in RTC
time_t getTeensy3Time(){
  return Teensy3Clock.get();
// Callback to assign timestamps for file system operations
void dateTime(uint16_t* date, uint16_t* time, uint8_t* ms10) {
  // Return date using FS_DATE macro to format fields.
  *date = FS_DATE(year(), month(), day());
  // Return time using FS_TIME macro to format fields.
  *time = FS_TIME(hour(), minute(), second());
  // Return low time bits in units of 10 ms.
  *ms10 = second() & 1 ? 100 : 0;
// Non-blocking delay, which pauses execution of main program logic,
// but while still listening for input
void wait(unsigned int milliseconds) {
  elapsedMillis msec=0;
  while (msec <= milliseconds) {
    if (buttonRecord.fallingEdge()) Serial.println("Button (pin 0) Press");
    if (buttonPlay.fallingEdge()) Serial.println("Button (pin 1) Press");
    if (buttonRecord.risingEdge()) Serial.println("Button (pin 0) Release");
    if (buttonPlay.risingEdge()) Serial.println("Button (pin 1) Release");
void writeOutHeader() { // update WAV header with final filesize/datasize
//  NumSamples = (recByteSaved*8)/bitsPerSample/numChannels;
//  Subchunk2Size = NumSamples*numChannels*bitsPerSample/8; // number of samples x number of channels x number of bytes per sample
  Subchunk2Size = recByteSaved - 42; // because we didn't make space for the header to start with! Lose 21 samples...
  ChunkSize = Subchunk2Size + 34; // was 36;
  frec.seek(0);
  frec.write("RIFF");
  byte1 = ChunkSize & 0xff;
  byte2 = (ChunkSize >> 8) & 0xff;
  byte3 = (ChunkSize >> 16) & 0xff;
  byte4 = (ChunkSize >> 24) & 0xff;
  frec.write(byte1);  frec.write(byte2);  frec.write(byte3);  frec.write(byte4);
  frec.write("WAVE");
  frec.write("fmt ");
  byte1 = Subchunk1Size & 0xff;
  byte2 = (Subchunk1Size >> 8) & 0xff;
  byte3 = (Subchunk1Size >> 16) & 0xff;
  byte4 = (Subchunk1Size >> 24) & 0xff;
  byte1 = AudioFormat & 0xff;
  byte2 = (AudioFormat >> 8) & 0xff;
  byte1 = numChannels & 0xff;
  byte2 = (numChannels >> 8) & 0xff;
  byte1 = sampleRate & 0xff;
  byte2 = (sampleRate >> 8) & 0xff;
  byte3 = (sampleRate >> 16) & 0xff;
  byte4 = (sampleRate >> 24) & 0xff;
  byte1 = byteRate & 0xff;
  byte2 = (byteRate >> 8) & 0xff;
  byte3 = (byteRate >> 16) & 0xff;
  byte4 = (byteRate >> 24) & 0xff;
  byte1 = blockAlign & 0xff;
  byte2 = (blockAlign >> 8) & 0xff;
  byte1 = bitsPerSample & 0xff;
  byte2 = (bitsPerSample >> 8) & 0xff;
  frec.write("data");
  byte1 = Subchunk2Size & 0xff;
  byte2 = (Subchunk2Size >> 8) & 0xff;
  byte3 = (Subchunk2Size >> 16) & 0xff;
  byte4 = (Subchunk2Size >> 24) & 0xff;
  frec.close();
  Serial.println("header written");
  Serial.print("Subchunk2: ");
  Serial.println(Subchunk2Size);
void end_Beep(void) {
          waveform1.frequency(523.25);
        wait(250);
        wait(250);
        wait(250);
        wait(250);
        wait(250);
        wait(250);
        wait(250);
void print_mode(void) { // only for debugging
  Serial.print("Mode switched to: ");
  // Initialising, Ready, Prompting, Recording, Playing
  if(mode == Mode::Ready)           Serial.println(" Ready");
  else if(mode == Mode::Prompting)  Serial.println(" Prompting");
  else if(mode == Mode::Recording)  Serial.println(" Recording");
  else if(mode == Mode::Playing)    Serial.println(" Playing");
  else if(mode == Mode::Initialising)  Serial.println(" Initialising");
  else Serial.println(" Undefined");
