Thanks expect some annoyances - was getting confusing working with 3 libs - but as I said should get easier@mjs513 - I cloned a copy of library and will start going through it. Not going to worry about 16Bit mode for now. I'll concentrate on testing everything in 8Bit mode. I'm having to move my storage unit to another oneso I'm kinda bouncing between that and this...
I had the same headaches when I was duplicating out all of the code for the different boards. Some good news. I have everything working including the ones in "testcases" folder in 8Bit mode and most all of it working 16Bit modeThanks expect some annoyances - was getting confusing working with 3 libs - but as I said should get easier
lcdRegWrite(RA8876_CCR); // 01h
// lcdDataWrite(RA8876_PLL_ENABLE<<7|RA8876_WAIT_MASK<<6|RA8876_KEY_SCAN_DISABLE<<5|RA8876_TFT_OUTPUT24<<3
if(BUS_WIDTH == 16) {
lcdDataWrite(RA8876_PLL_ENABLE<<7|RA8876_WAIT_NO_MASK<<6|RA8876_KEY_SCAN_DISABLE<<5|RA8876_TFT_OUTPUT24<<3
|RA8876_I2C_MASTER_DISABLE<<2|RA8876_SERIAL_IF_ENABLE<<1|RA8876_HOST_DATA_BUS_16BIT);
|RA8876_I2C_MASTER_DISABLE<<2|RA8876_SERIAL_IF_ENABLE<<1|RA8876_HOST_DATA_BUS_8BIT);
lcdDataWrite(RA8876_PLL_ENABLE << 7 | RA8876_WAIT_NO_MASK << 6 | RA8876_KEY_SCAN_DISABLE << 5 | RA8876_TFT_OUTPUT24 << 3 |
RA8876_I2C_MASTER_DISABLE << 2 | RA8876_SERIAL_IF_ENABLE << 1 | RA8876_HOST_DATA_BUS_SERIAL);
Sorry was off doing other things. Hope your moving went well. Knew there had to be something.I had the same headaches when I was duplicating out all of the code for the different boards. Some good news. I have everything working including the ones in "testcases" folder in 8Bit mode and most all of it working 16Bit modeThe biggest issue was missing init code for RA8876 REG[01h] in parallel mode:
Basically its already there - probably should rename it. Had to a hack for drawPixel:The only other thing that is needed is another define for lets say "USE_SPI" for use in SPI mode.
#define use_lcdDataWrite16bbp
Thanks will make it easier to update.Once I finish I will create another branch like yours on my repo, "RA8876_combined" with the changes...
@mjs513 @KurtE - Well all sketches seem to be working now in 8Bit mode and 16Bit mode including the sketches in the "testcases" folder
I done for the day. I found and fixed a few more issues tomorrow I will update RA8876_common on my GitHub after going through all of the examples again in 8/16Bit modes. Hopefully I can also setup the RA8876 SPI display again to test the SPI version of the library. Then I can start in on the Dev board and MicroMod version...
