I've searched for an answer to this but I'm still confused:
For the Adafruit Silicon MEMS Microphone Breakout that I'm playing with, the instructions say:
Thanks!!!!
"The output will have a DC bias of 0.67V so when its perfectly quiet that's what you'll read, there's a little drift. If the audio equipment you're using requires AC coupled audio, you can grab the signal out of the AC pin, which has a 10uF capacitor in series."
I understand that the Audio Shield has capacitors on the line-input, but I'm still not clear which output from the MEMS board I should use going into the Shield's line-in pins.Thanks!!!!
