Release of any is making note off sound of already hold keys ??
charnjit
i was testing with simple sketch for synth to make monophonic synth using this sketch
#include <Keypad.h>
#include <Arduino.h>
#include <TeensyVariablePlayback.h>
#include "PlaySynthMusic.h"
#include <SoftwareSerial.h>
const uint8_t ROWS = 7;  // 7 rows
const uint8_t COLS = 4;  //4 columns
char keys[ROWS][COLS] = {
    { 1, 2, 3, 4 },
    { 5, 6, 7, 8 },
    { 9, 10, 11, 12 },
    { 13, 14, 15, 16 },
    { 17, 18, 19, 20 },
    { 21, 22, 23, 24 },
    { 25, 26, 27, 28 }
uint8_t rowPins[ROWS] = { 33, 34, 35, 36, 37, 38, 39 };
uint8_t colPins[COLS] = { 40, 41, 14, 16 };
Keypad kpd = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
AudioSynthWaveform       waveform1;      //xy=175.7142857142857,257.1428571428571
AudioSynthWaveform       waveform2;
AudioSynthWaveform       waveform3;
AudioSynthWaveform       waveform4;
AudioPlaySdResmp           playSdWav1;     //xy=185.00003814697266,190.0000171661377
AudioEffectEnvelope      envelope1;      //xy=324.2857131958008,255.7142848968506
AudioMixer4              mixer1;         //xy=754.2857494354248,214.28570938110352
AudioAmplifier           amp1;           //xy=949.9999656677246,191.42856407165527
AudioAmplifier           amp2;           //xy=952.8571510314941,242.8571376800537
AudioOutputI2S           i2s1;           //xy=1099.9999542236328,228.5714282989502
AudioConnection          patchCord1(waveform1, envelope1);
AudioConnection          patchCord2(waveform3, 0, mixer1, 0);
AudioConnection          patchCord3(playSdWav1, 1, mixer1, 1);
AudioConnection          patchCord4(envelope1, 0, mixer1, 2);
AudioConnection          patchCord9(waveform2, 0, mixer1, 3);
AudioConnection          patchCord5(mixer1, amp1);
AudioConnection          patchCord6(mixer1, amp2);
AudioConnection          patchCord7(amp1, 0, i2s1, 0);
AudioConnection          patchCord8(amp2, 0, i2s1, 1);
AudioControlSGTL5000     audioShield;     //xy=654.2857131958008,335.71429920196533
int RAGA[] = {50,52,54,55,57,59,61,62,64,66,67,69,71,73, 74,76,78};
SoftwareSerial mySerial(0, 1); // RX,TX
     mySerial.begin(115200);
     kpd.setHoldTime(2000);
    if (!(SD.begin(BUILTIN_SDCARD))) {
        while (1) {      Serial.println("Unable to access the SD card");
        delay(500);   }  }
    AudioMemory(128);
    audioShield.enable();
    audioShield.volume(1.0);
    amp1.gain(1.0);
    amp2.gain(1.0);
    playSdWav1.enableInterpolation(true);
     waveform1.begin(WAVEFORM_TRIANGLE);
      waveform2.begin(WAVEFORM_SQUARE);
       waveform3.begin(WAVEFORM_SINE);
   unsigned long t=0;
  if (kpd.getKeys()) {
        for (int i = 0; i < LIST_MAX; i++)
        {    int mykey = (kpd.key[i].kchar);
            if ((kpd.key[i].stateChanged) && (mykey<29) && (mykey>0)) //  -----------------------------------------Key Changed----------------
            {      switch (kpd.key[i].kstate) {
                    case PRESSED:
                    case RELEASED:
// --------------------------------Read serial--------------------------------------------------------------
 int type, note, velocity, channel, d1, d2;
         if (mySerial.available()>=2)
      type = mySerial.read();
      note = mySerial.read();
   if (type==101) {  Serial.println(note);  Serial.println("on");
                      envelope1.releaseNoteOn(0);
                      waveform1.begin(1.0,Pitch_Freq[note+52],WAVEFORM_SAWTOOTH);
                      envelope1.noteOn();
                      envelope1.attack(5);
                      envelope1.hold(0);
                      envelope1.decay(0);
                      envelope1.sustain(1.0);
                       Serial.println(Pitch_Freq[note+52]);  }
    else  if (type==100) {    Serial.println("off");
                envelope1.noteOff();
from above code i playing keyboard with serial communication. getting succesfully note_on on Particular key press & Note_off on Key release.
first ... please check below
am I using correct code in "void loop() " for Note_on & Note_off event ????
Because i am feeling a little latency in Fast fingering.
                      envelope1.noteOn();
                      envelope1.hold(0);
                      envelope1.decay(0);
if No , Please describe here correct way...
and Second Main thing to ask:---
please try to understand what i want to ask. I do not know what word is used for event of synth process inwhich " in mono mode , if any new key is released after holded a old key , old key should begin sound.
i want my synth behave like below.
for example in sequence :- suppose : [Note1 for Key1 , Note2 for Key2 , Note3 for Key3
step1:- i press and hold key1 >>Note1 will sound on ,
step2:- i press and hold key2 without release key 1 >>> Note1 will sound off and Note2 will sound on.
step3:-i press and hold key3 without release Key1 & Key2 >> Note2 will sound off Note3 will sound on.
step4:-now if i will release Key3 without release Key1 & Key2 >> Note3 will sound off and Note2 should be sound on.because of key2 was holded before presses key3
step5:- now if i will release Key2 without release key1 >>> Note1 should be sound on because of already hold of Key1
just like Professional Synthesizor Keyboard in Mono Mode Patches.
I am sorry i you did not understand my wording.
if anyone my senior understand above event of NoteOn/NoteOFF, please describe How to write it in code
In general, you need to store data on each key that is pressed, until after it is released (even for keys that aren't currently sounding):
  • Note Number
  • Velocity
  • Time pressed
You also need to decide what allocation method you want, for notes to voices. The three used for mono synths are:
  1. Highest note priority (the note with the highest note number is chosen)
  2. Lowest note priority
  3. Last pressed (the most recent note)
The allocation function is called whenever there is an unallocated voice (first note, and after that whenever a note is released) .It is also called whenever a note is pressed (in highest priority mode, to see if it is higher thn the current note; in last mode, because it is the most recent note).
Thank you Nantonos for reply...
I just find youtube video for it
Teensy synth Part3 by Notes & Volts
Thank also to Notes & Volts . they provide code with video for my issue . i tested it is working
thanks to all of you ...
