chipaudette
With my Teensy Hearing Aid project (based on a Teensy 3.6), I was curious how much power I was consuming...so I measured it. I was surprised to see that it took 90 mA to run my system. So, I looked for ways to reduce the power. One very easy and successful technique was to add a WFI command asm(" WFI"); to my loop() function. It puts the processor to sleep instead of looping pointlessly. I found that it cut my power consumption by a third, which means that my battery life increased 50%. Not bad!
What's really nice is how well it works with the Audio Library. The WFI command only works if the system has been configured with an Interrupt. I don't (yet) know how to do this. But, since I'm using the Audio Library, it already fires a bunch of interrupts in the background. I didn't have to add anything! Just add the single WFI command and you're done. The easiest power that you'll ever save.
If you're interested, more detail is here: http://openaudio.blogspot.com/2016/11/reducing-current-draw.html
What other techniques can I use to save power?
Chip
Chip
