I made a little tool to transfer files from and to the serial flash.
Would be great if you could test it.
I plan to extend it, to allow access to the internal eeprom, and maybe, SD.
Usage:
On PC:
The gz - file contains the Linux-version, the *.zip the Windows-version
Commandline:
List files : teensytransfer -l
Write file to flash : teensytransfer [-w] filename
Read file from flash : teensytransfer -r filename > file
Delete file from flash : teensytransfer -e filename
It should work for the optional flash on the audio shield, too (not tested)
Sorry, at the moment there is no MAC version (I don't know how to compile it - any hints ?
https://github.com/FrankBoesing/TeensyTransfer
Edit: It would be great if there was a "Serial + Raw Hid" mode..
Usage:
- open Arduino, set USB-Mode to "Raw Hid"
- load teensytransfertool.ino, compile, and flash it to the teensy
On PC:
Commandline:
