Clock Speed : 48000000 Hz ( 48 MHz), Divisor 1
Clock Speed : 24000000 Hz ( 24 MHz), Divisor 2
Clock Speed : 12000000 Hz ( 12 MHz), Divisor 4
Clock Speed : 8000000 Hz ( 8 MHz), Divisor 6
Clock Speed : 6000000 Hz ( 6 MHz), Divisor 8
Clock Speed : 4800000 Hz ( 4.8 MHz), Divisor 10
Clock Speed : 4000000 Hz ( 4 MHz), Divisor 12
Clock Speed : 3428571 Hz (3.428571 MHz), Divisor 14
Clock Speed : 3000000 Hz ( 3 MHz), Divisor 16
Clock Speed : 2666666 Hz (2.666667 MHz), Divisor 18
Clock Speed : 2400000 Hz ( 2.4 MHz), Divisor 20
Clock Speed : 2181818 Hz (2.181818 MHz), Divisor 22
Clock Speed : 2000000 Hz ( 2 MHz), Divisor 24
Clock Speed : 1846153 Hz (1.846154 MHz), Divisor 26
Clock Speed : 1714285 Hz (1.714286 MHz), Divisor 28
Clock Speed : 1600000 Hz ( 1.6 MHz), Divisor 30
Clock Speed : 1500000 Hz ( 1.5 MHz), Divisor 32
Clock Speed : 1411764 Hz (1.411765 MHz), Divisor 34
Clock Speed : 1333333 Hz (1.333333 MHz), Divisor 36
Clock Speed : 1263157 Hz (1.263158 MHz), Divisor 38
Clock Speed : 1200000 Hz ( 1.2 MHz), Divisor 40
Clock Speed : 1142857 Hz (1.142857 MHz), Divisor 42
Clock Speed : 1090909 Hz (1.090909 MHz), Divisor 44
Clock Speed : 1043478 Hz (1.043478 MHz), Divisor 46
Clock Speed : 1000000 Hz ( 10 KHz), Divisor 48
Clock Speed : 960000 Hz ( 9.6 KHz), Divisor 50
Clock Speed : 923076 Hz (9.230769 KHz), Divisor 52
Clock Speed : 888888 Hz (8.888888 KHz), Divisor 54
Clock Speed : 857142 Hz (8.571428 KHz), Divisor 56
Clock Speed : 827586 Hz (8.275862 KHz), Divisor 58
Clock Speed : 800000 Hz ( 8 KHz), Divisor 60
Clock Speed : 774193 Hz (7.741936 KHz), Divisor 62
Clock Speed : 750000 Hz ( 7.5 KHz), Divisor 64
Clock Speed : 727272 Hz (7.272727 KHz), Divisor 66
Clock Speed : 705882 Hz (7.058824 KHz), Divisor 68
Clock Speed : 685714 Hz (6.857143 KHz), Divisor 70
Clock Speed : 666666 Hz (6.666667 KHz), Divisor 72
Clock Speed : 648648 Hz (6.486486 KHz), Divisor 74
Clock Speed : 631578 Hz (6.315789 KHz), Divisor 76
Clock Speed : 615384 Hz (6.153846 KHz), Divisor 78
Clock Speed : 600000 Hz ( 6 KHz), Divisor 80
Clock Speed : 585365 Hz (5.853659 KHz), Divisor 82
Clock Speed : 571428 Hz (5.714286 KHz), Divisor 84
Clock Speed : 558139 Hz (5.581396 KHz), Divisor 86
Clock Speed : 545454 Hz (5.454545 KHz), Divisor 88
Clock Speed : 533333 Hz (5.333333 KHz), Divisor 90
Clock Speed : 521739 Hz (5.217391 KHz), Divisor 92
Clock Speed : 510638 Hz (5.106383 KHz), Divisor 94
Clock Speed : 500000 Hz ( 5 KHz), Divisor 96
Clock Speed : 489795 Hz (4.897959 KHz), Divisor 98
Clock Speed : 480000 Hz ( 4.8 KHz), Divisor 100
