Hi Community,
this is my first post in this forum.
Setup:
I bought a 10.1 Inch Eastrising Display with the RA8876 chip quite some time ago and tested it on an ARDUINO Mega with the matching shield.
Everything was working properly.
I then wanted to change the MCU to a TEENSY 4.1 but I am now encountering (occasionally) problems with the display.
Issue:
After a couple of minutes after startup some of the characters on the display are suddenly rotated by 90 deg and some parts of the display start changing colors.
I have used the Oscilloscope on all SPI line (MISO, MOSI, SCLK, CS) and one thing I have noticed is that, whenever I connect the probe of the oscilloscope to the SCLK pin, the display gets corrupted the same way as described above.
Other than this issue, the signals itself look "sharp and in good shape"
Library:
RA8876_master
https://github.com/xlatb/ra8876
Wiring:
Pin 9 Reset
Pin 10 CS
Pin 11 MOSI
Pin 12 MISO
Pin 13 SCLK
3.3V to Backlight
Soldered directly to the pins with 10" long wires going directly to the Display pins (twisted and shielded)
Eastrising also recommended grounding the frame of the display and adding a capacitor on the Power Supply pins of the display (47uF). I did that
Demo Code from Library (ra8876-demo) with changed SPI pins
Question:
The display is the only SPI devices in my project. Do I need any termination/pullup resistors?
Has anyone else encounter this problem? What can I do to troubleshoot it further?
As mentioned above, connecting the probe of the oscilloscope to the SCLK pin causes the display to glitch in the same fashion.
I understand that the Oscilloscope has a certain resistance/capacitance -- maybe that's the issue even if the scope is not connected?
Setup:
Issue:
Library:
RA8876_master
Wiring:
Pin 9 Reset
Pin 10 CS
Pin 11 MOSI
Pin 12 MISO
Pin 13 SCLK
3.3V to Backlight
Question:
