Hi Everyone
Can someone please tell me why this code works on pin 15 of a T4.1 (sounds a buzzer):
But this code does not work on pin 12?
It's bound to be something obvious. Thank you for your help.
long buzzerThreshold = 48000; // threshold tone frequency
uint16_t buzzerDutyOnTime = buzzerThreshold / 4; // default volume duty cycle 1:3 on time = 25%
uint16_t buzzerDutyOffTime = (buzzerThreshold / 4) * 3; // default volume duty cycle 1:3 off time = 75%
CCM_CCGR6 |= CCM_CCGR6_QTIMER3(CCM_CCGR_ON); // enable QTIMER3 clock p.1091
IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_03 = 0x01; // set mux mode pin 15 to QTIMER3_TIMER3 p.495
TMR3_ENBL = 0; // disable timer for setup p.3008
TMR3_LOAD3 = 0; // intitial/reset value p.2998
TMR3_CNTR3 = 0; // reset counter to 0 p.2999
TMR3_SCTRL3 = 0x01; // TMR_SCTRL_OEN (output enable) p.3002 p.3024
TMR3_CSCTRL3 = 0x06; // TMR_CSCTRL_CL2(1) | TMR_CSCTRL_CL1(2) p.3004
TMR3_COMP23 = buzzerDutyOnTime; // pulse width ON time in ticks p.2998 p.3009
TMR3_CMPLD23 = buzzerDutyOnTime; // ON time preload value p.3003 p.3009
TMR3_COMP13 = buzzerDutyOffTime; // pulse width OFF time in ticks p.2997 p.3009
TMR3_CMPLD13 = buzzerDutyOffTime; // OFF time preload value p.3003 p.3009
TMR3_CTRL3 = 0x3024; // TMR_CTRL_CM(1)| TMR_CTRL_PCS(13) | TMR_CTRL_LENGTH | TMR_CTRL_OUTMODE(4) p.2999
// prescaler 1 = 3024, prescaler 32 = 3A24
TMR3_ENBL = 0x08; // enable timer / buzzer p.3008
void loop() {}
CCM_CCGR6 |= CCM_CCGR6_QTIMER1(CCM_CCGR_ON); // enable QTIMER1 clock p.1091
IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_01 = 0x01; // set mux mode pin 12 to QTIMER1_TIMER1 p.509
TMR1_ENBL = 0; // disable timer for setup p.3008
TMR1_LOAD1 = 0; // intitial/reset value p.2998
TMR1_CNTR1 = 0; // reset counter to 0 p.2999
TMR1_SCTRL1 = 0x01; // TMR_SCTRL_OEN (output enable) p.3002 p.3023
TMR1_CSCTRL1 = 0x06; // TMR_CSCTRL_CL2(1) | TMR_CSCTRL_CL1(2) p.3004
TMR1_COMP21 = buzzerDutyOnTime; // pulse width ON time in ticks p.2998 p.3009
TMR1_CMPLD21 = buzzerDutyOnTime; // ON time preload value p.3003 p.3009
TMR1_COMP11 = buzzerDutyOffTime; // pulse width OFF time in ticks p.2997 p.3009
TMR1_CMPLD11 = buzzerDutyOffTime; // OFF time preload value p.3003 p.3009
TMR1_CTRL1 = 0x3024; // TMR_CTRL_CM(1)| TMR_CTRL_PCS(13) | TMR_CTRL_LENGTH | TMR_CTRL_OUTMODE(4) p.2999
TMR1_ENBL = 0x08; // enable timer / buzzer p.3008 (enable when required)
void loop() {}