Clock Speed : 470588 Hz (4.705883 KHz), Divisor 102
Clock Speed : 461538 Hz (4.615385 KHz), Divisor 104
Clock Speed : 452830 Hz (4.528302 KHz), Divisor 106
Clock Speed : 444444 Hz (4.444444 KHz), Divisor 108
Clock Speed : 436363 Hz (4.363636 KHz), Divisor 110
Clock Speed : 428571 Hz (4.285714 KHz), Divisor 112
Clock Speed : 421052 Hz (4.210526 KHz), Divisor 114
Clock Speed : 413793 Hz (4.137931 KHz), Divisor 116
Clock Speed : 406779 Hz (4.067797 KHz), Divisor 118
Clock Speed : 400000 Hz ( 4 KHz), Divisor 120
Clock Speed : 393442 Hz (3.934426 KHz), Divisor 122
Clock Speed : 387096 Hz (3.870968 KHz), Divisor 124
Clock Speed : 380952 Hz (3.809524 KHz), Divisor 126
Clock Speed : 375000 Hz ( 3.75 KHz), Divisor 128
Clock Speed : 369230 Hz (3.692308 KHz), Divisor 130
Clock Speed : 363636 Hz (3.636364 KHz), Divisor 132
Clock Speed : 358208 Hz ( 3.58209 KHz), Divisor 134
Clock Speed : 352941 Hz (3.529412 KHz), Divisor 136
Clock Speed : 347826 Hz (3.478261 KHz), Divisor 138
Clock Speed : 342857 Hz (3.428571 KHz), Divisor 140
Clock Speed : 338028 Hz (3.380281 KHz), Divisor 142
Clock Speed : 333333 Hz (3.333333 KHz), Divisor 144
Clock Speed : 328767 Hz (3.287671 KHz), Divisor 146
Clock Speed : 324324 Hz (3.243243 KHz), Divisor 148
Clock Speed : 320000 Hz ( 3.2 KHz), Divisor 150
Clock Speed : 315789 Hz (3.157895 KHz), Divisor 152
Clock Speed : 311688 Hz (3.116883 KHz), Divisor 154
Clock Speed : 307692 Hz (3.076923 KHz), Divisor 156
Clock Speed : 303797 Hz (3.037975 KHz), Divisor 158
Clock Speed : 300000 Hz ( 3 KHz), Divisor 160
Clock Speed : 296296 Hz (2.962963 KHz), Divisor 162
Clock Speed : 292682 Hz (2.926829 KHz), Divisor 164
Clock Speed : 289156 Hz (2.891566 KHz), Divisor 166
Clock Speed : 285714 Hz (2.857143 KHz), Divisor 168
Clock Speed : 282352 Hz (2.823529 KHz), Divisor 170
Clock Speed : 279069 Hz (2.790698 KHz), Divisor 172
Clock Speed : 275862 Hz (2.758621 KHz), Divisor 174
Clock Speed : 272727 Hz (2.727273 KHz), Divisor 176
Clock Speed : 269662 Hz (2.696629 KHz), Divisor 178
Clock Speed : 266666 Hz (2.666667 KHz), Divisor 180
Clock Speed : 263736 Hz (2.637362 KHz), Divisor 182
Clock Speed : 260869 Hz (2.608696 KHz), Divisor 184
Clock Speed : 258064 Hz (2.580645 KHz), Divisor 186
Clock Speed : 255319 Hz (2.553192 KHz), Divisor 188
Clock Speed : 252631 Hz (2.526316 KHz), Divisor 190
Clock Speed : 250000 Hz ( 2.5 KHz), Divisor 192
Clock Speed : 247422 Hz (2.474227 KHz), Divisor 194
Clock Speed : 244897 Hz ( 2.44898 KHz), Divisor 196
Clock Speed : 242424 Hz (2.424242 KHz), Divisor 198
