Hi just wondering if I need the prop shield to play audio out of speakers on a teensy 3.6 does it also handle motion controlled audio? or led based response to audio
I found this github here where the audio signal comes in to the teensy via a circuit and then it uses that to work with the led strip.. I was wondering if the teensy was playing a wav or the like, can you pre-interpret the audio data and get the calculations done and drive the strip without the analog audio in?
https://github.com/2xAA/Audio-Light-Tube
Thanks
Tom
Thanks
Tom
