defragster
Senior Member+
AFAIK: If the non-blocking libraries that could be used don't support that fixed pin, it would have to be changed to a new pin that is supported.
Eventually I found a way to switch the pin. It works now thank you so much for your help
Compiling 'WavFilePlayerVarSpd' for 'Teensy 4.1 (teensy41)'
Build Folder: "file:///C:/Users/justi/AppData/Local/Temp/VMBuilds/WavFilePlayerVarSpd/teensy41/Release"
WavFilePlayerVarSpd.ino: 95:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
95 | char* _filename = "RECORD.RAW"
WavFilePlayerVarSpd.ino: In function void getMIDI()
WavFilePlayerVarSpd.ino: 468:9: warning: unused variable 'type' [-Wunused-variable]
468 | int type, note, velocity, channel, d1, d2
IndexableSDFile.h:5: In file included from
ResamplingSdReader.h:13: from
teensyvariableplayback.h:9: from
WavFilePlayerVarSpd.ino:8: from
IndexableFile.h: In instantiation of newdigate::IndexableFile<BUFFER_SIZE, MAX_NUM_BUFFERS, TFile>::IndexableFile(const char*) [with unsigned int BUFFER_SIZE = 128; unsigned int MAX_NUM_BUFFERS = 4; TFile = File]
IndexableSDFile.h:17: required from newdigate IndexableSDFile<BUFFER_SIZE, MAX_NUM_BUFFERS> IndexableSDFile(const char*) [with unsigned int BUFFER_SIZE = 128; unsigned int MAX_NUM_BUFFERS = 4]
ResamplingSdReader.h:62: required from here
IndexableFile.h: 92:33: warning: 'newdigate::IndexableFile<128, 4, File>::_buffers' will be initialized after [-Wreorder]
vector<indexedbuffer*> _buffers
IndexableFile.h: 29:12: warning: 'size_t newdigate::IndexableFile<128, 4, File>::buffer_to_index_shift' [-Wreorder]
29 | size_t buffer_to_index_shift
IndexableFile.h: 30:5: warning: when initialized here [-Wreorder]
30 | IndexableFile(const char *filename)
IndexableFile.h: In instantiation of newdigate::IndexableFile<BUFFER_SIZE, MAX_NUM_BUFFERS, TFile>::IndexableFile(const char*) [with unsigned int BUFFER_SIZE = 128; unsigned int MAX_NUM_BUFFERS = 2; TFile = File]
IndexableLittleFSFile.h:18: required from newdigate IndexableLittleFSFile<BUFFER_SIZE, MAX_NUM_BUFFERS> IndexableLittleFSFile(LittleFS&, const char*) [with unsigned int BUFFER_SIZE = 128; unsigned int MAX_NUM_BUFFERS = 2]
ResamplingLfsReader.h:59: required from here
IndexableFile.h: 92:33: warning: 'newdigate::IndexableFile<128, 2, File>::_buffers' will be initialized after [-Wreorder]
IndexableFile.h: 29:12: warning: 'size_t newdigate::IndexableFile<128, 2, File>::buffer_to_index_shift' [-Wreorder]
IndexableFile.h: In instantiation of newdigate::IndexableFile<BUFFER_SIZE, MAX_NUM_BUFFERS, TFile>::IndexableFile(const char*) [with unsigned int BUFFER_SIZE = 128; unsigned int MAX_NUM_BUFFERS = 2; TFile = SerialFlashFile]
IndexableSerialFlashFile.h:18: required from newdigate IndexableSerialFlashFile<BUFFER_SIZE, MAX_NUM_BUFFERS> IndexableSerialFlashFile(SerialFlashChip&, const char*) [with unsigned int BUFFER_SIZE = 128; unsigned int MAX_NUM_BUFFERS = 2]
ResamplingSerialFlashReader.h:63: required from here
IndexableFile.h: 92:33: warning: 'newdigate::IndexableFile<128, 2, SerialFlashFile>::_buffers' will be initialized after [-Wreorder]
IndexableFile.h: 29:12: warning: 'size_t newdigate::IndexableFile<128, 2, SerialFlashFile>::buffer_to_index_shift' [-Wreorder]
ResamplingSdReader.h:14: In file included from
ResamplingReader.h: In instantiation of bool newdigate::ResamplingReader<TArray, TFile>::play(const char*, bool, uint16_t) [with TArray = newdigate::IndexableSDFile<128, 4>; TFile = File; uint16_t = short unsigned int]
playresmp.h:27: required from bool AudioPlayResmp<TResamplingReader> playRaw(const char*, uint16_t) [with TResamplingReader = newdigate ResamplingSdReader; uint16_t = short unsigned int]
WavFilePlayerVarSpd.ino:323: required from here
ResamplingReader.h: 88:20: warning: variable 'bytesRead' set but not used [-Wunused-but-set-variable]
88 | size_t bytesRead = file.read(buffer, 36)
ResamplingReader.h: 120:24: warning: comparison of integer expressions of different signedness: 'int32_t' {aka 'long int'} and 'long unsigned int' [-Wsign-compare]
120 | if (_file_size <= _header_offset * sizeof(int16_t)) {
playsdresmp.h:14: In file included from
teensyvariableplayback.h:13: from
playresmp.h: In instantiation of void AudioPlayResmp<TResamplingReader>::update() [with TResamplingReader = newdigate::ResamplingSerialFlashReader]
playresmp.h:100: required from here
playresmp.h: 106:26: warning: unused variable 'i' [-Wunused-variable]
106 | unsigned int i, n
playresmp.h: In instantiation of void AudioPlayResmp<TResamplingReader>::update() [with TResamplingReader = newdigate::ResamplingLfsReader]
playresmp.h: In instantiation of void AudioPlayResmp<TResamplingReader>::update() [with TResamplingReader = newdigate::ResamplingArrayReader]
playresmp.h: In instantiation of void AudioPlayResmp<TResamplingReader>::update() [with TResamplingReader = newdigate::ResamplingSdReader]
ResamplingReader.h: In instantiation of bool newdigate::ResamplingReader<TArray, TFile>::readNextValue(int16_t*, uint16_t) [with TArray = newdigate::IndexableSerialFlashFile<128, 2>; TFile = SerialFlashFile; int16_t = short int; uint16_t = short unsigned int]
ResamplingReader.h:172: required from unsigned int newdigate ResamplingReader<TArray, TFile> read(void**, uint16_t) [with TArray = newdigate IndexableSerialFlashFile<128, 2>; TFile = SerialFlashFile; uint16_t = short unsigned int]
playresmp.h:121: required from void AudioPlayResmp<TResamplingReader> update() [with TResamplingReader = newdigate ResamplingSerialFlashReader]
ResamplingReader.h: 241:59: warning: comparison of integer expressions of different signedness: 'int' and 'long unsigned int' [-Wsign-compare]
241 | if (_crossfade == 0.0 && _bufferPosition1 > (_loop_finish - _numChannels) - _crossfadeDurationInSamples) {
ResamplingReader.h: 245:66: warning: comparison of integer expressions of different signedness: 'int' and 'long unsigned int' [-Wsign-compare]
245 | } else if (_crossfade == 1.0 && _bufferPosition2 > (_loop_finish - _numChannels)- _crossfadeDurationInSamples) {
ResamplingReader.h: 263:59: warning: comparison of integer expressions of different signedness: 'int' and 'long unsigned int' [-Wsign-compare]
263 | if (_crossfade == 0.0 && _bufferPosition1 < _crossfadeDurationInSamples + _header_offset) {
ResamplingReader.h: 267:66: warning: comparison of integer expressions of different signedness: 'int' and 'long unsigned int' [-Wsign-compare]
267 | } else if (_crossfade == 1.0 && _bufferPosition2 < _crossfadeDurationInSamples + _header_offset) {
ResamplingReader.h: In instantiation of bool newdigate::ResamplingReader<TArray, TFile>::readNextValue(int16_t*, uint16_t) [with TArray = newdigate::IndexableLittleFSFile<128, 2>; TFile = File; int16_t = short int; uint16_t = short unsigned int]
ResamplingReader.h:172: required from unsigned int newdigate ResamplingReader<TArray, TFile> read(void**, uint16_t) [with TArray = newdigate IndexableLittleFSFile<128, 2>; TFile = File; uint16_t = short unsigned int]
playresmp.h:121: required from void AudioPlayResmp<TResamplingReader> update() [with TResamplingReader = newdigate ResamplingLfsReader]
ResamplingReader.h: In instantiation of bool newdigate::ResamplingReader<TArray, TFile>::readNextValue(int16_t*, uint16_t) [with TArray = short int; TFile = File; int16_t = short int; uint16_t = short unsigned int]
ResamplingReader.h:172: required from unsigned int newdigate ResamplingReader<TArray, TFile> read(void**, uint16_t) [with TArray = short int; TFile = File; uint16_t = short unsigned int]
playresmp.h:121: required from void AudioPlayResmp<TResamplingReader> update() [with TResamplingReader = newdigate ResamplingArrayReader]
ResamplingReader.h: In instantiation of bool newdigate::ResamplingReader<TArray, TFile>::readNextValue(int16_t*, uint16_t) [with TArray = newdigate::IndexableSDFile<128, 4>; TFile = File; int16_t = short int; uint16_t = short unsigned int]
ResamplingReader.h:172: required from unsigned int newdigate ResamplingReader<TArray, TFile> read(void**, uint16_t) [with TArray = newdigate IndexableSDFile<128, 4>; TFile = File; uint16_t = short unsigned int]
playresmp.h:121: required from void AudioPlayResmp<TResamplingReader> update() [with TResamplingReader = newdigate ResamplingSdReader]
Warning*: for Arduino 1.8.x, Teensyduino must be installed with a special installer
Boards Manager installation give incomplete setup!
Download the Installer at https*: www.pjrc.com\teensy\td_download.html
Opening Teensy Loader
teensy_size: Memory Usage on Teensy 4.1:
teensy_size: FLASH: code:165900, data:39596, headers:8516 free for files:7912452
teensy_size: RAM1: variables:45344, code:162324, padding:1516 free for local variables:315104
teensy_size: RAM2: variables:24928 free for malloc/new:499360
Uploading 'WavFilePlayerVarSpd' to 'Teensy 4.1 (teensy41)' using 'usb:0/140000/0/2/2/2/3'
Warning: for Arduino 1.8.x, Teensyduino must be installed with a special installer.
Download the Installer at https://www.pjrc.com/teensy/td_download.html
The upload process has finished.
Summary: Header=1 Prototypes=1 Imports=0
Additional Defines:
Architecture Tools: "file:///c://Users//justi//AppData//Local//Arduino15//packages//teensy//tools//teensy-compile//11.3.1/"
Api: 2.2024.0223-0
Sketch Book: "file:///d:/ArduinoProjects"
User Libraries: "file:///d:/ArduinoProjects/libraries"
Build Temp: "file:///C:/Users/justi/AppData/Local/Temp/VMBuilds/WavFilePlayerVarSpd/teensy41/Release"
Board Support Urls: "https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json,https://www.pjrc.com/teensy/package_teensy_index.json"
Core Include Paths
Include Path "file:///c:/Users/justi/AppData/Local/Arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4"
Deep search for libraries ...
Using previous search results: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\WavFilePlayerVarSpd.cpp
Using previous search results: d:\ArduinoProjects\libraries\EncoderButton\src\EncoderButton.cpp
Using previous search results: d:\ArduinoProjects\libraries\Encoder\Encoder.cpp
Using previous search results: d:\ArduinoProjects\libraries\Bounce2\src\Bounce2.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\analyze_fft1024.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\analyze_fft256.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\analyze_notefreq.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\analyze_peak.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\analyze_print.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\analyze_rms.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\analyze_tonedetect.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\async_input_spdif3.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\control_ak4558.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Wire\Wire.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Wire\WireIMXRT.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Wire\WireKinetis.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\control_cs42448.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\control_cs4272.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\control_sgtl5000.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\control_tlv320aic3206.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\control_wm8731.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\data_bandlimit_step.c
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\data_spdif.c
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\data_ulaw.c
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\data_waveforms.c
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\data_windows.c
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_bitcrusher.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_chorus.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_combine.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_delay.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_delay_ext.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_envelope.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_fade.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_flange.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_freeverb.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_granular.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_midside.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_multiply.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_rectifier.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_reverb.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_wavefolder.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\effect_waveshaper.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\filter_biquad.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\filter_fir.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\filter_ladder.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\filter_variable.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\input_adc.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\input_adcs.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\input_i2s.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\input_i2s2.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\input_i2s_hex.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\input_i2s_oct.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\input_i2s_quad.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\input_pdm.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\input_pdm_i2s2.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\input_spdif3.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\input_tdm.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\input_tdm2.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\mixer.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_adat.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_dac.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_dacs.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_i2s.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_i2s2.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_i2s_hex.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_i2s_oct.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_i2s_quad.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_mqs.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_pt8211.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_pt8211_2.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_pwm.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_spdif.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_spdif2.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_spdif3.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_tdm.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\output_tdm2.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\play_memory.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\play_queue.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\play_sd_raw.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\play_sd_wav.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\play_serialflash_raw.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\Quantizer.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\record_queue.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\Resampler.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\spi_interrupt.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\synth_dc.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\synth_karplusstrong.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\synth_pinknoise.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\synth_pwm.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\synth_simple_drum.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\synth_sine.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\synth_tonesweep.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\synth_waveform.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\synth_wavetable.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\synth_whitenoise.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI\SPI.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SD\src\SD.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SdFat\src\FreeStack.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SdFat\src\MinimumSerial.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SerialFlash\SerialFlashChip.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SerialFlash\SerialFlashDirectory.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\MIDI\src\MIDI.cpp
Using previous search results: d:\ArduinoProjects\libraries\TeensyVariablePlayback\src\interpolation.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\LittleFS\src\LittleFS.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\LittleFS\src\LittleFS_NAND.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\ILI9341_t3\font_Arial.c
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\ILI9341_t3\font_ArialBold.c
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\ILI9341_t3\glcdfont.c
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\ILI9341_t3\ILI9341_t3.cpp
Using previous search results: c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\XPT2046_Touchscreen\XPT2046_Touchscreen.cpp
Using previous search results: d:\ArduinoProjects\libraries\TeensyTimerTool\src\config.cpp
Using previous search results: d:\ArduinoProjects\libraries\FastLED\src\bitswap.cpp
Using previous search results: d:\ArduinoProjects\libraries\FastLED\src\colorpalettes.cpp
Using previous search results: d:\ArduinoProjects\libraries\FastLED\src\colorutils.cpp
Using previous search results: d:\ArduinoProjects\libraries\FastLED\src\FastLED.cpp
Using previous search results: d:\ArduinoProjects\libraries\FastLED\src\hsv2rgb.cpp
Using previous search results: d:\ArduinoProjects\libraries\FastLED\src\lib8tion.cpp
Using previous search results: d:\ArduinoProjects\libraries\FastLED\src\noise.cpp
Using previous search results: d:\ArduinoProjects\libraries\FastLED\src\platforms.cpp
Using previous search results: d:\ArduinoProjects\libraries\FastLED\src\power_mgt.cpp
Using previous search results: d:\ArduinoProjects\libraries\FastLED\src\wiring.cpp
Extracting .ino prototypes ...
"d:\microsoft visual studio\2022\community\common7\ide\extensions\jydagq0n.l0f\Micro Platforms\visualmicro\tools\ctags/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/sketch-gcc-e-clean.cpp.filtered.cpp"
serialMIDI C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^midi::SerialMIDI<HardwareSerial> serialMIDI(Serial1); midi::MidiInterface<midi::SerialMIDI<HardwareSerial>> MIDI((midi::SerialMIDI<HardwareSerial>&)serialMIDI);;$/;" kind:prototype line:35 signature:(Serial1) returntype:midi::SerialMIDI
MidiInterface C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^midi::SerialMIDI<HardwareSerial> serialMIDI(Serial1); midi::MidiInterface<midi::SerialMIDI<HardwareSerial>> MIDI((midi::SerialMIDI<HardwareSerial>&)serialMIDI);;$/;" kind:prototype line:35 signature:(midi::SerialMIDI<HardwareSerial>&)serialMIDI
channel C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^const int channel = 1;$/;" kind:variable line:36
tft C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^ILI9341_t3 tft = ILI9341_t3(10, 9);$/;" kind:variable line:39
wastouched C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^boolean wastouched = true;$/;" kind:variable line:43
E0Value C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^int E0Value = 0;$/;" kind:variable line:48
E1Value C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^int E1Value = 100;$/;" kind:variable line:49