#if defined(ARDUINO_TEENSY41)
// FlexIO pins: data: 19 18 14 15 40 41 17 16 WR:36 RD:37
// FlexIO3
#define DISPLAY_WR 36
#define DISPLAY_RD 37
#define DISPLAY_D0 19 // FlexIO3:0 D0
#define DISPLAY_D1 18 // FlexIO3:1 |
#define DISPLAY_D2 14 // FlexIO3:2 |
#define DISPLAY_D3 15 // FlexIO3:3 |
#define DISPLAY_D4 40 // FlexIO3:4 |
#define DISPLAY_D5 41 // FlexIO3:5 |
#define DISPLAY_D6 17 // FlexIO3:6 |
#define DISPLAY_D7 16 // FlexIO3:7 D7
#define DISPLAY_D8 22 // FlexIO3:8 D8
#define DISPLAY_D9 23 // FlexIO3:9 |
#define DISPLAY_D10 20 // FlexIO3:10 |
#define DISPLAY_D11 21 // FlexIO3:11 |
#define DISPLAY_D12 38 // FlexIO3:12 |
#define DISPLAY_D13 39 // FlexIO3:13 |
#define DISPLAY_D14 26 // FlexIO3:14 |
#define DISPLAY_D15 27 // FlexIO3:15 D15
RA8876_t41_p::RA8876_t41_p(const uint8_t DCp, const uint8_t CSp, const uint8_t RSTp)
: _dc(DCp), _cs(CSp), _rst(RSTp),
_data_pins{DISPLAY_D0, DISPLAY_D1, DISPLAY_D2, DISPLAY_D3, DISPLAY_D4, DISPLAY_D5, DISPLAY_D6, DISPLAY_D7,
#if defined(DISPLAY_D8)
DISPLAY_D8, DISPLAY_D9, DISPLAY_D10, DISPLAY_D11, DISPLAY_D12, DISPLAY_D13, DISPLAY_D14, DISPLAY_D15}, _bus_width(BUS_WIDTH),
#else
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff}, _bus_width(8),
_wr_pin(DISPLAY_WR), _rd_pin(DISPLAY_RD)
RA8876_GFX(BUS_WIDTH);
Very nice, I have been running around this morning chasing down a lost cell phone. Going to have some breakfast and then do the final GitHub update into "RA8876_combined". Will check out your repo...Quick update: have some other stuff going on, so not sure how much I will get done today.
But, I created a new branch:
GitHub - KurtE/Ra8876LiteTeensy at combined_t4x_wip
Teensy RA8876 Driver. Contribute to KurtE/Ra8876LiteTeensy development by creating an account on GitHub.github.com
So far what I have done, is to create a header file with defaults by board type:
like:
Changed the constructor to save away these values:Code:#if defined(ARDUINO_TEENSY41) // FlexIO pins: data: 19 18 14 15 40 41 17 16 WR:36 RD:37 // FlexIO3 #define DISPLAY_WR 36 #define DISPLAY_RD 37 #define DISPLAY_D0 19 // FlexIO3:0 D0 #define DISPLAY_D1 18 // FlexIO3:1 | #define DISPLAY_D2 14 // FlexIO3:2 | #define DISPLAY_D3 15 // FlexIO3:3 | #define DISPLAY_D4 40 // FlexIO3:4 | #define DISPLAY_D5 41 // FlexIO3:5 | #define DISPLAY_D6 17 // FlexIO3:6 | #define DISPLAY_D7 16 // FlexIO3:7 D7 #define DISPLAY_D8 22 // FlexIO3:8 D8 #define DISPLAY_D9 23 // FlexIO3:9 | #define DISPLAY_D10 20 // FlexIO3:10 | #define DISPLAY_D11 21 // FlexIO3:11 | #define DISPLAY_D12 38 // FlexIO3:12 | #define DISPLAY_D13 39 // FlexIO3:13 | #define DISPLAY_D14 26 // FlexIO3:14 | #define DISPLAY_D15 27 // FlexIO3:15 D15
Code:RA8876_t41_p::RA8876_t41_p(const uint8_t DCp, const uint8_t CSp, const uint8_t RSTp) : _dc(DCp), _cs(CSp), _rst(RSTp), _data_pins{DISPLAY_D0, DISPLAY_D1, DISPLAY_D2, DISPLAY_D3, DISPLAY_D4, DISPLAY_D5, DISPLAY_D6, DISPLAY_D7, #if defined(DISPLAY_D8) DISPLAY_D8, DISPLAY_D9, DISPLAY_D10, DISPLAY_D11, DISPLAY_D12, DISPLAY_D13, DISPLAY_D14, DISPLAY_D15}, _bus_width(BUS_WIDTH), #else 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff}, _bus_width(8), #endif _wr_pin(DISPLAY_WR), _rd_pin(DISPLAY_RD) { RA8876_GFX(BUS_WIDTH); }
I update the method: FASTRUN void RA8876_t41_p::FlexIO_Init() {
To use the pins that are stored in the array and the like. First I figures out which flexio object it is, plus maps the D0, RD, WR
pins to their flexIO pin...
