mjs513
Senior Member+
Ok tonton81. Hooked up the LC to T3.5 and checked wiring a bunch of times and while the master is firing I am not seeing anything come through on the slave. I am running the slave at 48MH, the master I tried at 120, 144 and 168MHz with 4/6Mhz SPI speed. I am on SPI0. I did change SPI=0 in the cpp file, or are we limited to SPI1 for F&F example?
Keep getting low memory warnings when using faster. Also am seeing startup problems - doesn't want to come on line.
Mike
Mike