lpStart C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^int lpStart;$/;" kind:variable line:51
lpEnd C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^int lpEnd;$/;" kind:variable line:52
totalSamples C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^int totalSamples = 0;$/;" kind:variable line:54
prevE0 C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^int prevE0 = 0;$/;" kind:variable line:56
rate C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^float rate = 1.0;$/;" kind:variable line:58
xPos C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^int xPos = 10, xPosPrev = 10;$/;" kind:variable line:62
xPosPrev C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^int xPos = 10, xPosPrev = 10;$/;" kind:variable line:62
graphHeightPrev C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^int graphHeightPrev = 130;$/;" kind:variable line:63
currentKey C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^int currentKey = 0;$/;" kind:variable line:65
myFrame C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^int myFrame = 0;$/;" kind:variable line:66
frec C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^File frec;$/;" kind:variable line:72
mapf C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^double mapf(double val, double in_min, double in_max, double out_min, double out_max)$/;" kind:function line:74 signature:(double val, double in_min, double in_max, double out_min, double out_max) returntype:double
playSdWav1 C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^AudioPlaySdResmp playSdWav1;$/;" kind:variable line:80
i2s2 C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^AudioOutputI2S i2s2;$/;" kind:variable line:81
usb1 C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^AudioOutputUSB usb1;$/;" kind:variable line:82
patchCord1 C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^AudioConnection patchCord1(playSdWav1, 0, i2s2, 0);$/;" kind:prototype line:83 signature:(playSdWav1, 0, i2s2, 0) returntype:AudioConnection
patchCord2 C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^AudioConnection patchCord2(playSdWav1, 0, usb1, 0);$/;" kind:prototype line:84 signature:(playSdWav1, 0, usb1, 0) returntype:AudioConnection
patchCord3 C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^AudioConnection patchCord3(playSdWav1, 1, i2s2, 1);$/;" kind:prototype line:85 signature:(playSdWav1, 1, i2s2, 1) returntype:AudioConnection
patchCord4 C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^AudioConnection patchCord4(playSdWav1, 1, usb1, 1);$/;" kind:prototype line:86 signature:(playSdWav1, 1, usb1, 1) returntype:AudioConnection
audioShield C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^AudioControlSGTL5000 audioShield;$/;" kind:variable line:87
_filename C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^char* _filename = "RECORD.RAW";$/;" kind:variable line:95
analogInPin C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^const int analogInPin = 10;$/;" kind:variable line:97
lastSamplePlayed C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^unsigned long lastSamplePlayed = 0;$/;" kind:variable line:98
getPlaybackRate C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^double getPlaybackRate(int16_t analog) {$/;" kind:function line:100 signature:(int16_t analog) returntype:double
setup C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^void setup()$/;" kind:function line:104 signature:() returntype:void
loop C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^void loop()$/;" kind:function line:176 signature:() returntype:void
onEb1Clicked C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^void onEb1Clicked(EncoderButton& eb)$/;" kind:function line:289 signature:(EncoderButton& eb) returntype:void
onEb1Encoder C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^void onEb1Encoder(EncoderButton& eb)$/;" kind:function line:299 signature:(EncoderButton& eb) returntype:void
onEb0Clicked C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^void onEb0Clicked(EncoderButton& eb)$/;" kind:function line:316 signature:(EncoderButton& eb) returntype:void
onEb0Encoder C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^void onEb0Encoder(EncoderButton& eb)$/;" kind:function line:332 signature:(EncoderButton& eb) returntype:void
dispWavefile C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^void dispWavefile()$/;" kind:function line:367 signature:() returntype:void
showWaveform C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^void showWaveform()$/;" kind:function line:394 signature:() returntype:void
sendMIDITest C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^void sendMIDITest()$/;" kind:function line:454 signature:() returntype:void
getMIDI C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/.vmpreproc/D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino /^void getMIDI()$/;" kind:function line:466 signature:() returntype:void
Required: False, Prototype: midi::SerialMIDI serialMIDI(Serial1);, Function: serialMIDI, Kind: prototype, Line: 35, Signature: (Serial1), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: midi::SerialMIDI<HardwareSerial> serialMIDI(Serial1); midi::MidiInterface<midi::SerialMIDI<HardwareSerial>> MIDI((midi::SerialMIDI<HardwareSerial>&)serialMIDI);;
Required: False, Prototype: MidiInterface(midi::SerialMIDI<HardwareSerial>&)serialMIDI;, Function: MidiInterface, Kind: prototype, Line: 35, Signature: (midi::SerialMIDI<HardwareSerial>&)serialMIDI, File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: midi::SerialMIDI<HardwareSerial> serialMIDI(Serial1); midi::MidiInterface<midi::SerialMIDI<HardwareSerial>> MIDI((midi::SerialMIDI<HardwareSerial>&)serialMIDI);;
Required: False, Prototype: channel;, Function: channel, Kind: variable, Line: 36, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: const int channel = 1;
Required: False, Prototype: tft;, Function: tft, Kind: variable, Line: 39, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: ILI9341_t3 tft = ILI9341_t3(10, 9);
Required: False, Prototype: wastouched;, Function: wastouched, Kind: variable, Line: 43, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: boolean wastouched = true;
Required: False, Prototype: E0Value;, Function: E0Value, Kind: variable, Line: 48, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: int E0Value = 0;
Required: False, Prototype: E1Value;, Function: E1Value, Kind: variable, Line: 49, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: int E1Value = 100;
Required: False, Prototype: lpStart;, Function: lpStart, Kind: variable, Line: 51, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: int lpStart;
Required: False, Prototype: lpEnd;, Function: lpEnd, Kind: variable, Line: 52, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: int lpEnd;
Required: False, Prototype: totalSamples;, Function: totalSamples, Kind: variable, Line: 54, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: int totalSamples = 0;
Required: False, Prototype: prevE0;, Function: prevE0, Kind: variable, Line: 56, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: int prevE0 = 0;
Required: False, Prototype: rate;, Function: rate, Kind: variable, Line: 58, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: float rate = 1.0;
Required: False, Prototype: xPos;, Function: xPos, Kind: variable, Line: 62, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: int xPos = 10, xPosPrev = 10;
Required: False, Prototype: xPosPrev;, Function: xPosPrev, Kind: variable, Line: 62, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: int xPos = 10, xPosPrev = 10;
Required: False, Prototype: graphHeightPrev;, Function: graphHeightPrev, Kind: variable, Line: 63, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: int graphHeightPrev = 130;
Required: False, Prototype: currentKey;, Function: currentKey, Kind: variable, Line: 65, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: int currentKey = 0;
Required: False, Prototype: myFrame;, Function: myFrame, Kind: variable, Line: 66, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: int myFrame = 0;
Required: False, Prototype: frec;, Function: frec, Kind: variable, Line: 72, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: File frec;
Required: True, Prototype: double mapf(double val, double in_min, double in_max, double out_min, double out_max);, Function: mapf, Kind: function, Line: 74, Signature: (double val, double in_min, double in_max, double out_min, double out_max), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: double mapf(double val, double in_min, double in_max, double out_min, double out_max)
Required: False, Prototype: playSdWav1;, Function: playSdWav1, Kind: variable, Line: 80, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: AudioPlaySdResmp playSdWav1;
Required: False, Prototype: i2s2;, Function: i2s2, Kind: variable, Line: 81, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: AudioOutputI2S i2s2;
Required: False, Prototype: usb1;, Function: usb1, Kind: variable, Line: 82, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: AudioOutputUSB usb1;
Required: False, Prototype: AudioConnection patchCord1(playSdWav1, 0, i2s2, 0);, Function: patchCord1, Kind: prototype, Line: 83, Signature: (playSdWav1, 0, i2s2, 0), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: AudioConnection patchCord1(playSdWav1, 0, i2s2, 0);
Required: False, Prototype: AudioConnection patchCord2(playSdWav1, 0, usb1, 0);, Function: patchCord2, Kind: prototype, Line: 84, Signature: (playSdWav1, 0, usb1, 0), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: AudioConnection patchCord2(playSdWav1, 0, usb1, 0);
Required: False, Prototype: AudioConnection patchCord3(playSdWav1, 1, i2s2, 1);, Function: patchCord3, Kind: prototype, Line: 85, Signature: (playSdWav1, 1, i2s2, 1), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: AudioConnection patchCord3(playSdWav1, 1, i2s2, 1);
