Replacing 7805 with Buck converter.
TonyAme
I have a circuit board that I've made for the Teensy 4.0 and Audio board. Currently using a 7805 with a 9V power adapter. The 7805 gets very hot, so thinking about using the muRata OKI-78SR-5/1.5-W36-C. https://www.lcsc.com/product-detail/C6134431.html?s_z=n_q_C6134431&globalKeyword=C6134431
(Q1 is just a p-channel mosfet that I use for reverse polarity protection).
Would I need to change any caps in my schematic?
Thanks in advance, very much appreciated.
Looks like it should work. Your design has 4 capacitors, which is good. We've seen problems in the past where people didn't use capacitors, even some converters that said capacitors weren't necessary. They are needed.
Another option to consider with your current setup is to just use an AC/DC input with a lower voltage. If you used a 7V instead of 9V input, it would cut power dissipation in the 7805 in half.
