The recorded sample sounds great in Audacity but when I play it back the level bar maxes out in the red at 0 on voice peaks. Is this the proper level or should I attenuate it a bit? I am using the line level input on the audio shield. I found the "Find clipping" tool under analyze and it does show somc clipping. Also the wave form goes to 1 on the positive peaks but only to about -.75 on the negative peaks. I thought the line level was isolated by a cap on the input. Should I try to rebalance the center bias?