Required: False, Prototype: AudioConnection patchCord4(playSdWav1, 1, usb1, 1);, Function: patchCord4, Kind: prototype, Line: 86, Signature: (playSdWav1, 1, usb1, 1), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: AudioConnection patchCord4(playSdWav1, 1, usb1, 1);
Required: False, Prototype: audioShield;, Function: audioShield, Kind: variable, Line: 87, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: AudioControlSGTL5000 audioShield;
Required: False, Prototype: _filename;, Function: _filename, Kind: variable, Line: 95, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: char* _filename = "RECORD.RAW";
Required: False, Prototype: analogInPin;, Function: analogInPin, Kind: variable, Line: 97, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: const int analogInPin = 10;
Required: False, Prototype: lastSamplePlayed;, Function: lastSamplePlayed, Kind: variable, Line: 98, Signature: , File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: unsigned long lastSamplePlayed = 0;
Required: True, Prototype: double getPlaybackRate(int16_t analog);, Function: getPlaybackRate, Kind: function, Line: 100, Signature: (int16_t analog), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: double getPlaybackRate(int16_t analog) {
Required: True, Prototype: void setup();, Function: setup, Kind: function, Line: 104, Signature: (), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: void setup()
Required: True, Prototype: void loop();, Function: loop, Kind: function, Line: 176, Signature: (), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: void loop()
Required: True, Prototype: void onEb1Clicked(EncoderButton& eb);, Function: onEb1Clicked, Kind: function, Line: 289, Signature: (EncoderButton& eb), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: void onEb1Clicked(EncoderButton& eb)
Required: True, Prototype: void onEb1Encoder(EncoderButton& eb);, Function: onEb1Encoder, Kind: function, Line: 299, Signature: (EncoderButton& eb), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: void onEb1Encoder(EncoderButton& eb)
Required: True, Prototype: void onEb0Clicked(EncoderButton& eb);, Function: onEb0Clicked, Kind: function, Line: 316, Signature: (EncoderButton& eb), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: void onEb0Clicked(EncoderButton& eb)
Required: True, Prototype: void onEb0Encoder(EncoderButton& eb);, Function: onEb0Encoder, Kind: function, Line: 332, Signature: (EncoderButton& eb), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: void onEb0Encoder(EncoderButton& eb)
Required: True, Prototype: void dispWavefile();, Function: dispWavefile, Kind: function, Line: 367, Signature: (), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: void dispWavefile()
Required: True, Prototype: void showWaveform();, Function: showWaveform, Kind: function, Line: 394, Signature: (), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: void showWaveform()
Required: True, Prototype: void sendMIDITest();, Function: sendMIDITest, Kind: function, Line: 454, Signature: (), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: void sendMIDITest()
Required: True, Prototype: void getMIDI();, Function: getMIDI, Kind: function, Line: 466, Signature: (), File: D:\ArduinoProjects\WavFilePlayerVarSpd\WavFilePlayerVarSpd.ino, Code: void getMIDI()
recipe.hooks.sketch.prebuild.1.pattern
"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-tools\1.59.0/precompile_helper" "c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0/cores/teensy4" "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release" "c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=108010 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_MIDI_AUDIO_SERIAL -DLAYOUT_US_ENGLISH "-Ic:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0/cores/teensy4" "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/pch/Arduino.h" -o "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/pch/Arduino.h.gch"
Building core ...
Building libraries ...
Using library EncoderButton version 1.0.6 by Philip Fletcher <philip.fletcher@stutchbury.com> in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\EncoderButton\EncoderButton.cpp.o
Using library Encoder version 1.4.4 by Paul Stoffregen in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Encoder\Encoder.cpp.o
Using library Bounce2 version 2.71 by Thomas O Fredericks <tof@t-o-f.info> in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Bounce2\Bounce2.cpp.o
Using library Audio version 1.3 by Paul Stoffregen in folder ""
"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=108010 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_MIDI_AUDIO_SERIAL -DLAYOUT_US_ENGLISH -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4" -I"d:\ArduinoProjects\libraries\EncoderButton\src" -I"d:\ArduinoProjects\libraries\Encoder" -I"d:\ArduinoProjects\libraries\Bounce2\src" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SD\src" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SdFat\src" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SerialFlash" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\MIDI\src" -I"d:\ArduinoProjects\libraries\TeensyVariablePlayback\src" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\LittleFS\src" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\ILI9341_t3" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\XPT2046_Touchscreen" -I"d:\ArduinoProjects\libraries\TeensyTimerTool\src" -I"d:\ArduinoProjects\libraries\FastLED\src" -I"d:\ArduinoProjects\libraries\Encoder\utility" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\utility" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Wire" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Wire\utility" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI\utility" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SerialFlash\utility" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\ILI9341_t3\utility" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\XPT2046_Touchscreen\utility" -I"d:\ArduinoProjects\libraries\Encoder\utility" -I"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\utility" "c:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\Audio\memcpy_audio.S" -o "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\memcpy_audio.S.o"
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\pch\Arduino.h.gch
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\data_bandlimit_step.c.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\data_spdif.c.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\data_ulaw.c.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\data_waveforms.c.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\data_windows.c.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\analyze_fft1024.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\analyze_fft256.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\analyze_notefreq.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\analyze_peak.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\analyze_print.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\analyze_rms.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\analyze_tonedetect.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\async_input_spdif3.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\control_ak4558.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\control_cs42448.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\control_cs4272.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\control_sgtl5000.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\control_tlv320aic3206.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\control_wm8731.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_bitcrusher.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_chorus.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_combine.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_delay.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_delay_ext.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_envelope.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_fade.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_flange.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_freeverb.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_granular.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_midside.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_multiply.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_rectifier.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_reverb.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_wavefolder.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\effect_waveshaper.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\filter_biquad.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\filter_fir.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\filter_ladder.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\filter_variable.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\input_adc.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\input_adcs.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\input_i2s.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\input_i2s2.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\input_i2s_hex.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\input_i2s_oct.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\input_i2s_quad.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\input_pdm.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\input_pdm_i2s2.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\input_spdif3.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\input_tdm.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\input_tdm2.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\mixer.