So im guessing you would need to set the MUX on the pin back to standard io.Hi,
After programming the flexPWM at the register level, what is needed to return the pins to being available for digital read and write?
I tried pinMode() and digitalWrite() or digitalRead(), but to no avail.
Thank you
p = digital_pin_to_info_PGM + pin;
if (mode == OUTPUT || mode == OUTPUT_OPENDRAIN) {
*(p->reg + 1) |= p->mask; // TODO: atomic
if (mode == OUTPUT) {
*(p->pad) = IOMUXC_PAD_DSE(7);
} else { // OUTPUT_OPENDRAIN
*(p->pad) = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_ODE;
*(p->reg + 1) &= ~(p->mask); // TODO: atomic
if (mode == INPUT) {
} else if (mode == INPUT_PULLUP) {
*(p->pad) = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_PKE | IOMUXC_PAD_PUE | IOMUXC_PAD_PUS(3) | IOMUXC_PAD_HYS;
} else if (mode == INPUT_PULLDOWN) {
*(p->pad) = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_PKE | IOMUXC_PAD_PUE | IOMUXC_PAD_PUS(0) | IOMUXC_PAD_HYS;
} else { // INPUT_DISABLE
*(p->pad) = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_HYS;
*(p->mux) = 5 | 0x10;
It
It looks like that happens in pinMode() and digitalWrite() in digital.c.
Code:p = digital_pin_to_info_PGM + pin; if (mode == OUTPUT || mode == OUTPUT_OPENDRAIN) { *(p->reg + 1) |= p->mask; // TODO: atomic if (mode == OUTPUT) { *(p->pad) = IOMUXC_PAD_DSE(7); } else { // OUTPUT_OPENDRAIN *(p->pad) = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_ODE; } } else { *(p->reg + 1) &= ~(p->mask); // TODO: atomic if (mode == INPUT) { *(p->pad) = IOMUXC_PAD_DSE(7); } else if (mode == INPUT_PULLUP) { *(p->pad) = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_PKE | IOMUXC_PAD_PUE | IOMUXC_PAD_PUS(3) | IOMUXC_PAD_HYS; } else if (mode == INPUT_PULLDOWN) { *(p->pad) = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_PKE | IOMUXC_PAD_PUE | IOMUXC_PAD_PUS(0) | IOMUXC_PAD_HYS; } else { // INPUT_DISABLE *(p->pad) = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_HYS; } } *(p->mux) = 5 | 0x10;
And, I recall from another thread, that after using analogwriteFrequency() and analogWrite(), that normal gpio functionality is restored by calling pinMode() and digitalWrite()
So, I tried calling those, and the pins are still not functioning as digital i/o pins.
Is there a place in the teensy4 package code where the digital i/o pins are setup from scratch?
Hard to imagine you're hitting one of the really unusual cases, since FlexIO pretty much only needs a different mux setting.
define NBUFFER 2048
uint16_t buffer[NBUFFER]
unsigned int donothing_counter = 0;
void donothing()
donothing_counter++;
Serial.println("doing nothing")
// do this stuff in setup
pinMode(4,OUTPUT);
digitalWrite(4,LOW);
pinMode(5,OUTPUT);
digitalWrite(5,LOW);
pinMode(6,OUTPUT);
digitalWrite(6,LOW);
pinMode(10,OUTPUT);
digitalWrite(10,LOW);
SPISettings spi_settings( 30000000, MSBFIRST, SPI_MODE0); // 30 MHz, reads 1.5usecs/word including CNVST
SPI.begin();
SPI.beginTransaction(spi_settings);
// do this stuff in loop or main or whatever
if (pwm_lccd_setup( 0.01, 1E-6, 0.01, buffer, 0.01, 3, buffer, NBUFFER, donothing))
pwm_lccd_start();
while (donothing_counter<3)
sleep(1);
pwm_lcc_stop(); // maybe not necessary
pwm_lcc_done();
pinMode(4,OUTPUT)
pinMode(3,INPUT) // tie these together with a jumper
while(1) {
digitalWrite( 4, HIGH);
delay(1000)
Serial.println(digitalRead(3));
digitalWrite( 4, LOW);
delay(1000)
Here are the codes
Well that is pretty much the code snippet that I suggested.This is quite a lot of code, but it doesn't look like a complete program. I don't see a setup() or loop() function. Sorry, I really don't have time to review large code that I can't run on actual hardware.
If the issue is as simple as configuring the pin to FlexIO and then calling pinMode() and digitalWrite(), that ought to be achievable in a fairly small single page of code that I (or anyone else) can just copy into Arduino IDE and upload to a Teensy to reproduce the problem.
