Replacement for CS42448
grinch
Hi, I've done a lot of work with the Teensy Audio library and the CS42448 codec. I see now the part has been obsolesced, would definitely rather not have to redesign all the infrastructure I've built to support this.
A lot of this has been based on Paul's original codec PCB design on OSH Park and also the support the audio library gives for the component. Is there any replacement part that is recommended as an equivalent that could drop into an existing design, or go into an existing design with minimal modification?