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_adat.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_dac.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_dacs.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_i2s.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_i2s2.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_i2s_hex.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_i2s_oct.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_i2s_quad.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_mqs.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_pt8211.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_pt8211_2.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_pwm.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_spdif.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_spdif2.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_spdif3.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_tdm.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\output_tdm2.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\play_memory.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\play_queue.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\play_sd_raw.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\play_sd_wav.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\play_serialflash_raw.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\Quantizer.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\record_queue.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\Resampler.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\spi_interrupt.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\synth_dc.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\synth_karplusstrong.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\synth_pinknoise.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\synth_pwm.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\synth_simple_drum.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\synth_sine.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\synth_tonesweep.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\synth_waveform.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\synth_wavetable.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\synth_whitenoise.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\utility\sqrt_integer.c.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Audio\utility\imxrt_hw.cpp.o
Using library SPI version 1.0 by Paul Stoffregen in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SPI\SPI.cpp.o
Using library SD version 2.0.0 by Paul Stoffregen in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SD\SD.cpp.o
Using library SdFat version 2.1.2 by Bill Greiman <fat16lib@sbcglobal.net> in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FreeStack.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\MinimumSerial.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\common\FmtNumber.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\common\FsCache.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\common\FsDateTime.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\common\FsName.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\common\FsStructs.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\common\FsUtf.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\common\PrintBasic.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\common\upcase.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\ExFatLib\ExFatDbg.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\ExFatLib\ExFatFile.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\ExFatLib\ExFatFilePrint.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\ExFatLib\ExFatFileWrite.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\ExFatLib\ExFatFormatter.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\ExFatLib\ExFatName.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\ExFatLib\ExFatPartition.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\ExFatLib\ExFatVolume.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\ExFatLib\upcase.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FatLib\FatDbg.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FatLib\FatFile.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FatLib\FatFileLFN.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FatLib\FatFilePrint.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FatLib\FatFileSFN.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FatLib\FatFormatter.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FatLib\FatName.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FatLib\FatPartition.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FatLib\FatVolume.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FsLib\FsFile.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FsLib\FsNew.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\FsLib\FsVolume.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\iostream\istream.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\iostream\ostream.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\iostream\StdioStream.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\iostream\StreamBaseClass.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\SdCard\SdCardInfo.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\SdCard\SdioTeensy.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\SdCard\SdSpiCard.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\SpiDriver\SdSpiArtemis.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\SpiDriver\SdSpiChipSelect.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\SpiDriver\SdSpiDue.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\SpiDriver\SdSpiESP.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\SpiDriver\SdSpiParticle.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\SpiDriver\SdSpiSTM32.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\SpiDriver\SdSpiSTM32Core.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SdFat\SpiDriver\SdSpiTeensy3.cpp.o
Using library SerialFlash version 0.5 by Paul Stoffregen in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SerialFlash\SerialFlashChip.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\SerialFlash\SerialFlashDirectory.cpp.o
Using library MIDI version 5.0.2 by Francois Best <contact@francoisbest.com> in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\MIDI\MIDI.cpp.o
Using library TeensyVariablePlayback version 1.0.16 by Nic Newdigate in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\TeensyVariablePlayback\interpolation.cpp.o
Using library LittleFS version 1.0.0 by Paul Stoffregen in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\LittleFS\LittleFS.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\LittleFS\LittleFS_NAND.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\LittleFS\littlefs\lfs.c.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\LittleFS\littlefs\lfs_util.c.o
Using library ILI9341_t3 version 1.0 by Paul Stoffregen in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\ILI9341_t3\font_Arial.c.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\ILI9341_t3\font_ArialBold.c.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\ILI9341_t3\glcdfont.c.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\ILI9341_t3\ILI9341_t3.cpp.o
Using library XPT2046_Touchscreen version 1.4 by Paul Stoffregen in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\XPT2046_Touchscreen\XPT2046_Touchscreen.cpp.o
Using library TeensyTimerTool version 1.4.1 by luni64 in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\TeensyTimerTool\config.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\TeensyTimerTool\API\baseTimer.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\TeensyTimerTool\API\Timer.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\TeensyTimerTool\ErrorHandling\error_handler.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\TeensyTimerTool\TimerModules\GPT\GPTChannel.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\TeensyTimerTool\TimerModules\PIT4\PIT.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\TeensyTimerTool\TimerModules\RTC\RTC.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\TeensyTimerTool\TimerModules\TCK\TCK.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\TeensyTimerTool\TimerModules\TCK\TckChannelBase.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\TeensyTimerTool\TimerModules\TCK\tickCounters.cpp.o
Using library FastLED version 3.6.0 by Daniel Garcia <dgarcia@fastled.io> in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\FastLED\bitswap.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\FastLED\colorpalettes.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\FastLED\colorutils.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\FastLED\FastLED.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\FastLED\hsv2rgb.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\FastLED\lib8tion.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\FastLED\noise.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\FastLED\platforms.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\FastLED\power_mgt.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\FastLED\wiring.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\FastLED\platforms\esp\32\clockless_rmt_esp32.cpp.o
Using library Wire version 1.0 by Paul Stoffregen in folder ""
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Wire\WireIMXRT.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Wire\WireKinetis.cpp.o
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\Wire\utility\twi.c.o
Building project code ...
Using previously compiled file: C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\WavFilePlayerVarSpd.cpp.o
Linking it all together ...
