Programming a Teensy 1.0 in 2026
Vam
Hi, I have an old OG Teensy that I would like to use in a current project.
Teensyduino doesn't support it, and a cursory search about the AT90USB162 was not fruitful...
Is it still possible to program these nowadays ?
My main machine is an Apple Silicon Mac. I have an old Win XP netbook that could be used if I can put my hands on legacy software...
Teensyduino 1.18 was the last version with support for Teensy 1.0. Good news is the files are still on the PJRC server. Here's a link you can use to download them.
Arduino IDE was at version 1.0.5 back then. I found those files and put them into that directory on the server so you can get everything needed with 1 easy download.
I'd be amazed if this stuff could run on modern MacOS, even using Rosetta2. Linux version is also unlikely on modern Linux. I believe back then the IDE didn't ship with a Java JRE on Linux. Windows truly is the king of backwards compatibility. Just by guessing, I'd give it a 50-50 chance on Windows 10 or 11.
