I don't really understand your question. Maybe it would make more sense (to me, maybe for others too) if you give a little more context of what you're trying to accomplish?
But I can give you some facts I know about USB hubs.
Large USB hubs internally are really just a network of smaller hubs. Almost all hub chips implement 4 ports. When you shop for large USB hubs, you'll see 7 and 10 ports are common. The reason is 7 port hubs are usually a pair of 4 port hubs, and 10 port models have 2 extra hubs permanently connected to the first tier hub.
Though rare, 7 port hub chips do exist. I've only 7 port chip that implements USB2, never any for USB3, but maybe they do exist?
USB3 hubs actually implement 2 parallel hubs, one for USB2 speeds (1.5, 12, 480 Mbit/sec) and another for USB3 speeds (5, 10 Gbit/sec). So when you plug in 10 port USB3 hub, if you watch closely you'll see it's actually 6 separate hubs in Windows Device Manager or Linux "lsusb" or MacOS System Repory, because it physically has 3 chips inside and each 4-port chip implements separate USB2 and USB3 hubs.
USB hubs are pretty much all the same for data. They mainly differ by the amount and quality of power they deliver.
Back in the days of Teensy 3.x and earlier, when we had only 12 Mbit/sec speed, the hub's Transaction Translator (TT) design mattered if you wanted many boards communicating simultaneously at nearly their maximum speed. Most hubs have a single TT that is shared by all downstream ports. But some have a TT on every port. Your PC communicates with the TT at 480 Mbit/sec, and the TT then communicates with the USB device at 12 or 1.5 Mbit/sec. Not really an issue for Teensy 4.x which has 480 Mbit/sec speed.
There is nothing like TTs in USB3. When they added 5 and 10 Gbit/sec speed, it was done by adding a completely separate system. Teensy 4.x connected to a USB3 hub will use the USB2 hub portion to communicate at 480 Mbit. USB3 never does anything like USB2 TTs that allow slower speeds to communicate at the higher speed between your PC and the USB hub.
Whether any of this really matter to you, I don't know, because I really don't understand why you're asking this question. But if you're thinking very large hubs are somehow different especially if made in rugged or professional form factors, the reality is they're actually made from the silicon as smaller hubs. For example,
this expensive 16 port rackmount hub is almost certainly 5 small hubs interally, a 4 port hub with 4 more 4 port hubs connected to it. But it does have impressive power output specs, which maybe justifies the price.