# Coping cached core C:\Users\justi\AppData\Local\Temp\VMBCore\arduino20x\994cb1ed4be50333da206576a2142dc1\core.a to C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release\core.a
"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-Tc:\Users\justi\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4/imxrt1062_t41.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/WavFilePlayerVarSpd.ino.elf" "WavFilePlayerVarSpd.cpp.o" "EncoderButton\EncoderButton.cpp.o" "Encoder\Encoder.cpp.o" "Bounce2\Bounce2.cpp.o" "Audio\memcpy_audio.S.o" "Audio\data_bandlimit_step.c.o" "Audio\data_spdif.c.o" "Audio\data_ulaw.c.o" "Audio\data_waveforms.c.o" "Audio\data_windows.c.o" "Audio\analyze_fft1024.cpp.o" "Audio\analyze_fft256.cpp.o" "Audio\analyze_notefreq.cpp.o" "Audio\analyze_peak.cpp.o" "Audio\analyze_print.cpp.o" "Audio\analyze_rms.cpp.o" "Audio\analyze_tonedetect.cpp.o" "Audio\async_input_spdif3.cpp.o" "Audio\control_ak4558.cpp.o" "Audio\control_cs42448.cpp.o" "Audio\control_cs4272.cpp.o" "Audio\control_sgtl5000.cpp.o" "Audio\control_tlv320aic3206.cpp.o" "Audio\control_wm8731.cpp.o" "Audio\effect_bitcrusher.cpp.o" "Audio\effect_chorus.cpp.o" "Audio\effect_combine.cpp.o" "Audio\effect_delay.cpp.o" "Audio\effect_delay_ext.cpp.o" "Audio\effect_envelope.cpp.o" "Audio\effect_fade.cpp.o" "Audio\effect_flange.cpp.o" "Audio\effect_freeverb.cpp.o" "Audio\effect_granular.cpp.o" "Audio\effect_midside.cpp.o" "Audio\effect_multiply.cpp.o" "Audio\effect_rectifier.cpp.o" "Audio\effect_reverb.cpp.o" "Audio\effect_wavefolder.cpp.o" "Audio\effect_waveshaper.cpp.o" "Audio\filter_biquad.cpp.o" "Audio\filter_fir.cpp.o" "Audio\filter_ladder.cpp.o" "Audio\filter_variable.cpp.o" "Audio\input_adc.cpp.o" "Audio\input_adcs.cpp.o" "Audio\input_i2s.cpp.o" "Audio\input_i2s2.cpp.o" "Audio\input_i2s_hex.cpp.o" "Audio\input_i2s_oct.cpp.o" "Audio\input_i2s_quad.cpp.o" "Audio\input_pdm.cpp.o" "Audio\input_pdm_i2s2.cpp.o" "Audio\input_spdif3.cpp.o" "Audio\input_tdm.cpp.o" "Audio\input_tdm2.cpp.o" "Audio\mixer.cpp.o" "Audio\output_adat.cpp.o" "Audio\output_dac.cpp.o" "Audio\output_dacs.cpp.o" "Audio\output_i2s.cpp.o" "Audio\output_i2s2.cpp.o" "Audio\output_i2s_hex.cpp.o" "Audio\output_i2s_oct.cpp.o" "Audio\output_i2s_quad.cpp.o" "Audio\output_mqs.cpp.o" "Audio\output_pt8211.cpp.o" "Audio\output_pt8211_2.cpp.o" "Audio\output_pwm.cpp.o" "Audio\output_spdif.cpp.o" "Audio\output_spdif2.cpp.o" "Audio\output_spdif3.cpp.o" "Audio\output_tdm.cpp.o" "Audio\output_tdm2.cpp.o" "Audio\play_memory.cpp.o" "Audio\play_queue.cpp.o" "Audio\play_sd_raw.cpp.o" "Audio\play_sd_wav.cpp.o" "Audio\play_serialflash_raw.cpp.o" "Audio\Quantizer.cpp.o" "Audio\record_queue.cpp.o" "Audio\Resampler.cpp.o" "Audio\spi_interrupt.cpp.o" "Audio\synth_dc.cpp.o" "Audio\synth_karplusstrong.cpp.o" "Audio\synth_pinknoise.cpp.o" "Audio\synth_pwm.cpp.o" "Audio\synth_simple_drum.cpp.o" "Audio\synth_sine.cpp.o" "Audio\synth_tonesweep.cpp.o" "Audio\synth_waveform.cpp.o" "Audio\synth_wavetable.cpp.o" "Audio\synth_whitenoise.cpp.o" "Audio\utility\sqrt_integer.c.o" "Audio\utility\imxrt_hw.cpp.o" "SPI\SPI.cpp.o" "SD\SD.cpp.o" "SdFat\FreeStack.cpp.o" "SdFat\MinimumSerial.cpp.o" "SdFat\common\FmtNumber.cpp.o" "SdFat\common\FsCache.cpp.o" "SdFat\common\FsDateTime.cpp.o" "SdFat\common\FsName.cpp.o" "SdFat\common\FsStructs.cpp.o" "SdFat\common\FsUtf.cpp.o" "SdFat\common\PrintBasic.cpp.o" "SdFat\common\upcase.cpp.o" "SdFat\ExFatLib\ExFatDbg.cpp.o" "SdFat\ExFatLib\ExFatFile.cpp.o" "SdFat\ExFatLib\ExFatFilePrint.cpp.o" "SdFat\ExFatLib\ExFatFileWrite.cpp.o" "SdFat\ExFatLib\ExFatFormatter.cpp.o" "SdFat\ExFatLib\ExFatName.cpp.o" "SdFat\ExFatLib\ExFatPartition.cpp.o" "SdFat\ExFatLib\ExFatVolume.cpp.o" "SdFat\ExFatLib\upcase.cpp.o" "SdFat\FatLib\FatDbg.cpp.o" "SdFat\FatLib\FatFile.cpp.o" "SdFat\FatLib\FatFileLFN.cpp.o" "SdFat\FatLib\FatFilePrint.cpp.o" "SdFat\FatLib\FatFileSFN.cpp.o" "SdFat\FatLib\FatFormatter.cpp.o" "SdFat\FatLib\FatName.cpp.o" "SdFat\FatLib\FatPartition.cpp.o" "SdFat\FatLib\FatVolume.cpp.o" "SdFat\FsLib\FsFile.cpp.o" "SdFat\FsLib\FsNew.cpp.o" "SdFat\FsLib\FsVolume.cpp.o" "SdFat\iostream\istream.cpp.o" "SdFat\iostream\ostream.cpp.o" "SdFat\iostream\StdioStream.cpp.o" "SdFat\iostream\StreamBaseClass.cpp.o" "SdFat\SdCard\SdCardInfo.cpp.o" "SdFat\SdCard\SdioTeensy.cpp.o" "SdFat\SdCard\SdSpiCard.cpp.o" "SdFat\SpiDriver\SdSpiArtemis.cpp.o" "SdFat\SpiDriver\SdSpiChipSelect.cpp.o" "SdFat\SpiDriver\SdSpiDue.cpp.o" "SdFat\SpiDriver\SdSpiESP.cpp.o" "SdFat\SpiDriver\SdSpiParticle.cpp.o" "SdFat\SpiDriver\SdSpiSTM32.cpp.o" "SdFat\SpiDriver\SdSpiSTM32Core.cpp.o" "SdFat\SpiDriver\SdSpiTeensy3.cpp.o" "SerialFlash\SerialFlashChip.cpp.o" "SerialFlash\SerialFlashDirectory.cpp.o" "MIDI\MIDI.cpp.o" "TeensyVariablePlayback\interpolation.cpp.o" "LittleFS\LittleFS.cpp.o" "LittleFS\LittleFS_NAND.cpp.o" "LittleFS\littlefs\lfs.c.o" "LittleFS\littlefs\lfs_util.c.o" "ILI9341_t3\font_Arial.c.o" "ILI9341_t3\font_ArialBold.c.o" "ILI9341_t3\glcdfont.c.o" "ILI9341_t3\ILI9341_t3.cpp.o" "XPT2046_Touchscreen\XPT2046_Touchscreen.cpp.o" "TeensyTimerTool\config.cpp.o" "TeensyTimerTool\API\baseTimer.cpp.o" "TeensyTimerTool\API\Timer.cpp.o" "TeensyTimerTool\ErrorHandling\error_handler.cpp.o" "TeensyTimerTool\TimerModules\GPT\GPTChannel.cpp.o" "TeensyTimerTool\TimerModules\PIT4\PIT.cpp.o" "TeensyTimerTool\TimerModules\RTC\RTC.cpp.o" "TeensyTimerTool\TimerModules\TCK\TCK.cpp.o" "TeensyTimerTool\TimerModules\TCK\TckChannelBase.cpp.o" "TeensyTimerTool\TimerModules\TCK\tickCounters.cpp.o" "FastLED\bitswap.cpp.o" "FastLED\colorpalettes.cpp.o" "FastLED\colorutils.cpp.o" "FastLED\FastLED.cpp.o" "FastLED\hsv2rgb.cpp.o" "FastLED\lib8tion.cpp.o" "FastLED\noise.cpp.o" "FastLED\platforms.cpp.o" "FastLED\power_mgt.cpp.o" "FastLED\wiring.cpp.o" "FastLED\platforms\esp\32\clockless_rmt_esp32.cpp.o" "Wire\Wire.cpp.o" "Wire\WireIMXRT.cpp.o" "Wire\WireKinetis.cpp.o" "Wire\utility\twi.c.o" "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/core.a" "-LC:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release" -larm_cortexM7lfsp_math -lm -lstdc++
## recipe.objcopy.eep.pattern
"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/WavFilePlayerVarSpd.ino.elf" "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/WavFilePlayerVarSpd.ino.eep"
## recipe.objcopy.hex.pattern
"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/WavFilePlayerVarSpd.ino.elf" "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/WavFilePlayerVarSpd.ino.hex"
recipe.hooks.objcopy.postobjcopy.1.pattern
"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-tools\1.59.0/teensy_secure" encrypthex TEENSY41 "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/WavFilePlayerVarSpd.ino.hex"
recipe.hooks.postbuild.1.pattern
"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-tools\1.59.0/teensy_post_compile" "-file=WavFilePlayerVarSpd.ino" "-path=C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release" "-tools=c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-tools\1.59.0/" "-board=TEENSY41"
Can't find location of default key .pem file, skipping .ehex encryption
Warning*: for Arduino 1.8.x, Teensyduino must be installed with a special installer
Boards Manager installation give incomplete setup!
Download the Installer at https*: www.pjrc.com\teensy\td_download.html
recipe.hooks.postbuild.2.pattern
"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-tools\1.59.0/stdout_redirect" "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/WavFilePlayerVarSpd.ino.sym" "c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-objdump" -t -C "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/WavFilePlayerVarSpd.ino.elf"
recipe.hooks.postbuild.3.pattern
"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-tools\1.59.0/teensy_size" "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/WavFilePlayerVarSpd.ino.elf"
recipe.hooks.postbuild.4.pattern
"c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-tools\1.59.0/stdout_redirect" "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/WavFilePlayerVarSpd.ino.lst" "c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/WavFilePlayerVarSpd.ino.elf"
teensy_size: Memory Usage on Teensy 4.1:
teensy_size: FLASH: code:165900, data:39596, headers:8516 free for files:7912452
teensy_size: RAM1: variables:45344, code:162324, padding:1516 free for local variables:315104
teensy_size: RAM2: variables:24928 free for malloc/new:499360
# Compute Size: "c:\Users\justi\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-size" -A "C:\Users\justi\AppData\Local\Temp\VMBuilds\WavFilePlayerVarSpd\teensy41\Release/WavFilePlayerVarSpd.ino.elf"
Program : WavFilePlayerVarSpd (2.13 secs)
Uploading 'WavFilePlayerVarSpd' to 'Teensy 4.1 (teensy41)' using 'usb:0/140000/0/2/2/2/3'
Warning: for Arduino 1.8.x, Teensyduino must be installed with a special installer.
Download the Installer at https://www.pjrc.com/teensy/td_download.html
The upload process has finished.
Just verified that this just happened on second machine....all software is the same except it's Windows 10. So it appears it isn't a glich.Windows 11, Visual Micro 2.2024.0223, Visual Studio 17.9.2, Connected to Arduino IDE 2.3.2, TeensyLoader 1.59.
No nightly builds...just release updates.