Updated all of the configure functions like: FlexIO_Config_SnglBeat to use the computed flexio pin...
like:
| FLEXIO_SHIFTCTL_PINSEL(_flexio_D0) /* Shifter's pin start index */
and:
| FLEXIO_TIMCTL_PINSEL(_flexio_WR) /* Timer' pin index: WR pin */
Note: not sure how the RD pin was working are thought to work. It had some of the FlexIO stuff commented out, and digitalWriteFast calls to set high or low, but it still had the hard coded flexio RD pin mapping in: FlexIO_Config_SnglBeat_Read
So I copied over the gpioRead/gpioWrite functions from our other library.
And it sets the pin in Flexio or GPIO mode depending on Reads or writes...
I built with this and it still runs. Next up will be to remove where it resets the FlexIO object each time it does something, as well you might have some other FlexIO object on the same Flexio (like maybe a serial), which you probably don't want all of its setting reset all of the time...
I have not tried it yet, but it might actually run now on MicroMod FlexIO2, with the current stuff. Although it would use Interrupts instead of DMA for some of the multi-beat stuff.
Off to do some other stuff
Strange thats now what I am seeing with my current version (didnt incorporate your changes):One last issue with "RA8876_combined" is with "ILI_Ada_FontTest.ino". Font OpenSans24 is not working properly:
Ok just gave @KurtE's wip branch a shot without your changes and fonttest4 works fine!. FB Test - SPI: Works perfect., 8080: looks like issue with readPixel colors are off which may be issue with RD signal. Other than that no issue.@mjs513 - That is strange. As I mentioned all of the changes I made should be up at:
https://github.com/wwatson4506/Ra8876LiteTeensy/tree/RA8876_combined
I am now working with @KurtE's "combined_t4x_wip" branch. Unfortunately he forked a copy of the other "RA8876_combined" before I had all of the fixs put in. But it should be no problem doing the updates on his branch. The first thing I have to do is change how the RD signal is processed. FlexIO cannot give a RD signal that the RA8876 will accept so need to change it back to manual digitalWrite() usage...
tft.setBusWidth(8);
#if defined(use_spi)
tft.begin();
#else
tft.begin(20);
I know sort-of the chicken and the egg...@mjs513 - That is strange. As I mentioned all of the changes I made should be up at:
Sorry for the confusion. I'll finish making the needed changes and test. Is there a way to fork a single branch from a repo or do you have to fork the whole repo?I know sort-of the chicken and the egg...
That is, don't know what was updated from what @mjs513 branch has:
All of the changes I see up on your fork/branch from what is/was in @mjs513 branch look like:
Probably need to use some winmerge or the like program to compare.
And/or wait until you done with this set of changes and then continue to get it to work on MMOD (and DB4/5 on either FlexIO2 or FlexIO3 or both... Although I only have one such display
Sorry, my plans were to have @mjs513 and myself and others such as yourself to check out the changes as compared to the one I forked from.
Then do PR back into @mjs513 fork/branch. And then PR it back to your master fork. Not sure if that would have been master or new branch.
As for digitalWrite usage changes, again not a major thing to change back.
// Simply
uncomment the lines that look like:
//digitalWriteFast(RD_PIN, HIGH); // Set RD pin high manually
And comment out the lines: that look like:
gpioRead(); // write line high, pin 12(rst) as output
or
gpioWrite();
EDIT: I made those changes and pushed it up to my fork/branch
TNot a problem... Been there done that (many times)...Sorry for the confusion. I'll finish making the needed changes and test. Is there a way to fork a single branch from a repo or do you have to fork the whole repo?
Interesting, that's not what I was getting at first. I'll have to to take a look on my end. The issue was with the multiple pulse RD signal provided by FlexIO:TNot a problem... Been there done that (many times)...
With the Read issue, looking at Logic Analyzer output, (using digitalWriteFast version), looks sort of strange:
The line with my scribbled arrow in green is the RD pin, the one pointed to by BLUE is the WR pin. Note, that the WR pin is changing state
looks like it is getting pulses on both RD and WR...
(((1 * 2) - 1) << 8) /* TIMCMP[15:8] = number of beats x 2 – 1 */
| (((ILI9488_CLOCK_READ) / 2) - 1); /* TIMCMP[7:0] = baud rate divider / 2 – 1 ::: 30 = 8Mhz with current controller speed */
// #define ILI9488_CLOCK_READ 30 //equates to 8mhz
#define ILI9488_CLOCK_READ 60 // equates to 4mhz
//#define ILI9488_CLOCK_READ 120 //equates to 2mhz
Already tried that before I believe but it has been quite a while since I played with this. I can setup the test sketch and check it out again. The reads from video memory were were the problem not register reads. When reading from a memory location that had been written to with a 16bit value very rarely returned the correct value. Will check it out tomorrow...Potentially the problem is the timing. That is for example with the ILI9341 and the ILI948x displays,
I know we need to do memory reads at a lower clock speed
In our Parallel ILI948x code,
the FlexIO_Config_SnglBeat_Read() is setup to use a different Clock...
p->TIMCMP[_flexio_timer] =
Code:(((1 * 2) - 1) << 8) /* TIMCMP[15:8] = number of beats x 2 – 1 */ | (((ILI9488_CLOCK_READ) / 2) - 1); /* TIMCMP[7:0] = baud rate divider / 2 – 1 ::: 30 = 8Mhz with current controller speed */
Which we have been experimenting at different clock speeds:
Code:// #define ILI9488_CLOCK_READ 30 //equates to 8mhz #define ILI9488_CLOCK_READ 60 // equates to 4mhz //#define ILI9488_CLOCK_READ 120 //equates to 2mhz
Wonder if we try something like that here as well.
If what you have works… if it ain’t broke don’t fix it…Already tried that before I believe but it has been quite a while since I played with this. I can setup the test sketch and check it out again. The reads from video memory were were the problem not register reads. When reading from a memory location that had been written to with a 16bit value very rarely returned the correct value. Will check it out tomorrow...
I still am curious as to why there is more than one RD pulse per single read event. I know there is a dummy read with each RD event but I have seen up to 4 RD pulses per RD event. Also the RF says that writing to the config register automatically triggers a RD event as well. So does switching from a read config to a write config trigger a RD/WR pulse? Inquiring minds need to knowIf what you have works… if it ain’t broke don’t fix it…
just curious, I probably need to reread some of the flexio timer section, like when you do a read operation , and the clock signal goes low, how long is the setup time before the pins are sampled…
lcd.drawPixel(0x0000,0x0000,0xffff);
for(i = 0; i < 2; i++) {
rslt = lcd.getPixel(i,0);
Serial.printf("rslt = 0x%4.4X\n",rslt);
Press anykey to continue
rslt = 0x0000
rslt = 0x0000
rslt = 0x0000
rslt = 0x00FF
rslt = 0x0000
rslt = 0x0000
rslt = 0x0000
rslt = 0x0000
rslt = 0x0000
rslt = 0x00FF
SDRAM Dev Board and RA8876 parallel 8080 mode testing (8/16)
FlexIO_Init: D0:19 WR:36 RD:37
Bus speed: 20 MHZ
Bus Width: 8-bits
rslt = 0xFFFF
rslt = 0xFFFF
rslt = 0xFFFF
rslt = 0xFFFF
rslt = 0xFFFF
rslt = 0xFFFF
rslt = 0xFFFF
rslt = 0xFFFF
Inquiring minds want to knowConsistent accurate results from 16bit read of location 0. I'm satisfied for now that using the digitalWrite() method is probably the only and most reliable way to do the video memory reads unless somebody can figure out how to use FlexIO RD reliably.
Sorry for the long post but I had to know that I had not missed something![]()
